For others reading this in the hope to get info about openvpn:
You can simply install it in a normal unpriviledged container (because the tun device is added by default).
Recommendations:
set the limitnproc higher in the systemd-service file
edit /lib/systemd/system/openvpn@.service:LimitNPROC=50
(Note some people comment LimitNPROC out or set it to infinity, I would try to set it higher first and if you experience problems, you can disable it.) -
add a Firewall like ufw:
See for example this article in the arch linux wiki. -
use a macvlan-device (container will get ipadress directly from router, so no need for proxy) or use a proxy-device for the port-forwarding
Some time ago I started to use openvpn again and I set it up inside an unpriviledged container.
The good news is everything seems to be working so far and I would like to write an up-to-date howto for users searching for this, but I have two questions:
- What is the status on the limitnproc problem (see Systemd Issue 6011?
In the systemd issue it seemed that @brauner and poettering had different opinions about the reason for this problem?
I still get an error stating:
Note: Cannot set tx queue length on tun0: Operation not permitted (errno=1)
So the problem still seems to exist, though the server is working so far (already tested it for long hours with other persons connected).
Additional Info:
LXD Version: 4.0.0
unpriviledged
OS: Debian Testing amd64 (both host and container)
Kernel: 5.5.0-1-amd64
security.idmap.isolated: “true”
nictype: macvlan
- tun-device: I found this (little bit) older thread (openvpn-on-lxd-3-0-3), in which @stgraber stated:
Also worth noting that /dev/net/tun is allowed in the default configuration, so no special config is needed for this.
I guess that is still the case?
I ask because many other howtos still show stuff like this:
#config on host:
lxc config set name raw.lxc ‘lxc.cgroup.devices.allow = c 10:200 rwm’
lxc config device add name tun unix-char path=/dev/net/tun
#config in container:
- mknod /dev/net/tun c 10 200
- install OpenVPN (GitHub - Nyr/openvpn-install: OpenVPN road warrior installer for Ubuntu, Debian, AlmaLinux, Rocky Linux, CentOS and Fedora or manual)
- edit /lib/systemd/system/openvpn@.service – comment out/remove
LimitNPROC=10- systemctl daemon-reload or reboot container
I have to admit, that I followed this and wondered why the tun device was already in place
