Part 1
$ dmesg
[ 0.000000] microcode: microcode updated early to revision 0x71a, date = 2020-03-24
[ 0.000000] Linux version 5.4.0-90-generic (buildd@lgw01-amd64-054) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #101-Ubuntu SMP Fri Oct 15 20:00:55 UTC 2021 (Ubuntu 5.4.0-90.101-generic 5.4.148)
[ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-5.4.0-90-generic root=/dev/mapper/ubuntu--vg-ubuntu--lv ro maybe-ubiquity
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009bfff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007d2effff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007d2f0000-0x000000007d31bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007d31c000-0x000000007d35afff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000007d35b000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000247fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Dell Inc. PowerEdge R420/072XWF, BIOS 2.9.0 01/09/2020
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2400.257 MHz processor
[ 0.003221] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.003223] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.003226] last_pfn = 0x2480000 max_arch_pfn = 0x400000000
[ 0.003232] MTRR default type: uncachable
[ 0.003233] MTRR fixed ranges enabled:
[ 0.003234] 00000-9FFFF write-back
[ 0.003235] A0000-BFFFF uncachable
[ 0.003235] C0000-CBFFF write-protect
[ 0.003236] CC000-D3FFF write-back
[ 0.003237] D4000-EBFFF uncachable
[ 0.003237] EC000-FFFFF write-protect
[ 0.003238] MTRR variable ranges enabled:
[ 0.003239] 0 base 000000000000 mask 3FFF80000000 write-back
[ 0.003240] 1 base 000100000000 mask 3FFF00000000 write-back
[ 0.003241] 2 base 000200000000 mask 3FFE00000000 write-back
[ 0.003242] 3 base 000400000000 mask 3FFC00000000 write-back
[ 0.003242] 4 base 000800000000 mask 3FF800000000 write-back
[ 0.003243] 5 base 001000000000 mask 3FF000000000 write-back
[ 0.003244] 6 base 002000000000 mask 3FFC00000000 write-back
[ 0.003245] 7 base 002400000000 mask 3FFF80000000 write-back
[ 0.003245] 8 disabled
[ 0.003246] 9 disabled
[ 0.003694] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.004289] e820: update [mem 0x80000000-0xffffffff] usable ==> reserved
[ 0.004295] last_pfn = 0x7d2f0 max_arch_pfn = 0x400000000
[ 0.014057] found SMP MP-table at [mem 0x000fe710-0x000fe71f]
[ 0.024815] check: Scanning 1 areas for low memory corruption
[ 0.024820] Using GB pages for direct mapping
[ 0.024959] RAMDISK: [mem 0x2def3000-0x32f70fff]
[ 0.024966] ACPI: Early table checksum verification disabled
[ 0.024972] ACPI: RSDP 0x00000000000F10D0 000024 (v02 DELL )
[ 0.024976] ACPI: XSDT 0x00000000000F1218 0000A4 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.024984] ACPI: FACP 0x000000007D33534C 0000F4 (v03 DELL PE_SC3 00000001 DELL 00000001)
[ 0.024991] ACPI: DSDT 0x000000007D31C000 0072F1 (v01 DELL PE_SC3 00000001 INTL 20110211)
[ 0.024994] ACPI: FACS 0x000000007D337000 000040
[ 0.024997] ACPI: FACS 0x000000007D337000 000040
[ 0.025000] ACPI: APIC 0x000000007D334478 0001EA (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025003] ACPI: SPCR 0x000000007D334664 000050 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025006] ACPI: HPET 0x000000007D3346B8 000038 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025009] ACPI: DMAR 0x000000007D3346F4 000110 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025012] ACPI: MCFG 0x000000007D334A10 00003C (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025015] ACPI: WD__ 0x000000007D334A50 000134 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025019] ACPI: SLIC 0x000000007D334B88 000024 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025022] ACPI: ERST 0x000000007D3234B4 000270 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025025] ACPI: HEST 0x000000007D323724 00055C (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025028] ACPI: BERT 0x000000007D3232F4 000030 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025031] ACPI: EINJ 0x000000007D323324 000190 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025035] ACPI: TCPA 0x000000007D3352E4 000064 (v02 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025038] ACPI: PC__ 0x000000007D335274 00006E (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025041] ACPI: SRAT 0x000000007D334DB0 0004C0 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.025044] ACPI: SSDT 0x000000007D338000 006D84 (v01 INTEL PPM RCM 80000001 INTL 20061109)
[ 0.025047] ACPI: Reserving FACP table memory at [mem 0x7d33534c-0x7d33543f]
[ 0.025048] ACPI: Reserving DSDT table memory at [mem 0x7d31c000-0x7d3232f0]
[ 0.025049] ACPI: Reserving FACS table memory at [mem 0x7d337000-0x7d33703f]
[ 0.025050] ACPI: Reserving FACS table memory at [mem 0x7d337000-0x7d33703f]
[ 0.025051] ACPI: Reserving APIC table memory at [mem 0x7d334478-0x7d334661]
[ 0.025052] ACPI: Reserving SPCR table memory at [mem 0x7d334664-0x7d3346b3]
[ 0.025053] ACPI: Reserving HPET table memory at [mem 0x7d3346b8-0x7d3346ef]
[ 0.025054] ACPI: Reserving DMAR table memory at [mem 0x7d3346f4-0x7d334803]
[ 0.025055] ACPI: Reserving MCFG table memory at [mem 0x7d334a10-0x7d334a4b]
[ 0.025056] ACPI: Reserving WD__ table memory at [mem 0x7d334a50-0x7d334b83]
[ 0.025057] ACPI: Reserving SLIC table memory at [mem 0x7d334b88-0x7d334bab]
[ 0.025058] ACPI: Reserving ERST table memory at [mem 0x7d3234b4-0x7d323723]
[ 0.025059] ACPI: Reserving HEST table memory at [mem 0x7d323724-0x7d323c7f]
[ 0.025060] ACPI: Reserving BERT table memory at [mem 0x7d3232f4-0x7d323323]
[ 0.025061] ACPI: Reserving EINJ table memory at [mem 0x7d323324-0x7d3234b3]
[ 0.025062] ACPI: Reserving TCPA table memory at [mem 0x7d3352e4-0x7d335347]
[ 0.025063] ACPI: Reserving PC__ table memory at [mem 0x7d335274-0x7d3352e1]
[ 0.025064] ACPI: Reserving SRAT table memory at [mem 0x7d334db0-0x7d33526f]
[ 0.025065] ACPI: Reserving SSDT table memory at [mem 0x7d338000-0x7d33ed83]
[ 0.025077] ACPI: Local APIC address 0xfee00000
[ 0.025112] SRAT: PXM 1 -> APIC 0x00 -> Node 0
[ 0.025113] SRAT: PXM 2 -> APIC 0x20 -> Node 1
[ 0.025114] SRAT: PXM 1 -> APIC 0x02 -> Node 0
[ 0.025115] SRAT: PXM 2 -> APIC 0x22 -> Node 1
[ 0.025116] SRAT: PXM 1 -> APIC 0x04 -> Node 0
[ 0.025117] SRAT: PXM 2 -> APIC 0x24 -> Node 1
[ 0.025117] SRAT: PXM 1 -> APIC 0x06 -> Node 0
[ 0.025118] SRAT: PXM 2 -> APIC 0x26 -> Node 1
[ 0.025119] SRAT: PXM 1 -> APIC 0x08 -> Node 0
[ 0.025120] SRAT: PXM 2 -> APIC 0x28 -> Node 1
[ 0.025121] SRAT: PXM 1 -> APIC 0x0a -> Node 0
[ 0.025121] SRAT: PXM 2 -> APIC 0x2a -> Node 1
[ 0.025122] SRAT: PXM 1 -> APIC 0x01 -> Node 0
[ 0.025123] SRAT: PXM 2 -> APIC 0x21 -> Node 1
[ 0.025124] SRAT: PXM 1 -> APIC 0x03 -> Node 0
[ 0.025125] SRAT: PXM 2 -> APIC 0x23 -> Node 1
[ 0.025125] SRAT: PXM 1 -> APIC 0x05 -> Node 0
[ 0.025126] SRAT: PXM 2 -> APIC 0x25 -> Node 1
[ 0.025127] SRAT: PXM 1 -> APIC 0x07 -> Node 0
[ 0.025128] SRAT: PXM 2 -> APIC 0x27 -> Node 1
[ 0.025129] SRAT: PXM 1 -> APIC 0x09 -> Node 0
[ 0.025129] SRAT: PXM 2 -> APIC 0x29 -> Node 1
[ 0.025130] SRAT: PXM 1 -> APIC 0x0b -> Node 0
[ 0.025131] SRAT: PXM 2 -> APIC 0x2b -> Node 1
[ 0.025136] ACPI: SRAT: Node 0 PXM 1 [mem 0x00000000-0x127fffffff]
[ 0.025137] ACPI: SRAT: Node 1 PXM 2 [mem 0x1280000000-0x247fffffff]
[ 0.025150] NODE_DATA(0) allocated [mem 0x127ffd5000-0x127fffffff]
[ 0.025175] NODE_DATA(1) allocated [mem 0x247ffd5000-0x247fffffff]
[ 0.025505] Zone ranges:
[ 0.025507] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.025508] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.025509] Normal [mem 0x0000000100000000-0x000000247fffffff]
[ 0.025511] Device empty
[ 0.025512] Movable zone start for each node
[ 0.025515] Early memory node ranges
[ 0.025516] node 0: [mem 0x0000000000001000-0x000000000009bfff]
[ 0.025518] node 0: [mem 0x0000000000100000-0x000000007d2effff]
[ 0.025519] node 0: [mem 0x0000000100000000-0x000000127fffffff]
[ 0.025525] node 1: [mem 0x0000001280000000-0x000000247fffffff]
[ 0.025692] Zeroed struct page in unavailable ranges: 11637 pages
[ 0.025693] Initmem setup node 0 [mem 0x0000000000001000-0x000000127fffffff]
[ 0.025695] On node 0 totalpages: 18862731
[ 0.025696] DMA zone: 64 pages used for memmap
[ 0.025697] DMA zone: 21 pages reserved
[ 0.025698] DMA zone: 3995 pages, LIFO batch:0
[ 0.025783] DMA32 zone: 7948 pages used for memmap
[ 0.025784] DMA32 zone: 508656 pages, LIFO batch:63
[ 0.035879] Normal zone: 286720 pages used for memmap
[ 0.035881] Normal zone: 18350080 pages, LIFO batch:63
[ 0.303458] Initmem setup node 1 [mem 0x0000001280000000-0x000000247fffffff]
[ 0.303462] On node 1 totalpages: 18874368
[ 0.303464] Normal zone: 294912 pages used for memmap
[ 0.303465] Normal zone: 18874368 pages, LIFO batch:63
[ 0.617168] ACPI: PM-Timer IO Port: 0x808
[ 0.617176] ACPI: Local APIC address 0xfee00000
[ 0.617189] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.617203] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[ 0.617207] IOAPIC[1]: apic_id 1, version 32, address 0xfec3f000, GSI 32-55
[ 0.617211] IOAPIC[2]: apic_id 2, version 32, address 0xfec7f000, GSI 64-87
[ 0.617214] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.617217] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.617219] ACPI: IRQ0 used by override.
[ 0.617220] ACPI: IRQ9 used by override.
