I can’t seem to get oauth2-proxy to run.
The container either complains about no route to host, or seems to fall back to ::1 as a dns server and fails (I presume since the network doesn’t come up). I am using the same profile that otherwise works for all my other containers.
Even stranger, it works when the host comes up, but after a stop and then a start, it doesn’t come up.
srv01:/home/amaccuish # incus init quay:oauth2-proxy/oauth2-proxy:latest oauth2-proxy --storage local --profile default
Creating oauth2-proxy
srv01:/home/amaccuish # incus config device add oauth2-proxy config disk source=/incus/data/oauth2-proxy/oauth2-proxy.cfg path=/oauth2-proxy.cfg
Device config added to oauth2-proxy
srv01:/home/amaccuish # incus start oauth2-proxy
srv01:/home/amaccuish # incus console --show-log oauth2-proxy
\[2026/01/12 18:57:17\] \[provider.go:55\] Performing OIDC Discovery…
\[2026/01/12 18:57:17\] \[main.go:59\] ERROR: Failed to initialise OAuth2 Proxy: error initialising provider: could not create provider data: error building OIDC ProviderVerifier: could not get verifier builder: error while discovery OIDC configuration: failed to discover OIDC configuration: error performing request: Get “https://xxx.xxx.xxx.xxx/realms/xxx/.well-known/openid-configuration”: dial tcp: lookup xxx.xxx.xxx.xxx on 10.216.157.1:53: dial udp 10.216.157.1:53: connect: network is unreachable
Has anyone faced a similar issue with a go app? I note that the container base image is the GoogleContainerTools distroless, perhaps these are not supported by incus?
Config
environment.HOME: /home/nonroot
environment.PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
environment.SSL_CERT_FILE: /etc/ssl/certs/ca-certificates.crt
environment.TERM: xterm
image.architecture: x86_64
image.description: quay.io/oauth2-proxy/oauth2-proxy (OCI)
image.id: oauth2-proxy/oauth2-proxy:latest
image.type: oci
oci.cwd: /home/nonroot
oci.entrypoint: /bin/oauth2-proxy --config /oauth2-proxy.cfg
oci.gid: '65532'
oci.uid: '65532'
volatile.base_image: 56e3daedf765c7a1eea6e366fbe684be7d3084830ade14b6174570d3c7960954
volatile.cloud-init.instance-id: 76d6fe9e-6d48-4298-82c4-7b2ad4ba97e2
volatile.container.oci: 'true'
volatile.eth0.hwaddr: 10:66:6a:91:99:f4
volatile.idmap.base: '0'
volatile.idmap.current: >-
[{"Isuid":true,"Isgid":false,"Hostid":400000000,"Nsid":0,"Maprange":500000001},{"Isuid":false,"Isgid":true,"Hostid":400000000,"Nsid":0,"Maprange":500000001}]
volatile.idmap.next: >-
volatile.last_state.ready: 'false'
volatile.uuid: cceaea66-bf73-491c-b141-da8a8bd29803
volatile.uuid.generation: cceaea66-bf73-491c-b141-da8a8bd29803
path: /oauth2-proxy.cfg
source: /incus/data/oauth2-proxy/oauth2-proxy.cfg
pool: local
description: ''
created_at: '2026-01-12T18:55:41.904851868Z'
status: Stopped
status_code: 102
last_used_at: '2026-01-12T18:55:53.693452252Z'
type: container
project: default
