For some reason a shell while loop breaks off when doing lxc exec in the loop.
Here is a shell command that stops after one loop iteration.
echo 'does3
kanboard
gulp' | while read h; do lxc exec $h cat /etc/issue; done
A for loop does not have the problem. And any other lxc command (e.g. lxc info) does not have the problem either.
for h in does3 kanboard gulp; do lxc exec $h cat /etc/issue; done
Can any of the shell gurus explain what’s causing this?
BTW. The list of containers is the output of this
lxc list --format json | jq -r '.[] | select(.status == "Running") | .name'
My workaround is to avoid while and doit like this.
for h in $(lxc list --format json | jq -r '.[] | select(.status == "Running") | .name')
do
echo ">>>> $h"
lxc exec $h cat /etc/issue | head -1
done