[ 0.617222] Using ACPI (MADT) for SMP configuration information
[ 0.617224] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.617230] ACPI: SPCR: SPCR table version 1
[ 0.617230] ACPI: SPCR: Unexpected SPCR Access Width. Defaulting to byte size
[ 0.617232] ACPI: SPCR: console: uart,mmio,0x0
[ 0.617235] TSC deadline timer available
[ 0.617238] smpboot: Allowing 48 CPUs, 24 hotplug CPUs
[ 0.617254] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.617256] PM: Registered nosave memory: [mem 0x0009c000-0x000fffff]
[ 0.617258] PM: Registered nosave memory: [mem 0x7d2f0000-0x7d31bfff]
[ 0.617259] PM: Registered nosave memory: [mem 0x7d31c000-0x7d35afff]
[ 0.617260] PM: Registered nosave memory: [mem 0x7d35b000-0x7fffffff]
[ 0.617261] PM: Registered nosave memory: [mem 0x80000000-0xdfffffff]
[ 0.617262] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.617262] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.617263] PM: Registered nosave memory: [mem 0xfe000000-0xffffffff]
[ 0.617266] [mem 0x80000000-0xdfffffff] available for PCI devices
[ 0.617268] Booting paravirtualized kernel on bare hardware
[ 0.617272] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.617279] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:48 nr_cpu_ids:48 nr_node_ids:2
[ 0.619648] percpu: Embedded 55 pages/cpu s188416 r8192 d28672 u262144
[ 0.619657] pcpu-alloc: s188416 r8192 d28672 u262144 alloc=1*2097152
[ 0.619658] pcpu-alloc: [0] 00 02 04 06 08 10 12 14 [0] 16 18 20 22 24 26 28 30
[ 0.619663] pcpu-alloc: [0] 32 34 36 38 40 42 44 46 [1] 01 03 05 07 09 11 13 15
[ 0.619666] pcpu-alloc: [1] 17 19 21 23 25 27 29 31 [1] 33 35 37 39 41 43 45 47
[ 0.619706] Built 2 zonelists, mobility grouping on. Total pages: 37147434
[ 0.619707] Policy zone: Normal
[ 0.619710] Kernel command line: BOOT_IMAGE=/vmlinuz-5.4.0-90-generic root=/dev/mapper/ubuntu--vg-ubuntu--lv ro maybe-ubiquity
[ 0.619783] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.619784] printk: log_buf_len total cpu_extra contributions: 192512 bytes
[ 0.619785] printk: log_buf_len min size: 262144 bytes
[ 0.619910] printk: log_buf_len: 524288 bytes
[ 0.619912] printk: early log buf free: 248880(94%)
[ 0.620439] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.629778] Calgary: detecting Calgary via BIOS EBDA area
[ 0.629780] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 1.066158] Memory: 148396296K/150948396K available (14339K kernel code, 2400K rwdata, 5020K rodata, 2736K init, 4964K bss, 2552100K reserved, 0K cma-reserved)
[ 1.066170] random: get_random_u64 called from kmem_cache_open+0x2d/0x410 with crng_init=0
[ 1.066587] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=48, Nodes=2
[ 1.066614] Kernel/User page tables isolation: enabled
[ 1.066651] ftrace: allocating 44628 entries in 175 pages
[ 1.085687] rcu: Hierarchical RCU implementation.
[ 1.085689] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=48.
[ 1.085691] Tasks RCU enabled.
[ 1.085692] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 1.085693] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=48
[ 1.088652] NR_IRQS: 524544, nr_irqs: 1896, preallocated irqs: 16
[ 1.088985] Console: colour dummy device 80x25
[ 1.089213] printk: console [tty0] enabled
[ 1.089278] mempolicy: Enabling automatic NUMA balancing. Configure with numa_balancing= or the kernel.numa_balancing sysctl
[ 1.089283] ACPI: Core revision 20190816
[ 1.089415] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 1.089429] APIC: Switch to symmetric I/O mode setup
[ 1.089433] DMAR: Host address width 46
[ 1.089435] DMAR: DRHD base: 0x000000d3000000 flags: 0x0
[ 1.089441] DMAR: dmar0: reg_base_addr d3000000 ver 1:0 cap d2078c106f0462 ecap f020fe
[ 1.089444] DMAR: DRHD base: 0x000000df100000 flags: 0x1
[ 1.089449] DMAR: dmar1: reg_base_addr df100000 ver 1:0 cap d2078c106f0462 ecap f020fe
[ 1.089452] DMAR: RMRR base: 0x0000007f458000 end: 0x0000007f46ffff
[ 1.089454] DMAR: RMRR base: 0x0000007f450000 end: 0x0000007f450fff
[ 1.089456] DMAR: RMRR base: 0x0000007f452000 end: 0x0000007f452fff
[ 1.089458] DMAR: ATSR flags: 0x0
[ 1.089461] DMAR-IR: IOAPIC id 2 under DRHD base 0xd3000000 IOMMU 0
[ 1.089463] DMAR-IR: IOAPIC id 0 under DRHD base 0xdf100000 IOMMU 1
[ 1.089465] DMAR-IR: IOAPIC id 1 under DRHD base 0xdf100000 IOMMU 1
[ 1.089467] DMAR-IR: HPET id 0 under DRHD base 0xdf100000
[ 1.089469] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[ 1.089470] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[ 1.090013] DMAR-IR: Enabled IRQ remapping in xapic mode
[ 1.090016] x2apic: IRQ remapping doesn't support X2APIC mode
[ 1.090021] Switched APIC routing to physical flat.
[ 1.090642] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 1.109433] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x22992a4c99e, max_idle_ns: 440795250641 ns
[ 1.109439] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.51 BogoMIPS (lpj=9601028)
[ 1.109443] pid_max: default: 49152 minimum: 384
[ 1.109538] LSM: Security Framework initializing
[ 1.109555] Yama: becoming mindful.
[ 1.109760] AppArmor: AppArmor initialized
[ 1.130706] Dentry cache hash table entries: 16777216 (order: 15, 134217728 bytes, vmalloc)
[ 1.141273] Inode-cache hash table entries: 8388608 (order: 14, 67108864 bytes, vmalloc)
[ 1.141681] Mount-cache hash table entries: 262144 (order: 9, 2097152 bytes, vmalloc)
[ 1.142021] Mountpoint-cache hash table entries: 262144 (order: 9, 2097152 bytes, vmalloc)
[ 1.142064] *** VALIDATE tmpfs ***
[ 1.142313] *** VALIDATE proc ***
[ 1.142450] *** VALIDATE cgroup1 ***
[ 1.142453] *** VALIDATE cgroup2 ***
[ 1.142546] mce: CPU0: Thermal monitoring enabled (TM1)
[ 1.142579] process: using mwait in idle threads
[ 1.142583] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[ 1.142585] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 1.142592] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 1.142595] Spectre V2 : Mitigation: Full generic retpoline
[ 1.142597] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 1.142600] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 1.142603] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 1.142605] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 1.142608] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 1.142614] MDS: Mitigation: Clear CPU buffers
[ 1.142815] Freeing SMP alternatives memory: 40K
[ 1.145614] smpboot: CPU0: Intel(R) Xeon(R) CPU E5-2440 0 @ 2.40GHz (family: 0x6, model: 0x2d, stepping: 0x7)
[ 1.145808] Performance Events: PEBS fmt1+, SandyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 1.145821] ... version: 3
[ 1.145822] ... bit width: 48
[ 1.145824] ... generic registers: 4
[ 1.145826] ... value mask: 0000ffffffffffff
[ 1.145828] ... max period: 00007fffffffffff
[ 1.145830] ... fixed-purpose events: 3
[ 1.145831] ... event mask: 000000070000000f
[ 1.145903] rcu: Hierarchical SRCU implementation.
[ 1.149437] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 1.150122] smp: Bringing up secondary CPUs ...
[ 1.150288] x86: Booting SMP configuration:
[ 1.150291] .... node #1, CPUs: #1
[ 0.004550] smpboot: CPU 1 Converting physical 0 to logical die 1
[ 1.233598] .... node #0, CPUs: #2
[ 1.237686] .... node #1, CPUs: #3
[ 1.241627] .... node #0, CPUs: #4
[ 1.245683] .... node #1, CPUs: #5
[ 1.249580] .... node #0, CPUs: #6
[ 1.253650] .... node #1, CPUs: #7
[ 1.257611] .... node #0, CPUs: #8
[ 1.261683] .... node #1, CPUs: #9
[ 1.265539] .... node #0, CPUs: #10
[ 1.269604] .... node #1, CPUs: #11
[ 1.273439] .... node #0, CPUs: #12
[ 1.276347] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 1.276347] .... node #1, CPUs: #13
[ 1.277615] .... node #0, CPUs: #14
[ 1.280360] .... node #1, CPUs: #15
[ 1.283482] .... node #0, CPUs: #16
[ 1.285687] .... node #1, CPUs: #17
[ 1.288355] .... node #0, CPUs: #18
[ 1.291541] .... node #1, CPUs: #19
[ 1.293617] .... node #0, CPUs: #20
[ 1.296346] .... node #1, CPUs: #21
[ 1.297609] .... node #0, CPUs: #22
[ 1.300332] .... node #1, CPUs: #23
[ 1.303491] smp: Brought up 2 nodes, 24 CPUs
[ 1.303491] smpboot: Max logical packages: 4
[ 1.303491] smpboot: Total of 24 processors activated (115229.62 BogoMIPS)
[ 1.312447] devtmpfs: initialized
[ 1.312447] x86/mm: Memory block size: 2048MB
[ 1.313538] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 1.313699] futex hash table entries: 16384 (order: 8, 1048576 bytes, vmalloc)
[ 1.313943] pinctrl core: initialized pinctrl subsystem
[ 1.314090] PM: RTC time: 15:03:34, date: 2021-11-18
[ 1.314312] NET: Registered protocol family 16
[ 1.314423] audit: initializing netlink subsys (disabled)
[ 1.314433] audit: type=2000 audit(1637247813.224:1): state=initialized audit_enabled=0 res=1
[ 1.314433] EISA bus registered
[ 1.314433] cpuidle: using governor ladder
[ 1.314433] cpuidle: using governor menu
[ 1.314433] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 1.314433] ACPI: bus type PCI registered
[ 1.314433] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.314433] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 1.314433] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 1.314433] PCI: Using configuration type 1 for base access
[ 1.314433] PCI: Dell System detected, enabling pci=bfsort.
[ 1.314433] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 1.314471] mtrr: your CPUs had inconsistent variable MTRR settings
[ 1.314473] mtrr: probably your BIOS does not setup all CPUs.
[ 1.314475] mtrr: corrected configuration.
[ 1.317496] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.317496] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.317565] fbcon: Taking over console
[ 1.317638] ACPI: Added _OSI(Module Device)
[ 1.317640] ACPI: Added _OSI(Processor Device)
[ 1.317642] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 1.317644] ACPI: Added _OSI(Processor Aggregator Device)
[ 1.317647] ACPI: Added _OSI(Linux-Dell-Video)
[ 1.317649] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 1.317651] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 1.320674] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 1.321133] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 1.331027] ACPI: Interpreter enabled
[ 1.331046] ACPI: (supports S0 S4 S5)
[ 1.331049] ACPI: Using IOAPIC for interrupt routing
[ 1.331325] HEST: Table parsing has been initialized.
