Hello
I have set up a container with 2 nic (namely eth0, eth1) bridged to 2 different interfaces.
nic eth0 is the main communication interface for the container.
nic eth1 is an on-demand interface, which should be disabled on boot up and enable using command ip link set eth1 up.
However, I couldn’t set the interface eth1 to be disabled on container boot up. Any ideas how can I configure it to achieve this goal?
Tried:
echo “iface eth1 inet manual” >> /etc/network/interfaces on the container and it’s not working.
Because /erc/network/interfaces will only work with debian as conteiner or ubuntu ( <=16/xenial). Ubuntu 18 uses netplan and if you like to use /etc/network/interfaces youĺl have to install ifupdown and remove /etc/netplan/01.xxx
Hope it helps 80)
It uses systemd-networkd to manage the interface to manage the network interfaces on the container.
ps. I have reconfigure my container back to its default image which does not come with NetworkManager.
I managed to solve it without installing additional packages. Yeah!
On my Ubuntu 19.04 container which uses netplan and network-d,
#!/bin/bash
# Deploy this file to /etc/networkd-dispatcher/routable.d/ and set executable i.e. chmod +x ${0}
case “$IFACE” in
eth1)
if [ ! -f /tmp/networkd.eth1.disabled.startup ]; then
dhclient -r eth1
ip link set eth1 down
touch /tmp/networkd.eth1.disabled.startup
fi
esac
Save the file in /etc/networkd-dispatcher/routable.d/networkd.down.interface and chmod +x it. It should disable eth1 on every powerup, reboot.
