Hi, I tried to v0.6 but the below errors appeared. How could I to setup GPU passthrough?
me@pc:~$ incus profile create nvidia
Profile nvidia created
me@pc:~$ incus profile set nvidia nvidia.runtime true
me@pc:~$ incus profile device add nvidia gpu gpu
Device gpu added to nvidia
me@pc:~$ incus launch images:ubuntu/23.04 u1 -p default -p nvidia
Creating u1
Starting u1
Error: Failed to run: /opt/incus/bin/incusd forkstart u1 /var/lib/incus/containers /run/incus/u1/lxc.conf: exit status 1
Try `incus info --show-log local:u1` for more info
me@pc:~$ incus info --show-log local:u1
Status: STOPPED
Type: container
Created: 2024/03/02 22:20 EET
Last Used: 2024/03/02 22:20 EET
Log:
lxc u1 20240302202013.865 ERROR conf - ../src/lxc/conf.c:run_buffer:322 - Script exited with status 1
lxc u1 20240302202013.865 ERROR conf - ../src/lxc/conf.c:lxc_setup:4437 - Failed to run mount hooks
lxc u1 20240302202013.865 ERROR start - ../src/lxc/start.c:do_start:1272 - Failed to setup container "u1"
lxc u1 20240302202013.865 ERROR sync - ../src/lxc/sync.c:sync_wait:34 - An error occurred in another process (expected sequence number 4)
lxc u1 20240302202013.876 WARN network - ../src/lxc/network.c:lxc_delete_network_priv:3631 - Failed to rename interface with index 0 from "eth0" to its initial name "veth0380407b"
lxc u1 20240302202013.876 ERROR start - ../src/lxc/start.c:__lxc_start:2107 - Failed to spawn container "u1"
lxc u1 20240302202013.876 ERROR lxccontainer - ../src/lxc/lxccontainer.c:wait_on_daemonized_start:878 - Received container state "ABORTING" instead of "RUNNING"
lxc u1 20240302202013.876 WARN start - ../src/lxc/start.c:lxc_abort:1036 - No such process - Failed to send SIGKILL via pidfd 17 for process 14081
lxc 20240302202014.302 ERROR af_unix - ../src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20240302202014.303 ERROR commands - ../src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command "get_init_pid"
