While configuring OpenWrt, I noticed that the ULA prefix is not being auto generated. According to this post [Solved] Auto-generate ULA Prefix on compiled firmware - #5 by jow - For Developers - OpenWrt Forum by Jow, it is generated automatically upon first boot if the network config has ula_prefix
set to auto
I believe all that is needed would be to add the following to the network configuration located at /etc/config/network
config globals 'globals'
option ula_prefix 'auto'
Otherwise the generation code could be adapted to set it, that’s here: openwrt/package/base-files/files/etc/uci-defaults/12_network-generate-ula at 17b0d1379a3cd4a2e2dbefa7d0f9bc281269f97e · openwrt/openwrt · GitHub