[ 1.331331] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 1.331572] ACPI: Enabled 4 GPEs in block 00 to 3F
[ 1.340195] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3d])
[ 1.340205] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 1.340371] acpi PNP0A08:00: PCIe AER handled by firmware
[ 1.340697] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR]
[ 1.340701] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 1.341868] PCI host bridge to bus 0000:00
[ 1.341873] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 1.341876] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 1.341878] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 1.341881] pci_bus 0000:00: root bus resource [io 0x0d00-0x1fff window]
[ 1.341883] pci_bus 0000:00: root bus resource [io 0xe000-0xffff window]
[ 1.341886] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 1.341889] pci_bus 0000:00: root bus resource [mem 0xd8000000-0xdfffffff window]
[ 1.341892] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff window]
[ 1.341896] pci_bus 0000:00: root bus resource [bus 00-3d]
[ 1.341948] pci 0000:00:00.0: [8086:3c00] type 00 class 0x060000
[ 1.342030] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 1.342123] pci 0000:00:01.0: [8086:3c02] type 01 class 0x060400
[ 1.342216] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 1.342370] pci 0000:00:03.0: [8086:3c08] type 01 class 0x060400
[ 1.342416] pci 0000:00:03.0: enabling Extended Tags
[ 1.342469] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 1.342632] pci 0000:00:05.0: [8086:3c28] type 00 class 0x088000
[ 1.342777] pci 0000:00:05.2: [8086:3c2a] type 00 class 0x088000
[ 1.342911] pci 0000:00:11.0: [8086:1d3e] type 01 class 0x060400
[ 1.343020] pci 0000:00:11.0: PME# supported from D0 D3hot D3cold
[ 1.343114] pci 0000:00:16.0: [8086:1d3a] type 00 class 0x078000
[ 1.343136] pci 0000:00:16.0: reg 0x10: [mem 0xdf0fb000-0xdf0fb00f 64bit]
[ 1.343199] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 1.343283] pci 0000:00:16.1: [8086:1d3b] type 00 class 0x078000
[ 1.343305] pci 0000:00:16.1: reg 0x10: [mem 0xdf0fc000-0xdf0fc00f 64bit]
[ 1.343366] pci 0000:00:16.1: PME# supported from D0 D3hot D3cold
[ 1.343459] pci 0000:00:1a.0: [8086:1d2d] type 00 class 0x0c0320
[ 1.343482] pci 0000:00:1a.0: reg 0x10: [mem 0xdf0fd000-0xdf0fd3ff]
[ 1.343564] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 1.343656] pci 0000:00:1c.0: [8086:1d10] type 01 class 0x060400
[ 1.343746] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 1.343927] pci 0000:00:1c.4: [8086:1d18] type 01 class 0x060400
[ 1.344019] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 1.344124] pci 0000:00:1c.7: [8086:1d1e] type 01 class 0x060400
[ 1.344216] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[ 1.344324] pci 0000:00:1d.0: [8086:1d26] type 00 class 0x0c0320
[ 1.344347] pci 0000:00:1d.0: reg 0x10: [mem 0xdf0fe000-0xdf0fe3ff]
[ 1.344430] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 1.344517] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 1.344634] pci 0000:00:1f.0: [8086:1d41] type 00 class 0x060100
[ 1.344816] pci 0000:00:1f.2: [8086:1d02] type 00 class 0x010601
[ 1.344835] pci 0000:00:1f.2: reg 0x10: [io 0xece8-0xecef]
[ 1.344843] pci 0000:00:1f.2: reg 0x14: [io 0xecf8-0xecfb]
[ 1.344851] pci 0000:00:1f.2: reg 0x18: [io 0xecf0-0xecf7]
[ 1.344859] pci 0000:00:1f.2: reg 0x1c: [io 0xecfc-0xecff]
[ 1.344867] pci 0000:00:1f.2: reg 0x20: [io 0xecc0-0xecdf]
[ 1.344875] pci 0000:00:1f.2: reg 0x24: [mem 0xdf0ff000-0xdf0ff7ff]
[ 1.344916] pci 0000:00:1f.2: PME# supported from D3hot
[ 1.345025] pci 0000:01:00.0: [1000:005b] type 00 class 0x010400
[ 1.345040] pci 0000:01:00.0: reg 0x10: [io 0xfc00-0xfcff]
[ 1.345049] pci 0000:01:00.0: reg 0x14: [mem 0xdcffc000-0xdcffffff 64bit]
[ 1.345058] pci 0000:01:00.0: reg 0x1c: [mem 0xdcf80000-0xdcfbffff 64bit]
[ 1.345069] pci 0000:01:00.0: reg 0x30: [mem 0xdc000000-0xdc01ffff pref]
[ 1.345076] pci 0000:01:00.0: enabling Extended Tags
[ 1.345118] pci 0000:01:00.0: supports D1 D2
[ 1.345172] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.345177] pci 0000:00:01.0: bridge window [io 0xf000-0xffff]
[ 1.345181] pci 0000:00:01.0: bridge window [mem 0xdc000000-0xdcffffff]
[ 1.345221] pci 0000:00:03.0: PCI bridge to [bus 08]
[ 1.345270] pci 0000:00:11.0: PCI bridge to [bus 09]
[ 1.345318] pci 0000:00:1c.0: PCI bridge to [bus 0a]
[ 1.345406] pci 0000:02:00.0: [14e4:165f] type 00 class 0x020000
[ 1.345450] pci 0000:02:00.0: reg 0x10: [mem 0xd90a0000-0xd90affff 64bit pref]
[ 1.345472] pci 0000:02:00.0: reg 0x18: [mem 0xd90b0000-0xd90bffff 64bit pref]
[ 1.345494] pci 0000:02:00.0: reg 0x20: [mem 0xd90c0000-0xd90cffff 64bit pref]
[ 1.345509] pci 0000:02:00.0: reg 0x30: [mem 0xdd000000-0xdd03ffff pref]
[ 1.345631] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 1.345670] pci 0000:02:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5 GT/s x1 link at 0000:00:1c.4 (capable of 8.000 Gb/s with 5 GT/s x2 link)
[ 1.345775] pci 0000:02:00.1: [14e4:165f] type 00 class 0x020000
[ 1.345819] pci 0000:02:00.1: reg 0x10: [mem 0xd90d0000-0xd90dffff 64bit pref]
[ 1.345841] pci 0000:02:00.1: reg 0x18: [mem 0xd90e0000-0xd90effff 64bit pref]
[ 1.345863] pci 0000:02:00.1: reg 0x20: [mem 0xd90f0000-0xd90fffff 64bit pref]
[ 1.345878] pci 0000:02:00.1: reg 0x30: [mem 0xdd000000-0xdd03ffff pref]
[ 1.345999] pci 0000:02:00.1: PME# supported from D0 D3hot D3cold
[ 1.346161] pci 0000:00:1c.4: PCI bridge to [bus 02]
[ 1.346169] pci 0000:00:1c.4: bridge window [mem 0xdd000000-0xdd7fffff]
[ 1.346175] pci 0000:00:1c.4: bridge window [mem 0xd9000000-0xd90fffff 64bit pref]
[ 1.346522] pci 0000:03:00.0: [1912:0013] type 01 class 0x060400
[ 1.353845] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 1.354957] pci 0000:00:1c.7: PCI bridge to [bus 03-07]
[ 1.354964] pci 0000:00:1c.7: bridge window [mem 0xdd800000-0xdeffffff]
[ 1.354971] pci 0000:00:1c.7: bridge window [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.356136] pci 0000:04:00.0: [1912:0013] type 01 class 0x060400
[ 1.359594] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[ 1.360775] pci 0000:04:01.0: [1912:0013] type 01 class 0x060400
[ 1.364451] pci 0000:04:01.0: PME# supported from D0 D3hot D3cold
[ 1.366986] pci 0000:03:00.0: PCI bridge to [bus 04-07]
[ 1.367179] pci 0000:03:00.0: bridge window [mem 0xdd800000-0xdeffffff]
[ 1.367303] pci 0000:03:00.0: bridge window [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.368518] pci 0000:05:00.0: [1912:0012] type 01 class 0x060400
[ 1.372993] pci 0000:04:00.0: PCI bridge to [bus 05-06]
[ 1.373208] pci 0000:04:00.0: bridge window [mem 0xdd800000-0xde7fffff]
[ 1.373353] pci 0000:04:00.0: bridge window [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.374388] pci_bus 0000:06: extended config space not accessible
[ 1.374619] pci 0000:06:00.0: [102b:0534] type 00 class 0x030000
[ 1.375103] pci 0000:06:00.0: reg 0x10: [mem 0xd8000000-0xd8ffffff pref]
[ 1.375363] pci 0000:06:00.0: reg 0x14: [mem 0xde7fc000-0xde7fffff]
[ 1.375624] pci 0000:06:00.0: reg 0x18: [mem 0xdd800000-0xddffffff]
[ 1.379812] pci 0000:05:00.0: PCI bridge to [bus 06]
[ 1.380035] pci 0000:05:00.0: bridge window [mem 0xdd800000-0xde7fffff]
[ 1.380180] pci 0000:05:00.0: bridge window [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.381419] pci 0000:04:01.0: PCI bridge to [bus 07]
[ 1.381618] pci 0000:04:01.0: bridge window [mem 0xdef00000-0xdeffffff]
[ 1.382746] pci_bus 0000:0b: extended config space not accessible
[ 1.382796] pci 0000:00:1e.0: PCI bridge to [bus 0b] (subtractive decode)
[ 1.382807] pci 0000:00:1e.0: bridge window [io 0x0000-0x03af window] (subtractive decode)
[ 1.382810] pci 0000:00:1e.0: bridge window [io 0x03e0-0x0cf7 window] (subtractive decode)
[ 1.382813] pci 0000:00:1e.0: bridge window [io 0x03b0-0x03df window] (subtractive decode)
[ 1.382817] pci 0000:00:1e.0: bridge window [io 0x0d00-0x1fff window] (subtractive decode)
[ 1.382820] pci 0000:00:1e.0: bridge window [io 0xe000-0xffff window] (subtractive decode)
[ 1.382823] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 1.382826] pci 0000:00:1e.0: bridge window [mem 0xd8000000-0xdfffffff window] (subtractive decode)
[ 1.382830] pci 0000:00:1e.0: bridge window [mem 0xfed40000-0xfed44fff window] (subtractive decode)
