OpenVPN on LXD 2.0
I tried to setup a OpenVPN Server on a LXD alpine-linux container.
So as i understand it correctly the tun/tap device is provided by LXD. But the OpenVPN server have problems to access the device:
TUN/TAP device tap0 opened
Note: Cannot set tx queue length on tap0: Operation not permitted (errno=1)
How can I fix this?
Do you get any other errors?
Reading this post at VPN in containers | Stéphane Graber's website it says
Fri Sep 26 17:48:12 2014 TUN/TAP device tun0 opened
Fri Sep 26 17:48:12 2014 Note: Cannot set tx queue length on tun0: Operation not permitted (errno=1)
Fri Sep 26 17:48:12 2014 do_ifconfig, tt->ipv6=1, tt->did_ifconfig_ipv6_setup=1
Fri Sep 26 17:48:12 2014 /sbin/ip link set dev tun0 up mtu 1500
but it then manages to continue.
The VPN runs on tap mode. When I start the client following error appears:
ERROR: Cannot ioctl TUNSETIFF tap: Operation not permitted (errno=1)
Exiting due to fatal error
It looks that you are missing some Linux capability, CAP_NET_ADMIN.
Try to pass it to the container according to https://github.com/lxc/lxd/issues/1982
Thanks for your help.
Finally it was a client side problem…
Nice!
Write a few words about what you did in order to help any future visitor that come here.
As simos wrote… :slight_smile: It would be nice with some hints
I run a wrong chown command, so the file rights of the client was wrong.
This is not very descriptive - what properties/where? Did you end up using anything like:
lxc config set container-name raw.lxc=lxc.cap.drop=some-cap
I don’t think installing openvpn in a container represents any specific issues. I set up the openvpn container using macvlan, so it get’s its IP address from the router. I have arranged for the router to forward openvpn’s required ports to the openvpn server, and once connected, I can then interact directly with all internal devices (except the lxd host). I installed using the openvpn-access-server (https://openvpn.net/index.php/access-server/overview.html), and it worked ‘out of the box’, but If you install openvpn by hand, it should work the same way.
Jon
A couple replies to you asked if you could write up how you finally configured everything to work.
Did you get around to it? If so did you post it somewhere?
thanks
Hi @ebahn
I have the same thing. Is there a way to set ip up so it can also interact with the lxd host?
