Hi, I cannot get OpenShfit to work in an LXD container:
On my machine:
$ lxd --version
4.3
$ lxc config get openshift security.nesting
true
$ uname -r
4.19.0-9-amd64
$ grep PRETTY_NAME /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
In my openshift LXD container:
[openshift@openshift ~]$ /opt/crc-linux-1.13.0-amd64/crc start
INFO Checking if oc binary is cached
INFO Checking if podman remote binary is cached
INFO Checking if goodhosts binary is cached
INFO Checking if running as non-root
INFO Checking if Virtualization is enabled
INFO Checking if KVM is enabled
INFO Checking if libvirt is installed
INFO Checking if user is part of libvirt group
INFO Checking if libvirt daemon is running
INFO Checking if a supported libvirt version is installed
INFO Checking if crc-driver-libvirt is installed
INFO Checking if libvirt 'crc' network is available
INFO Checking if libvirt 'crc' network is active
INFO Checking if NetworkManager is installed
INFO Checking if NetworkManager service is running
INFO Checking if /etc/NetworkManager/conf.d/crc-nm-dnsmasq.conf exists
INFO Checking if /etc/NetworkManager/dnsmasq.d/crc.conf exists
INFO Starting CodeReady Containers VM for OpenShift 4.5.1...
ERRO Error starting stopped VM: virError(Code=89, Domain=47, Message='Start job for unit machine-qemu\x2d1\x2dcrc.scope failed with 'failed'')
[openshift@openshift ~]$ grep PRETTY_NAME /etc/os-release
PRETTY_NAME="CentOS Linux 8 (Core)"
Hope you can help, it would be awesome to have that giant contained
