Using Opensuse 15.2, and latest lxd built by @cyphar.
lxc start testcontainer container starts i can see it by opening another console and running lxc ls.
but the command start hangs and does not return. ctl c to terminate and then lxc info --show-log testcontainer
lxc default_testcontainer 20210102005812.433 WARN cgfsng - cgroups/cgfsng.c:cg_unified_delegate:2845 - No such file or directory - Failed to read /sys/kernel/cgroup/delegate
lxc default_testcontainer 20210102005812.435 WARN cgfsng - cgroups/cgfsng.c:create_cgroup_tree:1150 - File exists - The /sys/fs/cgroup/cpuset//lxc.monitor.default_testcontainer cgroup already existed
lxc default_testcontainer 20210102005812.435 ERROR cgfsng - cgroups/cgfsng.c:cgfsng_monitor_create:1257 - Failed to create cgroup "(null)"
lxc default_testcontainer 20210102005812.435 WARN cgfsng - cgroups/cgfsng.c:create_cgroup_tree:1150 - File exists - The /sys/fs/cgroup/cpuset//lxc.monitor.default_testcontainer-1 cgroup already existed
lxc default_testcontainer 20210102005812.435 WARN cgfsng - cgroups/cgfsng.c:create_cgroup_tree:1150 - File exists - The /sys/fs/cgroup/cpuset//lxc.monitor.default_testcontainer-2 cgroup already existed
lxc default_testcontainer 20210102005812.435 ERROR cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1136 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.default_testcontainer-3"
lxc default_testcontainer 20210102005812.437 ERROR cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1136 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.default_testcontainer"
lxc default_testcontainer 20210102005812.439 ERROR utils - utils.c:lxc_can_use_pidfd:1834 - Kernel does not support pidfds
lxc default_testcontainer 20210102005812.457 WARN cgfsng - cgroups/cgfsng.c:fchowmodat:1448 - No such file or directory - Failed to fchownat(17, cgroup.threads, 500000001, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
any help please.
Thank you.