[ 1.382870] pci_bus 0000:00: on NUMA node 0
[ 1.384650] ACPI: PCI Root Bridge [PCI1] (domain 0000 [bus 40-7e])
[ 1.384657] acpi PNP0A08:01: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 1.384822] acpi PNP0A08:01: PCIe AER handled by firmware
[ 1.385147] acpi PNP0A08:01: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR]
[ 1.385151] acpi PNP0A08:01: FADT indicates ASPM is unsupported, using BIOS configuration
[ 1.386234] PCI host bridge to bus 0000:40
[ 1.386238] pci_bus 0000:40: root bus resource [io 0x2000-0x3fff window]
[ 1.386241] pci_bus 0000:40: root bus resource [io 0x4000-0x5fff window]
[ 1.386243] pci_bus 0000:40: root bus resource [io 0x6000-0x7fff window]
[ 1.386246] pci_bus 0000:40: root bus resource [io 0x8000-0x9fff window]
[ 1.386249] pci_bus 0000:40: root bus resource [io 0xa000-0xbfff window]
[ 1.386251] pci_bus 0000:40: root bus resource [io 0xc000-0xdfff window]
[ 1.386254] pci_bus 0000:40: root bus resource [mem 0xd0000000-0xd7ffffff window]
[ 1.386257] pci_bus 0000:40: root bus resource [bus 40-7e]
[ 1.386310] pci 0000:40:03.0: [8086:3c08] type 01 class 0x060400
[ 1.386359] pci 0000:40:03.0: enabling Extended Tags
[ 1.386417] pci 0000:40:03.0: PME# supported from D0 D3hot D3cold
[ 1.386555] pci 0000:40:05.0: [8086:3c28] type 00 class 0x088000
[ 1.386684] pci 0000:40:05.2: [8086:3c2a] type 00 class 0x088000
[ 1.386837] pci 0000:40:03.0: PCI bridge to [bus 41]
[ 1.386854] pci_bus 0000:40: on NUMA node 1
[ 1.386924] ACPI: PCI Root Bridge [P0B1] (domain 0000 [bus 3f])
[ 1.386930] acpi PNP0A08:02: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 1.387094] acpi PNP0A08:02: PCIe AER handled by firmware
[ 1.387419] acpi PNP0A08:02: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR]
[ 1.387422] acpi PNP0A08:02: FADT indicates ASPM is unsupported, using BIOS configuration
[ 1.387511] PCI host bridge to bus 0000:3f
[ 1.387514] pci_bus 0000:3f: root bus resource [bus 3f]
[ 1.387525] pci 0000:3f:08.0: [8086:3c80] type 00 class 0x088000
[ 1.387595] pci 0000:3f:09.0: [8086:3c90] type 00 class 0x088000
[ 1.387653] pci 0000:3f:0a.0: [8086:3cc0] type 00 class 0x088000
[ 1.387703] pci 0000:3f:0a.1: [8086:3cc1] type 00 class 0x088000
[ 1.387752] pci 0000:3f:0a.2: [8086:3cc2] type 00 class 0x088000
[ 1.387802] pci 0000:3f:0a.3: [8086:3cd0] type 00 class 0x088000
[ 1.387852] pci 0000:3f:0b.0: [8086:3ce0] type 00 class 0x088000
[ 1.387900] pci 0000:3f:0b.3: [8086:3ce3] type 00 class 0x088000
[ 1.387968] pci 0000:3f:0c.0: [8086:3ce8] type 00 class 0x088000
[ 1.388023] pci 0000:3f:0c.1: [8086:3ce8] type 00 class 0x088000
[ 1.388071] pci 0000:3f:0c.2: [8086:3ce8] type 00 class 0x088000
[ 1.388121] pci 0000:3f:0c.6: [8086:3cf4] type 00 class 0x088000
[ 1.388169] pci 0000:3f:0c.7: [8086:3cf6] type 00 class 0x088000
[ 1.388216] pci 0000:3f:0d.0: [8086:3ce8] type 00 class 0x088000
[ 1.388264] pci 0000:3f:0d.1: [8086:3ce8] type 00 class 0x088000
[ 1.388314] pci 0000:3f:0d.2: [8086:3ce8] type 00 class 0x088000
[ 1.388363] pci 0000:3f:0d.6: [8086:3cf5] type 00 class 0x088000
[ 1.388419] pci 0000:3f:0e.0: [8086:3ca0] type 00 class 0x088000
[ 1.388471] pci 0000:3f:0e.1: [8086:3c46] type 00 class 0x110100
[ 1.388527] pci 0000:3f:0f.0: [8086:3ca8] type 00 class 0x088000
[ 1.388596] pci 0000:3f:0f.1: [8086:3c71] type 00 class 0x088000
[ 1.388661] pci 0000:3f:0f.2: [8086:3caa] type 00 class 0x088000
[ 1.388728] pci 0000:3f:0f.3: [8086:3cab] type 00 class 0x088000
[ 1.388795] pci 0000:3f:0f.4: [8086:3cac] type 00 class 0x088000
[ 1.388861] pci 0000:3f:0f.5: [8086:3cad] type 00 class 0x088000
[ 1.388934] pci 0000:3f:0f.6: [8086:3cae] type 00 class 0x088000
[ 1.388990] pci 0000:3f:10.0: [8086:3cb0] type 00 class 0x088000
[ 1.389057] pci 0000:3f:10.1: [8086:3cb1] type 00 class 0x088000
[ 1.389124] pci 0000:3f:10.2: [8086:3cb2] type 00 class 0x088000
[ 1.389190] pci 0000:3f:10.3: [8086:3cb3] type 00 class 0x088000
[ 1.389256] pci 0000:3f:10.5: [8086:3cb5] type 00 class 0x088000
[ 1.389323] pci 0000:3f:10.6: [8086:3cb6] type 00 class 0x088000
[ 1.389388] pci 0000:3f:10.7: [8086:3cb7] type 00 class 0x088000
[ 1.389463] pci 0000:3f:11.0: [8086:3cb8] type 00 class 0x088000
[ 1.389523] pci 0000:3f:13.0: [8086:3ce4] type 00 class 0x088000
[ 1.389572] pci 0000:3f:13.1: [8086:3c43] type 00 class 0x110100
[ 1.389622] pci 0000:3f:13.4: [8086:3ce6] type 00 class 0x110100
[ 1.389670] pci 0000:3f:13.5: [8086:3c44] type 00 class 0x110100
[ 1.389720] pci 0000:3f:13.6: [8086:3c45] type 00 class 0x088000
[ 1.389782] pci_bus 0000:3f: on NUMA node 0
[ 1.389871] ACPI: PCI Root Bridge [P1B1] (domain 0000 [bus 7f])
[ 1.389877] acpi PNP0A08:03: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 1.390042] acpi PNP0A08:03: PCIe AER handled by firmware
[ 1.390368] acpi PNP0A08:03: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR]
[ 1.390372] acpi PNP0A08:03: FADT indicates ASPM is unsupported, using BIOS configuration
[ 1.390424] PCI host bridge to bus 0000:7f
[ 1.390428] pci_bus 0000:7f: root bus resource [bus 7f]
[ 1.390440] pci 0000:7f:08.0: [8086:3c80] type 00 class 0x088000
[ 1.390497] pci 0000:7f:09.0: [8086:3c90] type 00 class 0x088000
[ 1.390559] pci 0000:7f:0a.0: [8086:3cc0] type 00 class 0x088000
[ 1.390606] pci 0000:7f:0a.1: [8086:3cc1] type 00 class 0x088000
[ 1.390653] pci 0000:7f:0a.2: [8086:3cc2] type 00 class 0x088000
[ 1.390701] pci 0000:7f:0a.3: [8086:3cd0] type 00 class 0x088000
[ 1.390749] pci 0000:7f:0b.0: [8086:3ce0] type 00 class 0x088000
[ 1.390794] pci 0000:7f:0b.3: [8086:3ce3] type 00 class 0x088000
[ 1.390840] pci 0000:7f:0c.0: [8086:3ce8] type 00 class 0x088000
[ 1.390889] pci 0000:7f:0c.1: [8086:3ce8] type 00 class 0x088000
[ 1.390941] pci 0000:7f:0c.2: [8086:3ce8] type 00 class 0x088000
[ 1.390987] pci 0000:7f:0c.6: [8086:3cf4] type 00 class 0x088000
[ 1.391032] pci 0000:7f:0c.7: [8086:3cf6] type 00 class 0x088000
[ 1.391079] pci 0000:7f:0d.0: [8086:3ce8] type 00 class 0x088000
[ 1.391124] pci 0000:7f:0d.1: [8086:3ce8] type 00 class 0x088000
[ 1.391169] pci 0000:7f:0d.2: [8086:3ce8] type 00 class 0x088000
[ 1.391215] pci 0000:7f:0d.6: [8086:3cf5] type 00 class 0x088000
[ 1.391261] pci 0000:7f:0e.0: [8086:3ca0] type 00 class 0x088000
[ 1.391318] pci 0000:7f:0e.1: [8086:3c46] type 00 class 0x110100
[ 1.391372] pci 0000:7f:0f.0: [8086:3ca8] type 00 class 0x088000
[ 1.391437] pci 0000:7f:0f.1: [8086:3c71] type 00 class 0x088000
[ 1.391503] pci 0000:7f:0f.2: [8086:3caa] type 00 class 0x088000
[ 1.391571] pci 0000:7f:0f.3: [8086:3cab] type 00 class 0x088000
[ 1.391636] pci 0000:7f:0f.4: [8086:3cac] type 00 class 0x088000
[ 1.391701] pci 0000:7f:0f.5: [8086:3cad] type 00 class 0x088000
[ 1.391765] pci 0000:7f:0f.6: [8086:3cae] type 00 class 0x088000
[ 1.391824] pci 0000:7f:10.0: [8086:3cb0] type 00 class 0x088000
[ 1.391891] pci 0000:7f:10.1: [8086:3cb1] type 00 class 0x088000
[ 1.391956] pci 0000:7f:10.2: [8086:3cb2] type 00 class 0x088000
[ 1.392023] pci 0000:7f:10.3: [8086:3cb3] type 00 class 0x088000
[ 1.392090] pci 0000:7f:10.5: [8086:3cb5] type 00 class 0x088000
[ 1.392156] pci 0000:7f:10.6: [8086:3cb6] type 00 class 0x088000
[ 1.392222] pci 0000:7f:10.7: [8086:3cb7] type 00 class 0x088000
[ 1.392285] pci 0000:7f:11.0: [8086:3cb8] type 00 class 0x088000
[ 1.392347] pci 0000:7f:13.0: [8086:3ce4] type 00 class 0x088000
[ 1.392393] pci 0000:7f:13.1: [8086:3c43] type 00 class 0x110100
[ 1.392442] pci 0000:7f:13.4: [8086:3ce6] type 00 class 0x110100
[ 1.392488] pci 0000:7f:13.5: [8086:3c44] type 00 class 0x110100
[ 1.392533] pci 0000:7f:13.6: [8086:3c45] type 00 class 0x088000
[ 1.392586] pci_bus 0000:7f: on NUMA node 1
[ 1.392809] ACPI: PCI Interrupt Link [LK00] (IRQs 3 4 5 6 7 11 14 *15)
[ 1.392915] ACPI: PCI Interrupt Link [LK01] (IRQs 3 4 5 6 7 11 *14 15)
[ 1.393021] ACPI: PCI Interrupt Link [LK02] (IRQs 3 4 5 6 7 11 14 15) *0, disabled.
[ 1.393124] ACPI: PCI Interrupt Link [LK03] (IRQs 3 4 5 6 7 *11 14 15)
[ 1.393227] ACPI: PCI Interrupt Link [LK04] (IRQs 3 4 *5 6 7 11 14 15)
[ 1.393331] ACPI: PCI Interrupt Link [LK05] (IRQs 3 4 5 6 7 11 14 15) *0, disabled.
[ 1.393434] ACPI: PCI Interrupt Link [LK06] (IRQs 3 4 5 *6 7 11 14 15)
[ 1.393544] ACPI: PCI Interrupt Link [LK07] (IRQs 3 4 5 6 7 11 *14 15)
[ 1.393702] iommu: Default domain type: Translated
[ 1.393719] SCSI subsystem initialized
[ 1.393741] libata version 3.00 loaded.
