Recently, operators of projects can’t seem to view or edit networks they should be able to. It looks like the network-project relations are missing?
Even when I create the OVN networks with “project” set, the operators of projects still does not have access.
This appears to be a regression, or a change in behavior at least, since the users in the shared project used to be able to access the networks defined in restrictions.networks.access in that shared prroject.
This is the individual personal projects I was attempting to create by syncing IDP users to Incus and openfga:
[moonpie@osiris .ssh]$ incus project show moonpiedumplings
features.images: "false"
features.networks: "false"
limits.cpu: "4"
limits.memory: 8GiB
restricted: "true"
restricted.backups: block
restricted.containers.nesting: allow
restricted.networks.access: internal0, moonpiedumplings-vlab, moonpiedumplings-cloudnet
restricted.snapshots: allow
description: User specific project
used_by: []
[moonpie@osiris .ssh]$ incus network list --project moonpiedumplings
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| internal0 | bridge | YES | 10.230.28.1/24 | fd42:9c6d:a864:7762::1/64 | | 11 | CREATED |
| moonpiedumplings-cloudnet | ovn | YES | 10.37.155.1/24 | fd42:af92:fdc8:2522::1/64 | Personal network for moonpiedumplings | 0 | CREATED |
| moonpiedumplings-vlab | ovn | YES | 192.168.40.1/24 | none | Non routed network for moonpiedumplings | 0 | CREATED |
Although right now, the moonpiedumplings-* networks have their project set as default. But that still wouldn’t explain why the shared project stopped working for everybody.
Okay, I am having trouble creating OVN networks inside a project. I create them with project: username but they show up as project: default after I create them.,
Okay, I see where I screwed up. I have to have networks set as isolated in project settings. And then I have to specify which network names are acceptable uplinks. And then users can create and manage their own OVN networks.
Ah, I see. I need to stop using restricted.networks.access, and instead set restricted.networks.uplink to enable OVN networks to be able to use uplinks.
And then I need to set features.networks: true to isolate the project networks. Then users can create and manage their own OVN networks inside of a project.
