I have the standard lxdbr0 bridge from an incus conversion and observed that OCI containers get a 10.34… address but are not being added to the var/lib/incus/networks/lxdbr0/dnsmasq.leases file. As such, I can not ping the oci containers on the lxdbr0 bridge with container name, but can ping using the 10.34… address.
The only entries appear to be standard incus containers. I do not see the IPV4 address for the incus container either, but not sure that I am reading the file correctly.
I am using Incus 6.4 on an Ubuntu 22.04 host converted from lxd to incus. I see I received a response indicating that it may be based on Alpine OCI images. These images are based on Alpine which as you know are very popular.
By the way, uptime kuma OCI image is debian 10 image and also has the same issue.
I would appreciate your thoughts?
The solution posted by alex14641 which I have not tried does not seem ideal because I assume when the OCI images get refreshed the change will be lost.
This is more of a quick fix: you will also have to restart the daemon when the container is restarted. I’m working on adding the daemon to the startup scripts for the container.
Thanks- This issue appears more related to the lxdbr0 bridge and dnsmaq process and does not seem specific to Alpine OCI containers. I am running Uptime Kuma OCI container and had the same dns entry problem with this debian 10 based image.
Also, interesting I am running an Openwrt container with another bridge interface under a 10.50… network and getting a dns entry in the openwrt router for the OCI containers.
I am hoping that Stephane could opine if this is a bug with lxdbrO bridge and Dnsmaq process or expected behavior.
Hi- I just upgrade to 6.5 and can confirmed it worked. It looks like the entire dnsmaq.leases file was refreshed and I can see both the IPV4 and IPV6 dns entries.
My use case was setting up Traefik reverse proxy and did not want to hardcode the ips for the container services. I assume this should work fine if Traefik is also on the lxdbr0 bridge.
You are awesome and I have been amazed how much progress you have made on the incus project in such a short time. Thanks for all your efforts.
By the way, I did not rebuild any of the OCI images on the lxbr0 bridge and all now have dns entires. The entire dnsmaq.leases file appears to have been rebuilt with the upgrade to 6.5.
Maybe I declared victory too soon on this issue. I know when I upgraded to 6.5, all the OCI containers were in the dnsmaq.leases file. Now it seems, I only see the native incus containers and the one debian based OCI container (Uptime Kuma). All the other OCI containers are now missing from the file which by the way are Alpine linux based.
Maybe the other poster in this tread was correct and Alpine images are an issue. I did run this command that appeared to resolve the issue in one of containers:
I have this issue with 6.4 and 6.5. I noticed this issue while setting up incus DNS: the containers would initially have IPv4 addresses (A records); then after a period of time the address would be gone. I suspect that any Docker container would have this problem.
I deleted the dnsmasq.leases file and rebooted the server. All the Ixdbr0 DNS entries were back. I then deleted and added some containers and everything was correctly being added and deleted. I checked a few hours later and all the OCI DNS addresses were gone.
I rebooted the server again this time leaving the dnsmasq.leases file alone and the dns addresses appeared again. I think this is impacting all OCI images and not just Alpine.
Thanks for confirming the issue as I was testing changing the lease expiry key. For now it seems a simple solution is to change the key to the high value to avoid the lease from being renewed as below:.
Set the ipv4.dhcp.expiry config option of the network to a high value like 8765h .
as a long time linux user and enjoyer of all things foss, thanks for the container-related development over the years.
as a long time virtualization user who’s now spent 12+ cumulative hours trying to breathe a pulse into the incus equivalent of ‘hello world’, i understand now why i’d always kept LXD at arms length and why the capitalist cronies at canonical took it over. rip
