I’m having trouble using opengl in an ubuntu 18.04 or 19.04 container on ubuntu 18.04, and would like to buy a clue ![]()
To reproduce:
- get fresh ubuntu 18.04 system with nvidia card
- install proprietary driver with sudo ubuntu-driver autoinstall
- verify that glxgears works
- verify glxinfo | grep str shows e.g. NVIDIA 390.116
- sudo apt install snapd (and log out and back in to get in the group)
- sudo snap install lxd (because older lxd is much less happy with nvidia.runtime=true)
- spin up an lxc container and verify nvidia-smi works, e.g.
$ cat > mygpu-profile.tmp <<_EOF_
gpu:
type: gpu
X0:
path: /tmp/.X11-unix/X0
source: /tmp/.X11-unix/X0
environment.DISPLAY: :0
_EOF_
$ lxc profile create mygpu
$ lxc profile edit mygpu < mygpu-profile.tmp
$ lxc launch --profile default --profile mygpu ubuntu:19.04 demo-ubu1904 -c nvidia.runtime=true
$ sleep 10 # (for it to finish starting network?)
$ lxc exec demo-ubu1904 -- sh -c "apt update; apt install -y mesa-utils x11-apps"
$ lxc exec demo-ubu1904 nvidia-smi
Thu May 30 18:16:18 2019
| NVIDIA-SMI 390.116 Driver Version: 390.116 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce GTX 1080 Off | 00000000:01:00.0 On | N/A |
| 27% 34C P8 7W / 180W | 18MiB / 8117MiB | 0% Default |
- Try an X program. Works.
$ xhost +
$ lxc exec demo-ubu1904 xeyes
- Now try an opengl program. Boom!
$ lxc exec demo-ubu1904 glxinfo | grep str
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
X Error of failed request: GLXBadContext
Major opcode of failed request: 155 (GLX)
Minor opcode of failed request: 6 (X_GLXIsDirect)
I thought once nvidia-smi worked, I’d be home free, but alas no.
This works with Intel and AMD graphics, fwiw (minus the -c nvidia.runtime=true and nvidia-smi, of course)… so it seems to be nvidia-specific. Does nvidia-container-runtime not support, um, graphics?
Aha, LXD 3.6 has been released mentions another config flag: nvidia.driver.capabilities. Setting that to “graphics” does the trick. Whew!
So either use -c twice when launching on nvidia:
$ lxc launch --profile default --profile mygpu ubuntu:19.04 demo-ubu1904 -c nvidia.runtime=true -c nvidia.driver.capabilities=graphics
or add those two settings to the profile, e.g.
nvidia.runtime: false
nvidia.driver.capabilities: "graphics"
for non-nvidia systems, and just flip the false to true for nvidia systems.
