Hello everyone
Today I restart my server and one of my containers didn 't run
Should I run : incus admin recover ?
Server Ubuntu-22.04
uname -a : Linux pauloric 5.15.0-102-generic #112-Ubuntu SMP Tue Mar 5 16:50:32 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
container: Ubuntu22-04
root@pauloric:/var/lib/incus/containers/squid# incus version
Client version: 6.0.0
Server version: 6.0.0
root@pauloric:/var/lib/incus/containers/squid# incus start squid
Error: Failed to run: /opt/incus/bin/incusd forkstart squid /var/lib/incus/containers /run/incus/squid/lxc.conf: exit status 1
Try incus info --show-log squid
for more info
root@pauloric:/var/lib/incus/containers/squid# incus info --show-log squid
Status: STOPPED
Type: container
Created: 2024/04/12 17:00 -03
Last Used: 2024/04/16 08:44 -03
Snapshots:
| NAME | TAKEN AT | EXPIRES AT | STATEFUL |
| snap0 | 2024/04/16 03:00 -03 | 2024/04/17 03:00 -03 | NO |
Log:
lxc squid 20240416114448.489 WARN idmap_utils - …/src/lxc/idmap_utils.c:lxc_map_ids:165 - newuidmap binary is missing
lxc squid 20240416114448.489 WARN idmap_utils - …/src/lxc/idmap_utils.c:lxc_map_ids:171 - newgidmap binary is missing
lxc squid 20240416114448.643 ERROR start - …/src/lxc/start.c:start:2204 - No such file or directory - Failed to exec “/sbin/init”
lxc squid 20240416114448.643 ERROR sync - …/src/lxc/sync.c:sync_wait:34 - An error occurred in another process (expected sequence number 7)
lxc squid 20240416114448.646 WARN network - …/src/lxc/network.c:lxc_delete_network_priv:3671 - Failed to rename interface with index 0 from “eth0” to its initial name “veth496b4268”
lxc squid 20240416114448.646 ERROR lxccontainer - …/src/lxc/lxccontainer.c:wait_on_daemonized_start:837 - Received container state “ABORTING” instead of “RUNNING”
lxc squid 20240416114448.646 ERROR start - …/src/lxc/start.c:__lxc_start:2114 - Failed to spawn container “squid”
lxc squid 20240416114448.646 WARN start - …/src/lxc/start.c:lxc_abort:1037 - No such process - Failed to send SIGKILL via pidfd 17 for process 33041
lxc 20240416114448.746 ERROR af_unix - …/src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20240416114448.746 ERROR commands - …/src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command “get_init_pid”
