* Distribution:
* Distribution version:
20.04.5 LTS
* The output… of "lxc info" or if that fails:
lxc info ct7839
Status: RUNNING
Type: container
PID: 2404105
Created: 2022/10/25 06:19 EEST
Last Used: 2022/11/03 18:12 EET
Resources:
Processes: 39
Disk usage:
root: 5.40GiB
CPU usage:
CPU usage (in seconds): 2
Memory usage:
Memory (current): 184.11MiB
Memory (peak): 186.48MiB
Network usage:
Type: broadcast
State: UP
Host interface: veth17b24774
MAC address: 00:16:3e:4f:f2:29
MTU: 1500
Bytes received: 13.33kB
Bytes sent: 39.75kB
Packets received: 154
Packets sent: 319
IP addresses:
inet: *.*.*.248/32 (global)
lo:
Type: loopback
State: UP
MTU: 65536
Bytes received: 0B
Bytes sent: 0B
Packets received: 0
Packets sent: 0
IP addresses:
inet: 127.0.0.1/8 (local)
inet6: ::1/128 (local)
* Kernel version:
5.4.0-131-generic lxc/lxd#147-Ubuntu
* LXC version:
5.7
* LXD version:
5.7
* Storage backend in use:
# Issue description
When run top inside containers
seen flapping info from other containers
top - 18:13:19 up 9 days, 13:49, 0 users, load average: 0.00, 0.00, 0.00
Tasks: 22 total, 1 running, 21 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.1 us, 0.0 sy, 0.0 ni, 99.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 16384.0 total, 15026.1 free, 659.4 used, 698.4 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 15724.6 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1 root 20 0 151508 10100 7928 S 0.0 0.1 0:00.26 systemd
77 root 20 0 187400 31912 31096 S 0.0 0.2 0:00.06 systemd-journal
99 root 20 0 17192 3156 2860 S 0.0 0.0 0:00.00 cron
100 message+ 20 0 8268 4220 3760 S 0.0 0.0 0:00.01 dbus-daemon
110 root 20 0 1116604 7264 5648 S 0.0 0.0 0:00.01 hosting-agent
128 root 20 0 880408 27180 25196 S 0.0 0.2 0:00.04 syslog-ng
131 root 20 0 13420 5596 4952 S 0.0 0.0 0:00.05 systemd-logind
139 root 20 0 258860 45900 35568 S 0.0 0.3 0:00.05 /usr/sbin/apach
140 root 20 0 1048440 6744 4576 S 0.0 0.0 0:00.00 process-slayer
141 root 20 0 13372 7140 6264 S 0.0 0.0 0:00.00 sshd
143 root 20 0 15540 2148 2032 S 0.0 0.0 0:00.00 agetty
153 apache 20 0 57140 7920 4100 S 0.0 0.0 0:00.00 /usr/sbin/apach
154 apache 20 0 58316 7396 3576 S 0.0 0.0 0:00.00 /usr/sbin/apach
156 root 20 0 19796 1308 0 S 0.0 0.0 0:00.00 nginx
157 apache 20 0 24380 7712 2220 S 0.0 0.0 0:00.00 nginx
180 apache 20 0 259380 19636 9252 S 0.0 0.1 0:00.00 /usr/sbin/apach
181 apache 20 0 259380 19636 9252 S 0.0 0.1 0:00.00 /usr/sbin/apach
369 nobody 20 0 29192 2572 1628 S 0.0 0.0 0:00.00 proftpd
370 mysql 20 0 1802904 76400 22648 S 0.0 0.5 0:00.13 mariadbd
420 Debian-+ 20 0 16884 6376 5304 S 0.0 0.0 0:00.12 exim4
516 root 20 0 20120 5132 3600 S 0.0 0.0 0:00.01 bash
519 root 20 0 20108 3768 3224 R 0.0 0.0 0:00.03 top
in 10 sec
top - 18:13:30 up 0 min, 0 users, load average: 0.00, 0.00, 0.00
%Cpu(s): 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 16384.0 total, 15025.4 free, 660.1 used, 698.5 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 15723.9 avail Mem
77 root 20 0 187400 31856 31040 S 0.0 0.2 0:00.06 systemd-journal
100 message+ 20 0 8268 4216 3756 S 0.0 0.0 0:00.01 dbus-daemon
128 root 20 0 880408 27176 25192 S 0.0 0.2 0:00.04 syslog-ng
157 apache 20 0 24380 7704 2212 S 0.0 0.0 0:00.00 nginx
519 root 20 0 20108 3768 3224 R 0.0 0.0 0:00.04 top
A brief description of the problem. Should include what you were
attempting to do, what you did, what happened and what you expected to
see happen.
# Steps to reproduce
1. Step one
2. Step two
3. Step three
# Information to attach
Config :
lxc config show ct7839 --expanded
boot.autostart: "true"
limits.cpu: "6"
limits.hugepages.1GB: 4GiB
limits.hugepages.2MB: 100MiB
limits.memory: 16GiB
limits.memory.enforce: hard
limits.memory.swap: "false"
limits.processes: "800"
raw.lxc: lxc.cgroup.memory.oom_control=1
security.idmap.base: "51345450"
security.idmap.isolated: "true"
user.fqdn: *1.m*.net
volatile.cloud-init.instance-id: 3479b700-4ad6-4a3f-a423-650bebca2138
volatile.eth0.host_name: veth17b24774
volatile.eth0.hwaddr: 00:16:3e:4f:f2:29
volatile.idmap.base: "51345450"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":51345450,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":51345450,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":51345450,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":51345450,"Nsid":0,"Maprange":65536}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":51345450,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":51345450,"Nsid":0,"Maprange":65536}]'
volatile.uuid: 78df104f-44ce-4969-92df-02761d2bbc71
ipv4.address: *.*.*.248
mtu: "1500"
nictype: routed
resolvconf:
path: /etc/resolv.conf
readonly: "true"
source: /etc/resolv.conf
limits.read: 2000iops
limits.write: 1000iops
pool: default
shared:
path: /shared
readonly: "true"
source: /shared
- [ ] Any relevant kernel output (`dmesg`)
- [ ] Container log (`lxc info NAME --show-log`)
- [ ] Container configuration (`lxc config show NAME --expanded`)
- [ ] Main daemon log (at /var/log/lxd/lxd.log or /var/snap/lxd/common/lxd/logs/lxd.log)
- [ ] Output of the client with --debug
- [ ] Output of the daemon with --debug (alternatively output of `lxc monitor` while reproducing the issue)