[ 1.393741] pci 0000:06:00.0: vgaarb: setting as boot VGA device
[ 1.393741] pci 0000:06:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 1.393741] pci 0000:06:00.0: vgaarb: bridge control possible
[ 1.393741] vgaarb: loaded
[ 1.393741] ACPI: bus type USB registered
[ 1.393741] usbcore: registered new interface driver usbfs
[ 1.393741] usbcore: registered new interface driver hub
[ 1.393741] usbcore: registered new device driver usb
[ 1.393741] pps_core: LinuxPPS API ver. 1 registered
[ 1.393741] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.393746] PTP clock support registered
[ 1.393777] EDAC MC: Ver: 3.0.0
[ 1.394152] PCI: Using ACPI for IRQ routing
[ 1.396756] PCI: pci_cache_line_size set to 64 bytes
[ 1.397226] e820: reserve RAM buffer [mem 0x0009c000-0x0009ffff]
[ 1.397229] e820: reserve RAM buffer [mem 0x7d2f0000-0x7fffffff]
[ 1.397486] NetLabel: Initializing
[ 1.397489] NetLabel: domain hash size = 128
[ 1.397491] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 1.397511] NetLabel: unlabeled traffic allowed by default
[ 1.402389] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 1.402398] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 1.404473] clocksource: Switched to clocksource tsc-early
[ 1.416610] *** VALIDATE bpf ***
[ 1.416775] VFS: Disk quotas dquot_6.6.0
[ 1.416823] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.416859] *** VALIDATE ramfs ***
[ 1.416874] *** VALIDATE hugetlbfs ***
[ 1.417010] AppArmor: AppArmor Filesystem Enabled
[ 1.417051] pnp: PnP ACPI init
[ 1.417294] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.417347] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 1.417642] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[ 1.417907] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[ 1.418357] system 00:04: [io 0x0800-0x087f] has been reserved
[ 1.418361] system 00:04: [io 0x0880-0x08ff] has been reserved
[ 1.418364] system 00:04: [io 0x0900-0x091f] has been reserved
[ 1.418366] system 00:04: [io 0x0920-0x0923] has been reserved
[ 1.418369] system 00:04: [io 0x0924] has been reserved
[ 1.418372] system 00:04: [io 0x0370-0x0377] has been reserved
[ 1.418375] system 00:04: [io 0x0ca0-0x0ca7] has been reserved
[ 1.418377] system 00:04: [io 0x0ca9-0x0cab] has been reserved
[ 1.418380] system 00:04: [io 0x0cad-0x0caf] has been reserved
[ 1.418383] system 00:04: [io 0x0cb0-0x0cbf] has been reserved
[ 1.418388] system 00:04: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.418491] system 00:05: [io 0x0ca8] has been reserved
[ 1.418495] system 00:05: [io 0x0cac] has been reserved
[ 1.418501] system 00:05: Plug and Play ACPI device, IDs IPI0001 PNP0c01 (active)
[ 1.418981] system 00:06: [mem 0xe0000000-0xe3efffff] has been reserved
[ 1.418988] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.419214] system 00:07: [mem 0xe4000000-0xe7ffffff] has been reserved
[ 1.419221] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.419316] system 00:08: [mem 0xe3f00000-0xe3ffffff] has been reserved
[ 1.419322] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.419432] system 00:09: [mem 0xdf100000-0xdf101fff] could not be reserved
[ 1.419439] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.419577] system 00:0a: [mem 0xd3000000-0xd3001fff] could not be reserved
[ 1.419584] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.419843] pnp: PnP ACPI: found 11 devices
[ 1.421287] thermal_sys: Registered thermal governor 'fair_share'
[ 1.421288] thermal_sys: Registered thermal governor 'bang_bang'
[ 1.421291] thermal_sys: Registered thermal governor 'step_wise'
[ 1.421293] thermal_sys: Registered thermal governor 'user_space'
[ 1.421296] thermal_sys: Registered thermal governor 'power_allocator'
[ 1.425788] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.425830] pci 0000:02:00.1: can't claim BAR 6 [mem 0xdd000000-0xdd03ffff pref]: address conflict with 0000:02:00.0 [mem 0xdd000000-0xdd03ffff pref]
[ 1.425847] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.425851] pci 0000:00:01.0: bridge window [io 0xf000-0xffff]
[ 1.425857] pci 0000:00:01.0: bridge window [mem 0xdc000000-0xdcffffff]
[ 1.425865] pci 0000:00:03.0: PCI bridge to [bus 08]
[ 1.425874] pci 0000:00:11.0: PCI bridge to [bus 09]
[ 1.425887] pci 0000:00:1c.0: PCI bridge to [bus 0a]
[ 1.425902] pci 0000:02:00.1: BAR 6: assigned [mem 0xdd040000-0xdd07ffff pref]
[ 1.425906] pci 0000:00:1c.4: PCI bridge to [bus 02]
[ 1.425911] pci 0000:00:1c.4: bridge window [mem 0xdd000000-0xdd7fffff]
[ 1.425916] pci 0000:00:1c.4: bridge window [mem 0xd9000000-0xd90fffff 64bit pref]
[ 1.425924] pci 0000:05:00.0: PCI bridge to [bus 06]
[ 1.426066] pci 0000:05:00.0: bridge window [mem 0xdd800000-0xde7fffff]
[ 1.426160] pci 0000:05:00.0: bridge window [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.426355] pci 0000:04:00.0: PCI bridge to [bus 05-06]
[ 1.426498] pci 0000:04:00.0: bridge window [mem 0xdd800000-0xde7fffff]
[ 1.426592] pci 0000:04:00.0: bridge window [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.426786] pci 0000:04:01.0: PCI bridge to [bus 07]
[ 1.426930] pci 0000:04:01.0: bridge window [mem 0xdef00000-0xdeffffff]
[ 1.427280] pci 0000:03:00.0: PCI bridge to [bus 04-07]
[ 1.427410] pci 0000:03:00.0: bridge window [mem 0xdd800000-0xdeffffff]
[ 1.427495] pci 0000:03:00.0: bridge window [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.427734] pci 0000:00:1c.7: PCI bridge to [bus 03-07]
[ 1.427739] pci 0000:00:1c.7: bridge window [mem 0xdd800000-0xdeffffff]
[ 1.427744] pci 0000:00:1c.7: bridge window [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.427751] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1.427762] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 1.427764] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 1.427767] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 1.427769] pci_bus 0000:00: resource 7 [io 0x0d00-0x1fff window]
[ 1.427772] pci_bus 0000:00: resource 8 [io 0xe000-0xffff window]
[ 1.427775] pci_bus 0000:00: resource 9 [mem 0x000a0000-0x000bffff window]
[ 1.427778] pci_bus 0000:00: resource 10 [mem 0xd8000000-0xdfffffff window]
[ 1.427780] pci_bus 0000:00: resource 11 [mem 0xfed40000-0xfed44fff window]
[ 1.427783] pci_bus 0000:01: resource 0 [io 0xf000-0xffff]
[ 1.427785] pci_bus 0000:01: resource 1 [mem 0xdc000000-0xdcffffff]
[ 1.427788] pci_bus 0000:02: resource 1 [mem 0xdd000000-0xdd7fffff]
[ 1.427791] pci_bus 0000:02: resource 2 [mem 0xd9000000-0xd90fffff 64bit pref]
[ 1.427794] pci_bus 0000:03: resource 1 [mem 0xdd800000-0xdeffffff]
[ 1.427796] pci_bus 0000:03: resource 2 [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.427799] pci_bus 0000:04: resource 1 [mem 0xdd800000-0xdeffffff]
[ 1.427802] pci_bus 0000:04: resource 2 [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.427805] pci_bus 0000:05: resource 1 [mem 0xdd800000-0xde7fffff]
[ 1.427807] pci_bus 0000:05: resource 2 [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.427811] pci_bus 0000:06: resource 1 [mem 0xdd800000-0xde7fffff]
[ 1.427813] pci_bus 0000:06: resource 2 [mem 0xd8000000-0xd8ffffff 64bit pref]
[ 1.427816] pci_bus 0000:07: resource 1 [mem 0xdef00000-0xdeffffff]
[ 1.427819] pci_bus 0000:0b: resource 4 [io 0x0000-0x03af window]
[ 1.427822] pci_bus 0000:0b: resource 5 [io 0x03e0-0x0cf7 window]
[ 1.427824] pci_bus 0000:0b: resource 6 [io 0x03b0-0x03df window]
[ 1.427827] pci_bus 0000:0b: resource 7 [io 0x0d00-0x1fff window]
[ 1.427829] pci_bus 0000:0b: resource 8 [io 0xe000-0xffff window]
[ 1.427832] pci_bus 0000:0b: resource 9 [mem 0x000a0000-0x000bffff window]
[ 1.427834] pci_bus 0000:0b: resource 10 [mem 0xd8000000-0xdfffffff window]
[ 1.427837] pci_bus 0000:0b: resource 11 [mem 0xfed40000-0xfed44fff window]
[ 1.427868] pci 0000:40:03.0: PCI bridge to [bus 41]
[ 1.427879] pci_bus 0000:40: resource 4 [io 0x2000-0x3fff window]
[ 1.427882] pci_bus 0000:40: resource 5 [io 0x4000-0x5fff window]
[ 1.427884] pci_bus 0000:40: resource 6 [io 0x6000-0x7fff window]
[ 1.427887] pci_bus 0000:40: resource 7 [io 0x8000-0x9fff window]
[ 1.427889] pci_bus 0000:40: resource 8 [io 0xa000-0xbfff window]
[ 1.427892] pci_bus 0000:40: resource 9 [io 0xc000-0xdfff window]
[ 1.427894] pci_bus 0000:40: resource 10 [mem 0xd0000000-0xd7ffffff window]
[ 1.427979] NET: Registered protocol family 2
[ 1.428488] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, vmalloc)
[ 1.431180] tcp_listen_portaddr_hash hash table entries: 65536 (order: 8, 1048576 bytes, vmalloc)
[ 1.432286] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, vmalloc)
[ 1.433174] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, vmalloc)
[ 1.433276] TCP: Hash tables configured (established 524288 bind 65536)
[ 1.433857] UDP hash table entries: 65536 (order: 9, 2097152 bytes, vmalloc)
[ 1.434595] UDP-Lite hash table entries: 65536 (order: 9, 2097152 bytes, vmalloc)
[ 1.435013] NET: Registered protocol family 1
[ 1.435021] NET: Registered protocol family 44
[ 1.435040] pci 0000:00:05.0: disabled boot interrupts on device [8086:3c28]
[ 1.453679] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x670 took 18180 usecs
[ 1.454142] pci 0000:01:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
[ 1.454508] pci 0000:06:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 1.454608] pci 0000:40:05.0: disabled boot interrupts on device [8086:3c28]
[ 1.454673] PCI: CLS 64 bytes, default 64
[ 1.454748] Trying to unpack rootfs image as initramfs...
[ 1.704504] Freeing initrd memory: 82424K
[ 1.729462] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.729466] software IO TLB: mapped [mem 0x792f0000-0x7d2f0000] (64MB)
[ 1.730726] check: Scanning for low memory corruption every 60 seconds
[ 1.731742] Initialise system trusted keyrings
[ 1.731756] Key type blacklist registered
[ 1.731821] workingset: timestamp_bits=36 max_order=26 bucket_order=0
[ 1.733202] zbud: loaded
[ 1.733715] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.733902] fuse: init (API version 7.31)
[ 1.733924] *** VALIDATE fuse ***
[ 1.733927] *** VALIDATE fuse ***
[ 1.734075] Platform Keyring initialized
[ 1.737893] Key type asymmetric registered
[ 1.737897] Asymmetric key parser 'x509' registered
[ 1.737908] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.737955] io scheduler mq-deadline registered
[ 1.738745] pcieport 0000:00:01.0: PME: Signaling with IRQ 25
[ 1.739164] pcieport 0000:00:03.0: PME: Signaling with IRQ 26
[ 1.739529] pcieport 0000:00:11.0: PME: Signaling with IRQ 27
[ 1.739658] pcieport 0000:00:1c.0: PME: Signaling with IRQ 28
[ 1.739979] pcieport 0000:00:1c.4: PME: Signaling with IRQ 29
[ 1.740309] pcieport 0000:00:1c.7: PME: Signaling with IRQ 30
[ 1.744716] pcieport 0000:40:03.0: PME: Signaling with IRQ 32
[ 1.745047] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.745139] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 1.745142] vesafb: scrolling: redraw
[ 1.745144] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.745158] vesafb: framebuffer at 0xd8000000, mapped to 0x(____ptrval____), using 1216k, total 1216k
[ 1.745257] Console: switching to colour frame buffer device 80x30
[ 1.809848] fb0: VESA VGA frame buffer device
[ 1.811167] intel_idle: MWAIT substates: 0x21120
[ 1.811168] intel_idle: v0.4.1 model 0x2D
[ 1.812258] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 1.812383] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 1.814702] ACPI: Power Button [PWRF]
[ 1.816777] ERST: Error Record Serialization Table (ERST) support is initialized.
[ 1.885716] pstore: Registered erst as persistent store backend
[ 1.920932] GHES: APEI firmware first mode is enabled by APEI bit and WHEA _OSC.
