It’s very hard.
I create a docker bridge first. docker network create keycloak
docker compose
services:
mysql:
image: mysql
container_name: mysql
environment:
- MYSQL_ROOT_PASSWORD=(MYSQL_ROOT_PASSWORD)
- MYSQL_DATABASE=keycloak
- MYSQL_USER=(MYSQL_USER)
- MYSQL_PASSWORD=(MYSQL_PASSWORD)
ports:
- 3306:3306
volumes:
- /docker/keycloak/mysql:/var/lib/mysql
keycloak:
image: quay.io/keycloak/keycloak:26.4.5
command: --config-file=/config/keycloak.conf start
container_name: keycloak
restart: unless-stopped
ports:
- 8080:8080
volumes:
- "/docker/keycloak/config:/config"
depends_on:
- mysql
networks:
default:
external: true
hostname=keycloak.example.com
proxy-headers=xforwarded
bootstrap-admin-username=tmpadm
bootstrap-admin-password=pass
http-port=8080
http-enabled=true
db=mysql
db-url-host=mysql
db-username=(MYSQL_USER)
db-password=(MYSQL_PASSWORD)
db-schema=keycloak
Keycloak doesn’t recommend use mysql. There will be tons of warning about mysql.
Then use whatever reverse proxy proxy port 8080 and use https://keycloak.example.com.
Waiting this showing in log: Listening on: ``http://0.0.0.0:8080
You know how to read docker log right? docker logs keycloak
Remember the forum will highlight any url start with https as a link, you don’t see it doesn’t mean I didn’t write it. Now go to https://keycloak.example.com to setup. Log in.
In left panel, click Manage realms , Create realm. Realm name : incus. Enabled: on. Click create.
Now Current realm will switch to incus. If not, click Manage realms , click incus.
Click Users, create new user, fill username, create. You will be redirect to User details page. Click credentials, set password, Temporary: off.
Open a new tab, go to https://keycloak.example.com/realms/incus/account for test the new user. You can login, good.
Click Clients, Create client,Client type : OpenID Connect, Client ID: incus, Next.
Client authentication: off. Authentication flow choose Standard flow and Direct access grants. Next. Well, I haven’t read all the doc, you really need to read.
Valid redirect URIs: https://incus.example.com/oidc/callback . Valid post logout redirect URIs: https://incus.example.com/oidc/callback . Save.
You can see this uri for openid config: https://keycloak.example.com/realms/incus/.well-known/openid-configuration
incus config set oidc.client.id=incus
incus config set oidc.issuer=https://keycloak.example.com/realms/incus/
incus config set oidc.scopes=openid,email,profile
Now you can visit https://incus.example.com and login with SSO.