[ 1.993295] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 2.052198] 00:02: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[ 2.150514] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 2.230606] Linux agpgart interface v0.103
[ 2.413519] loop: module loaded
[ 2.452126] libphy: Fixed MDIO Bus: probed
[ 2.491356] tun: Universal TUN/TAP device driver, 1.6
[ 2.531948] PPP generic driver version 2.4.2
[ 2.573405] VFIO - User Level meta-driver version: 0.3
[ 2.616401] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.660707] ehci-pci: EHCI PCI platform driver
[ 2.705928] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 2.749477] tsc: Refined TSC clocksource calibration: 2399.992 MHz
[ 2.750451] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 2.795225] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x22982fdf183, max_idle_ns: 440795240423 ns
[ 2.884981] ehci-pci 0000:00:1a.0: debug port 2
[ 3.023296] clocksource: Switched to clocksource tsc
[ 3.027260] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 3.114623] ehci-pci 0000:00:1a.0: irq 23, io mem 0xdf0fd000
[ 3.173486] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 3.218277] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 3.307386] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.396971] usb usb1: Product: EHCI Host Controller
[ 3.441631] usb usb1: Manufacturer: Linux 5.4.0-90-generic ehci_hcd
[ 3.486370] usb usb1: SerialNumber: 0000:00:1a.0
[ 3.529842] hub 1-0:1.0: USB hub found
[ 3.572551] hub 1-0:1.0: 2 ports detected
[ 3.614612] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 3.656194] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 3.738563] ehci-pci 0000:00:1d.0: debug port 2
[ 3.784734] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 3.827941] ehci-pci 0000:00:1d.0: irq 22, io mem 0xdf0fe000
[ 3.885491] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 3.901462] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 3.971787] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 4.058892] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.082283] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 4.146443] usb usb2: Product: EHCI Host Controller
[ 4.146445] usb usb2: Manufacturer: Linux 5.4.0-90-generic ehci_hcd
[ 4.235232] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.235743] hub 1-1:1.0: USB hub found
[ 4.278338] usb usb2: SerialNumber: 0000:00:1d.0
[ 4.324468] hub 1-1:1.0: 6 ports detected
[ 4.366739] hub 2-0:1.0: USB hub found
[ 4.540376] hub 2-0:1.0: 2 ports detected
[ 4.581776] ehci-platform: EHCI generic platform driver
[ 4.622344] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.663229] ohci-pci: OHCI PCI platform driver
[ 4.697454] usb 1-1.6: new high-speed USB device number 3 using ehci-pci
[ 4.703258] ohci-platform: OHCI generic platform driver
[ 4.785585] uhci_hcd: USB Universal Host Controller Interface driver
[ 4.827333] i8042: PNP: No PS/2 controller found.
[ 4.851344] usb 1-1.6: New USB device found, idVendor=413c, idProduct=a001, bcdDevice= 0.00
[ 4.869466] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 4.869929] mousedev: PS/2 mouse device common for all mice
[ 4.956226] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.956228] usb 1-1.6: Product: Gadget USB HUB
[ 5.000696] rtc_cmos 00:01: RTC can wake from S4
[ 5.033974] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 5.033976] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.034365] hub 2-1:1.0: USB hub found
[ 5.034569] hub 2-1:1.0: 8 ports detected
[ 5.045142] usb 1-1.6: Manufacturer: no manufacturer
[ 5.045143] usb 1-1.6: SerialNumber: 0123456789
[ 5.045631] hub 1-1.6:1.0: USB hub found
[ 5.135231] rtc_cmos 00:01: registered as rtc0
[ 5.180094] hub 1-1.6:1.0: 6 ports detected
[ 5.224769] rtc_cmos 00:01: alarms up to one day, y3k, 242 bytes nvram, hpet irqs
[ 5.730180] i2c /dev entries driver
[ 5.770982] device-mapper: uevent: version 1.0.3
[ 5.793454] usb 1-1.6.1: new high-speed USB device number 4 using ehci-pci
[ 5.812657] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[ 5.941349] platform eisa.0: Probing EISA bus 0
[ 5.984797] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 5.987474] usb 1-1.6.1: New USB device found, idVendor=0624, idProduct=0249, bcdDevice= 0.00
[ 6.027859] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 6.027861] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 6.114906] usb 1-1.6.1: New USB device strings: Mfr=4, Product=5, SerialNumber=6
[ 6.114907] usb 1-1.6.1: Product: Keyboard/Mouse Function
[ 6.114920] usb 1-1.6.1: Manufacturer: Avocent
[ 6.159284] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 6.159296] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 6.159298] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 6.201830] usb 1-1.6.1: SerialNumber: 20121018
[ 6.527486] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 6.565975] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 6.603173] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 6.640080] platform eisa.0: EISA: Detected 0 cards
[ 6.676551] intel_pstate: Intel P-state driver initializing
[ 6.717108] ledtrig-cpu: registered to indicate activity on CPUs
[ 6.755251] drop_monitor: Initializing network drop monitor service
[ 6.794150] NET: Registered protocol family 10
[ 6.840849] Segment Routing with IPv6
[ 6.878539] NET: Registered protocol family 17
[ 6.915919] Key type dns_resolver registered
[ 6.956534] RAS: Correctable Errors collector initialized.
[ 6.994837] microcode: sig=0x206d7, pf=0x8, revision=0x71a
[ 7.033667] microcode: Microcode Update Driver: v2.2.
[ 7.033672] IPI shorthand broadcast: enabled
[ 7.106283] sched_clock: Marking stable (7105721654, 550039)->(7142914227, -36642534)
[ 7.179561] registered taskstats version 1
[ 7.215745] Loading compiled-in X.509 certificates
[ 7.252584] Loaded X.509 cert 'Build time autogenerated kernel key: 85cd93e325e502cfcb4258a2209a1e273ffd77af'
[ 7.326768] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
[ 7.402968] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
[ 7.480979] zswap: loaded using pool lzo/zbud
[ 7.520586] Key type ._fscrypt registered
[ 7.560346] Key type .fscrypt registered
[ 7.600899] pstore: Using crash dump compression: deflate
[ 7.648429] Key type big_key registered
[ 7.691416] Key type encrypted registered
[ 7.731679] AppArmor: AppArmor sha1 policy hashing enabled
[ 7.773413] ima: No TPM chip found, activating TPM-bypass!
[ 7.815079] ima: Allocated hash algorithm: sha1
[ 7.856766] ima: No architecture policies found
[ 7.897759] evm: Initialising EVM extended attributes:
[ 7.938611] evm: security.selinux
[ 7.978680] evm: security.SMACK64
[ 8.017740] evm: security.SMACK64EXEC
[ 8.056246] evm: security.SMACK64TRANSMUTE
[ 8.094416] evm: security.SMACK64MMAP
[ 8.131139] evm: security.apparmor
[ 8.167167] evm: security.ima
[ 8.202313] evm: security.capability
[ 8.237074] evm: HMAC attrs: 0x1
[ 8.271684] PM: Magic number: 13:487:83
[ 8.304477] event_source uncore_cbox_1: hash matches
[ 8.337620] rtc_cmos 00:01: setting system clock to 2021-11-18T15:03:41 UTC (1637247821)
[ 8.406187] Freeing unused decrypted memory: 2040K
[ 8.440250] Freeing unused kernel image memory: 2736K
[ 8.477576] Write protecting the kernel read-only data: 22528k
[ 8.510591] Freeing unused kernel image memory: 2008K
[ 8.542182] Freeing unused kernel image memory: 1124K
[ 8.581857] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 8.611793] x86/mm: Checking user space page tables
[ 8.651189] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 8.681902] Run /init as init process
[ 8.873653] megasas: 07.713.01.00-rc1
[ 8.907279] hidraw: raw HID events driver (C) Jiri Kosina
[ 8.909546] megaraid_sas 0000:01:00.0: BAR:0x1 BAR's base_addr(phys):0x00000000dcffc000 mapped virt_addr:0x(____ptrval____)
[ 8.937577] megaraid_sas 0000:01:00.0: FW now in Ready state
[ 8.967943] megaraid_sas 0000:01:00.0: 63 bit DMA mask and 32 bit consistent mask
[ 9.028266] cryptd: max_cpu_qlen set to 1000
[ 9.028498] megaraid_sas 0000:01:00.0: firmware supports msix : (16)
[ 9.091640] megaraid_sas 0000:01:00.0: requested/available msix 16/16
[ 9.124633] megaraid_sas 0000:01:00.0: current msix/online cpus : (16/24)
[ 9.158440] megaraid_sas 0000:01:00.0: RDPQ mode : (disabled)
[ 9.192332] megaraid_sas 0000:01:00.0: Current firmware supports maximum commands: 1008 LDIO threshold: 0
[ 9.263086] megaraid_sas 0000:01:00.0: Configured max firmware commands: 1007
[ 9.305983] megaraid_sas 0000:01:00.0: Performance mode :Latency
[ 9.344107] megaraid_sas 0000:01:00.0: FW supports sync cache : No
[ 9.382351] megaraid_sas 0000:01:00.0: megasas_disable_intr_fusion is called outbound_intr_mask:0x40000009
[ 9.481934] tg3.c:v3.137 (May 11, 2014)
[ 9.519799] ahci 0000:00:1f.2: version 3.0
[ 9.527548] usbcore: registered new interface driver usbhid
[ 9.530783] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x1f impl SATA mode
[ 9.564563] usbhid: USB HID core driver
[ 9.639955] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
[ 9.650378] tg3 0000:02:00.0 eth0: Tigon3 [partno(BCM95720) rev 5720000] (PCI Express) MAC address 90:b1:1c:24:a1:f1
[ 9.756359] AVX version of gcm_enc/dec engaged.
[ 9.838303] tg3 0000:02:00.0 eth0: attached PHY is 5720C (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 9.838307] tg3 0000:02:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] TSOcap[1]
[ 9.879579] AES CTR mode by8 optimization enabled
[ 9.964509] tg3 0000:02:00.0 eth0: dma_rwctrl[00000001] dma_mask[64-bit]
[ 10.143326] megaraid_sas 0000:01:00.0: FW provided supportMaxExtLDs: 0 max_lds: 64
[ 10.233799] megaraid_sas 0000:01:00.0: controller type : MR(512MB)
[ 10.280302] megaraid_sas 0000:01:00.0: Online Controller Reset(OCR) : Enabled
[ 10.327500] megaraid_sas 0000:01:00.0: Secure JBOD support : No
[ 10.374549] megaraid_sas 0000:01:00.0: NVMe passthru support : No
[ 10.421415] megaraid_sas 0000:01:00.0: FW provided TM TaskAbort/Reset timeout : 0 secs/0 secs
[ 10.514064] megaraid_sas 0000:01:00.0: JBOD sequence map support : No
[ 10.560892] megaraid_sas 0000:01:00.0: PCI Lane Margining support : No
[ 10.634434] megaraid_sas 0000:01:00.0: megasas_enable_intr_fusion is called outbound_intr_mask:0x40000000
[ 10.728469] megaraid_sas 0000:01:00.0: INIT adapter done
[ 10.775617] megaraid_sas 0000:01:00.0: JBOD sequence map is disabled megasas_setup_jbod_map 5734
[ 10.869602] scsi host1: ahci
[ 10.916097] input: Avocent Keyboard/Mouse Function as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6.1/1-1.6.1:1.0/0003:0624:0249.0001/input/input1
[ 10.916296] megaraid_sas 0000:01:00.0: pci id : (0x1000)/(0x005b)/(0x1028)/(0x1f38)
[ 11.069815] hid-generic 0003:0624:0249.0001: input,hidraw0: USB HID v1.00 Keyboard [Avocent Keyboard/Mouse Function] on usb-0000:00:1a.0-1.6.1/input0
[ 11.107159] megaraid_sas 0000:01:00.0: unevenspan support : no
[ 11.205518] input: Avocent Keyboard/Mouse Function as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6.1/1-1.6.1:1.1/0003:0624:0249.0002/input/input2
[ 11.254569] megaraid_sas 0000:01:00.0: firmware crash dump : no
[ 11.354762] hid-generic 0003:0624:0249.0002: input,hidraw1: USB HID v1.00 Mouse [Avocent Keyboard/Mouse Function] on usb-0000:00:1a.0-1.6.1/input1
[ 11.403961] megaraid_sas 0000:01:00.0: JBOD sequence map : disabled
[ 11.503377] input: Avocent Keyboard/Mouse Function as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6.1/1-1.6.1:1.2/0003:0624:0249.0003/input/input3
[ 11.553358] scsi host2: ahci
[ 11.654024] hid-generic 0003:0624:0249.0003: input,hidraw2: USB HID v1.00 Mouse [Avocent Keyboard/Mouse Function] on usb-0000:00:1a.0-1.6.1/input2
[ 11.704215] scsi host3: ahci
[ 11.859518] scsi host0: Avago SAS based MegaRAID driver
[ 11.913863] scsi host4: ahci
[ 11.937003] scsi 0:2:0:0: Direct-Access DELL PERC H710 3.13 PQ: 0 ANSI: 5
[ 11.965340] scsi host5: ahci
[ 12.086159] random: fast init done
[ 12.117150] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 12.117377] scsi host6: ahci
[ 12.117738] ata1: SATA max UDMA/133 abar m2048@0xdf0ff000 port 0xdf0ff100 irq 50
[ 12.117752] ata2: SATA max UDMA/133 abar m2048@0xdf0ff000 port 0xdf0ff180 irq 50
[ 12.117757] ata3: SATA max UDMA/133 abar m2048@0xdf0ff000 port 0xdf0ff200 irq 50
[ 12.117761] ata4: SATA max UDMA/133 abar m2048@0xdf0ff000 port 0xdf0ff280 irq 50
[ 12.117766] ata5: SATA max UDMA/133 abar m2048@0xdf0ff000 port 0xdf0ff300 irq 50
[ 12.117767] ata6: DUMMY
[ 12.123773] tg3 0000:02:00.1 eth1: Tigon3 [partno(BCM95720) rev 5720000] (PCI Express) MAC address 90:b1:1c:24:a1:f2
[ 12.123776] tg3 0000:02:00.1 eth1: attached PHY is 5720C (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 12.123777] tg3 0000:02:00.1 eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] TSOcap[1]
[ 12.123779] tg3 0000:02:00.1 eth1: dma_rwctrl[00000001] dma_mask[64-bit]
[ 12.176755] scsi 0:2:0:0: Attached scsi generic sg0 type 0
[ 12.176979] sd 0:2:0:0: [sda] 11717836800 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 12.177041] sd 0:2:0:0: [sda] Write Protect is off
[ 12.177043] sd 0:2:0:0: [sda] Mode Sense: 1f 00 00 08
[ 12.177101] sd 0:2:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 12.216152] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 12.432089] ata1: SATA link down (SStatus 0 SControl 300)
[ 12.467869] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 12.568083] ata2: SATA link down (SStatus 0 SControl 300)
[ 12.671298] tg3 0000:02:00.0 eno1: renamed from eth0
[ 12.767945] ata4: SATA link down (SStatus 0 SControl 300)
[ 13.761295] ata3: SATA link down (SStatus 0 SControl 300)
[ 13.811864] ata5: SATA link down (SStatus 0 SControl 300)
[ 13.816403] sda: sda1 sda2 sda3
[ 13.862601] tg3 0000:02:00.1 eno2: renamed from eth1
[ 13.958905] mgag200 0000:06:00.0: remove_conflicting_pci_framebuffers: bar 0: 0xd8000000 -> 0xd8ffffff
[ 14.052447] mgag200 0000:06:00.0: remove_conflicting_pci_framebuffers: bar 1: 0xde7fc000 -> 0xde7fffff
[ 14.146758] mgag200 0000:06:00.0: remove_conflicting_pci_framebuffers: bar 2: 0xdd800000 -> 0xddffffff
[ 14.243010] checking generic (d8000000 130000) vs hw (d8000000 1000000)
[ 14.243010] fb0: switching to mgag200drmfb from VESA VGA
[ 14.291831] Console: switching to colour dummy device 80x25
[ 14.291851] mgag200 0000:06:00.0: vgaarb: deactivate vga console
[ 14.293784] sd 0:2:0:0: [sda] Attached SCSI disk
[ 14.303645] [TTM] Zone kernel: Available graphics memory: 74243334 KiB
[ 14.303649] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 14.303651] [TTM] Initializing pool allocator
[ 14.303668] [TTM] Initializing DMA pool allocator
[ 14.335652] fbcon: mgag200drmfb (fb0) is primary device
[ 14.405505] Console: switching to colour frame buffer device 128x48
[ 14.407065] mgag200 0000:06:00.0: fb0: mgag200drmfb frame buffer device
[ 14.437510] [drm] Initialized mgag200 1.0.0 20110418 for 0000:06:00.0 on minor 0
[ 14.893447] raid6: sse2x4 gen() 11647 MB/s
[ 14.941449] raid6: sse2x4 xor() 7890 MB/s
[ 14.989447] raid6: sse2x2 gen() 10010 MB/s
[ 15.037447] raid6: sse2x2 xor() 6762 MB/s
[ 15.085451] raid6: sse2x1 gen() 8193 MB/s
[ 15.133450] raid6: sse2x1 xor() 6079 MB/s
[ 15.133465] raid6: using algorithm sse2x4 gen() 11647 MB/s
[ 15.133483] raid6: .... xor() 7890 MB/s, rmw enabled
[ 15.133519] raid6: using ssse3x2 recovery algorithm
[ 15.135764] xor: automatically using best checksumming function avx
[ 15.137513] async_tx: api initialized (async)
[ 15.250209] Btrfs loaded, crc32c=crc32c-intel
[ 15.267637] BTRFS: device label local devid 1 transid 1266667 /dev/mapper/ubuntu--vg-lxd--lv
[ 15.351481] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 16.633216] systemd[1]: Inserted module 'autofs4'
[ 16.692823] ERST: NVRAM ERST Log Address Range not implemented yet.
[ 16.734121] systemd[1]: systemd 245.4-4ubuntu3.13 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 16.753570] systemd[1]: Detected architecture x86-64.
[ 16.827818] systemd[1]: Set hostname to <frodo>.
[ 18.285557] random: crng init done
[ 18.286403] random: 7 urandom warning(s) missed due to ratelimiting
[ 18.438878] systemd[1]: Created slice system-modprobe.slice.
[ 18.443205] systemd[1]: Created slice User and Session Slice.
[ 18.444921] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 18.446840] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 18.448592] systemd[1]: Reached target User and Group Name Lookups.
[ 18.450296] systemd[1]: Reached target Slices.
[ 18.452057] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 18.453921] systemd[1]: Listening on LVM2 poll daemon socket.
[ 18.455749] systemd[1]: Listening on multipathd control socket.
[ 18.461654] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 18.463630] systemd[1]: Listening on Syslog Socket.
[ 18.465584] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 18.467616] systemd[1]: Listening on Journal Audit Socket.
[ 18.469526] systemd[1]: Listening on Journal Socket (/dev/log).
[ 18.471422] systemd[1]: Listening on Journal Socket.
[ 18.473295] systemd[1]: Listening on Network Service Netlink Socket.
[ 18.475139] systemd[1]: Listening on udev Control Socket.
[ 18.476898] systemd[1]: Listening on udev Kernel Socket.
[ 18.479932] systemd[1]: Mounting Huge Pages File System...
[ 18.482830] systemd[1]: Mounting POSIX Message Queue File System...
[ 18.485643] systemd[1]: Mounting RPC Pipe File System...
[ 18.488513] systemd[1]: Mounting Kernel Debug File System...
[ 18.491594] systemd[1]: Mounting Kernel Trace File System...
[ 18.495750] systemd[1]: Starting Journal Service...
[ 18.499275] systemd[1]: Starting Set the console keyboard layout...
[ 18.502323] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 18.505336] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 18.507280] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 18.508226] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 18.523841] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 18.529874] systemd[1]: Starting Load Kernel Modules...
[ 18.532873] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 18.535845] systemd[1]: Starting udev Coldplug all Devices...
[ 18.538807] systemd[1]: Starting Uncomplicated firewall...
[ 18.543360] systemd[1]: Mounted Huge Pages File System.
[ 18.545324] systemd[1]: Mounted POSIX Message Queue File System.
[ 18.547627] systemd[1]: Mounted Kernel Debug File System.
[ 18.550028] systemd[1]: Mounted Kernel Trace File System.
[ 18.552487] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 18.553200] EXT4-fs (dm-0): re-mounted. Opts: (null)
[ 18.557342] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 18.561369] systemd[1]: Activating swap /swap.img...
[ 18.571681] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 18.573581] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 18.577342] systemd[1]: Starting Load/Save Random Seed...
[ 18.582678] systemd[1]: Starting Create System Users...
[ 18.587364] systemd[1]: Finished Uncomplicated firewall.
[ 18.620242] systemd[1]: Finished Load Kernel Modules.
[ 18.623879] systemd[1]: Mounting FUSE Control File System...
[ 18.627233] systemd[1]: Mounting Kernel Configuration File System...
[ 18.628314] RPC: Registered named UNIX socket transport module.
[ 18.628315] RPC: Registered udp transport module.
[ 18.628316] RPC: Registered tcp transport module.
[ 18.628317] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 18.637319] systemd[1]: Starting Apply Kernel Variables...
[ 18.640185] systemd[1]: Mounted RPC Pipe File System.
[ 18.642658] systemd[1]: Finished Load/Save Random Seed.
[ 18.644676] systemd[1]: Mounted FUSE Control File System.
[ 18.646613] systemd[1]: Mounted Kernel Configuration File System.
[ 18.651044] systemd[1]: Finished Set the console keyboard layout.
[ 18.654381] systemd[1]: Started Journal Service.
[ 18.691347] systemd-journald[612]: Received client request to flush runtime journal.
[ 18.769513] Adding 4603900k swap on /swap.img. Priority:-2 extents:7 across:5169148k FS
[ 19.331561] ACPI Error: No handler for Region [SYSI] (000000004f7ece08) [IPMI] (20190816/evregion-129)
[ 19.332505] ACPI Error: Region IPMI (ID=7) has no handler (20190816/exfldio-261)
[ 19.333951] No Local Variables are initialized for Method [_GHL]
[ 19.333952] No Arguments are initialized for method [_GHL]
[ 19.333957] ACPI Error: Aborting method \_SB.PMI0._GHL due to previous error (AE_NOT_EXIST) (20190816/psparse-529)
[ 19.333991] IPMI message handler: version 39.2
[ 19.335402] ACPI Error: Aborting method \_SB.PMI0._PMC due to previous error (AE_NOT_EXIST) (20190816/psparse-529)
[ 19.336781] ACPI Error: AE_NOT_EXIST, Evaluating _PMC (20190816/power_meter-743)
[ 19.349587] ipmi device interface
[ 19.367018] ipmi_si: IPMI System Interface driver
[ 19.367047] ipmi_si dmi-ipmi-si.0: ipmi_platform: probing via SMBIOS
[ 19.367051] ipmi_platform: ipmi_si: SMBIOS: io 0xca8 regsize 1 spacing 4 irq 10
[ 19.367052] ipmi_si: Adding SMBIOS-specified kcs state machine
[ 19.368342] ipmi_si: Trying SMBIOS-specified kcs state machine at i/o address 0xca8, slave address 0x20, irq 10
[ 19.398621] mei_me 0000:00:16.0: Device doesn't have valid ME Interface
[ 19.431776] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[ 19.431779] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 19.431780] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 19.431781] RAPL PMU: hw unit of domain dram 2^-16 Joules
[ 19.482600] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.3)
[ 19.748128] EDAC sbridge: Seeking for: PCI ID 8086:3ca0
[ 19.748149] EDAC sbridge: Seeking for: PCI ID 8086:3ca0
[ 19.748163] EDAC sbridge: Seeking for: PCI ID 8086:3ca0
[ 19.748170] EDAC sbridge: Seeking for: PCI ID 8086:3ca8
[ 19.748176] EDAC sbridge: Seeking for: PCI ID 8086:3ca8
[ 19.748181] EDAC sbridge: Seeking for: PCI ID 8086:3ca8
[ 19.748183] EDAC sbridge: Seeking for: PCI ID 8086:3c71
[ 19.748189] EDAC sbridge: Seeking for: PCI ID 8086:3c71
[ 19.748194] EDAC sbridge: Seeking for: PCI ID 8086:3c71
[ 19.748196] EDAC sbridge: Seeking for: PCI ID 8086:3caa
[ 19.748201] EDAC sbridge: Seeking for: PCI ID 8086:3caa
[ 19.748207] EDAC sbridge: Seeking for: PCI ID 8086:3caa
[ 19.748209] EDAC sbridge: Seeking for: PCI ID 8086:3cab
[ 19.748214] EDAC sbridge: Seeking for: PCI ID 8086:3cab
[ 19.748220] EDAC sbridge: Seeking for: PCI ID 8086:3cab
[ 19.748221] EDAC sbridge: Seeking for: PCI ID 8086:3cac
[ 19.748227] EDAC sbridge: Seeking for: PCI ID 8086:3cac
[ 19.748232] EDAC sbridge: Seeking for: PCI ID 8086:3cac
[ 19.748234] EDAC sbridge: Seeking for: PCI ID 8086:3cad
[ 19.748240] EDAC sbridge: Seeking for: PCI ID 8086:3cad
[ 19.748245] EDAC sbridge: Seeking for: PCI ID 8086:3cad
[ 19.748247] EDAC sbridge: Seeking for: PCI ID 8086:3cb8
[ 19.748253] EDAC sbridge: Seeking for: PCI ID 8086:3cb8
[ 19.748258] EDAC sbridge: Seeking for: PCI ID 8086:3cb8
[ 19.748259] EDAC sbridge: Seeking for: PCI ID 8086:3cf4
[ 19.748264] EDAC sbridge: Seeking for: PCI ID 8086:3cf4
[ 19.748269] EDAC sbridge: Seeking for: PCI ID 8086:3cf4
[ 19.748272] EDAC sbridge: Seeking for: PCI ID 8086:3cf6
[ 19.748277] EDAC sbridge: Seeking for: PCI ID 8086:3cf6
[ 19.748282] EDAC sbridge: Seeking for: PCI ID 8086:3cf6
[ 19.748284] EDAC sbridge: Seeking for: PCI ID 8086:3cf5
[ 19.748289] EDAC sbridge: Seeking for: PCI ID 8086:3cf5
[ 19.748294] EDAC sbridge: Seeking for: PCI ID 8086:3cf5
[ 19.748407] EDAC MC0: Giving out device to module sb_edac controller Sandy Bridge SrcID#0_Ha#0: DEV 0000:3f:0e.0 (INTERRUPT)
[ 19.748497] EDAC MC1: Giving out device to module sb_edac controller Sandy Bridge SrcID#1_Ha#0: DEV 0000:7f:0e.0 (INTERRUPT)
[ 19.748497] EDAC sbridge: Ver: 1.1.2
[ 19.757510] ipmi_si dmi-ipmi-si.0: The BMC does not support setting the recv irq bit, compensating, but the BMC needs to be fixed.
[ 19.803516] intel_rapl_common: Found RAPL domain package
[ 19.803518] intel_rapl_common: Found RAPL domain core
[ 19.803521] intel_rapl_common: Found RAPL domain dram
[ 19.803633] intel_rapl_common: Found RAPL domain package
[ 19.803635] intel_rapl_common: Found RAPL domain core
[ 19.803637] intel_rapl_common: Found RAPL domain dram
[ 19.837561] ipmi_si dmi-ipmi-si.0: Using irq 10
[ 19.860458] ipmi_si dmi-ipmi-si.0: IPMI message handler: Found new BMC (man_id: 0x0002a2, prod_id: 0x0100, dev_id: 0x20)
[ 19.910002] ipmi_si dmi-ipmi-si.0: IPMI kcs interface initialized
[ 19.922626] ipmi_ssif: IPMI SSIF Interface driver
[ 20.359278] alua: device handler registered
[ 20.360909] emc: device handler registered
[ 20.362987] rdac: device handler registered
[ 20.524599] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 21.180166] audit: type=1400 audit(1637247834.336:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=953 comm="apparmor_parser"
[ 21.180170] audit: type=1400 audit(1637247834.336:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=953 comm="apparmor_parser"
[ 21.180298] audit: type=1400 audit(1637247834.336:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=951 comm="apparmor_parser"
[ 21.189089] audit: type=1400 audit(1637247834.344:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=952 comm="apparmor_parser"
[ 21.189093] audit: type=1400 audit(1637247834.344:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=952 comm="apparmor_parser"
[ 21.189095] audit: type=1400 audit(1637247834.344:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=952 comm="apparmor_parser"
[ 21.192822] audit: type=1400 audit(1637247834.348:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=949 comm="apparmor_parser"
[ 21.192828] audit: type=1400 audit(1637247834.348:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=949 comm="apparmor_parser"
[ 21.235393] audit: type=1400 audit(1637247834.392:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=950 comm="apparmor_parser"
[ 27.856231] tg3 0000:02:00.0 eno1: Link is up at 1000 Mbps, full duplex
[ 27.856239] tg3 0000:02:00.0 eno1: Flow control is off for TX and off for RX
[ 27.856240] tg3 0000:02:00.0 eno1: EEE is disabled
[ 27.856259] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[ 30.444477] FS-Cache: Loaded
[ 30.592601] FS-Cache: Netfs 'nfs' registered for caching
[ 30.763228] NFS: Registering the id_resolver key type
[ 30.763238] Key type id_resolver registered
[ 30.763239] Key type id_legacy registered
[ 30.765615] FS-Cache: Duplicate cookie detected
[ 30.766187] FS-Cache: O-cookie c=0000000032c1ef50 [p=00000000c8a4cb66 fl=222 nc=0 na=1]
[ 30.766764] FS-Cache: O-cookie d=000000002d2526ad n=000000003ee77e52
[ 30.767301] FS-Cache: O-key=[16] '040000000100000002000801863c4414'
[ 30.767843] FS-Cache: N-cookie c=000000006d4b93e2 [p=00000000c8a4cb66 fl=2 nc=0 na=1]
[ 30.768444] FS-Cache: N-cookie d=000000002d2526ad n=0000000031b32c72
[ 30.769014] FS-Cache: N-key=[16] '040000000100000002000801863c4414'
[ 35.065351] new mount options do not match the existing superblock, will be ignored
[ 36.342196] NET: Registered protocol family 40
[ 38.594964] bpfilter: Loaded bpfilter_umh pid 1529
[ 38.595568] Started bpfilter
[ 39.083823] spl: loading out-of-tree module taints kernel.
[ 39.108934] znvpair: module license 'CDDL' taints kernel.
[ 39.108936] Disabling lock debugging due to kernel taint
[ 40.964519] ZFS: Loaded module v0.8.3-1ubuntu12.12, ZFS pool version 5000, ZFS filesystem version 5
[ 41.164518] BTRFS info (device dm-1): flagging fs with big metadata feature
[ 41.164526] BTRFS info (device dm-1): use lzo compression, level 0
[ 41.164530] BTRFS info (device dm-1): disk space caching is enabled
[ 41.164533] BTRFS info (device dm-1): has skinny extents
[ 61.287680] BTRFS info (device dm-1): start tree-log replay
[ 61.634926] BTRFS warning (device dm-1): block group 1881226084352 has wrong amount of free space
[ 61.634930] BTRFS warning (device dm-1): failed to load free space cache for block group 1881226084352, rebuilding it now
[ 72.885426] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 72.912950] lxdfan0: port 1(lxdfan0-mtu) entered blocking state
[ 72.912958] lxdfan0: port 1(lxdfan0-mtu) entered disabled state
[ 72.913162] device lxdfan0-mtu entered promiscuous mode
[ 72.938525] lxdfan0: port 1(lxdfan0-mtu) entered blocking state
[ 72.938530] lxdfan0: port 1(lxdfan0-mtu) entered forwarding state
[ 73.065033] lxdfan0: port 2(lxdfan0-fan) entered blocking state
[ 73.065038] lxdfan0: port 2(lxdfan0-fan) entered disabled state
[ 73.065193] device lxdfan0-fan entered promiscuous mode
[ 73.072605] lxdfan0: port 2(lxdfan0-fan) entered blocking state
[ 73.072611] lxdfan0: port 2(lxdfan0-fan) entered forwarding state
[ 73.205125] kauditd_printk_skb: 21 callbacks suppressed
[ 73.205127] audit: type=1400 audit(1637247886.089:32): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_dnsmasq-lxdfan0_</var/snap/lxd/common/lxd>" pid=1682 comm="apparmor_parser"
[ 73.228862] audit: type=1400 audit(1637247886.113:33): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_forkdns-lxdfan0_</var/snap/lxd/common/lxd>" pid=1684 comm="apparmor_parser"
[ 73.942151] IPv6: ADDRCONF(NETDEV_CHANGE): lxdfan0: link becomes ready
[ 75.604368] lxdfan0: port 3(vethf31ab1b1) entered blocking state
[ 75.604372] lxdfan0: port 3(vethf31ab1b1) entered disabled state
[ 75.604489] device vethf31ab1b1 entered promiscuous mode
[ 75.846345] audit: type=1400 audit(1637247888.709:34): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-nocs2021-old_</var/snap/lxd/common/lxd>" pid=1790 comm="apparmor_parser"
[ 75.889917] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
[ 75.964851] phys6G92fK: renamed from veth5a4359cf
[ 76.005619] eth0: renamed from phys6G92fK
[ 76.034329] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 76.034432] lxdfan0: port 3(vethf31ab1b1) entered blocking state
[ 76.034435] lxdfan0: port 3(vethf31ab1b1) entered forwarding state
[ 86.694285] audit: type=1400 audit(1637247899.521:35): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=2050 comm="apparmor_parser"
[ 86.694301] audit: type=1400 audit(1637247899.521:36): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=2050 comm="apparmor_parser"
[ 86.694880] audit: type=1400 audit(1637247899.521:37): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=2052 comm="apparmor_parser"
[ 86.694890] audit: type=1400 audit(1637247899.521:38): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=2052 comm="apparmor_parser"
[ 86.694909] audit: type=1400 audit(1637247899.521:39): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=2052 comm="apparmor_parser"
[ 86.702345] audit: type=1400 audit(1637247899.529:40): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=2055 comm="apparmor_parser"
[ 86.702359] audit: type=1400 audit(1637247899.529:41): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=2055 comm="apparmor_parser"
[ 86.702433] audit: type=1400 audit(1637247899.529:42): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=2049 comm="apparmor_parser"
[ 86.719776] audit: type=1400 audit(1637247899.549:43): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=2051 comm="apparmor_parser"
[ 86.719788] audit: type=1400 audit(1637247899.549:44): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=2051 comm="apparmor_parser"
[ 112.498685] overlayfs: unrecognized mount option "userxattr" or missing value
[ 114.163891] kauditd_printk_skb: 20 callbacks suppressed
[ 114.163895] audit: type=1400 audit(1637247926.985:65): apparmor="STATUS" operation="profile_load" label="lxd-nocs2021-old_</var/snap/lxd/common/lxd>//&:lxd-nocs2021-old_<var-snap-lxd-common-lxd>:unconfined" name="docker-default" pid=2419 comm="apparmor_parser"
