I try to create an Opnsense VM. I follow Stéphane’s tutorial like windows install, Installer works but, opnsense installer don’t find NIC or disk.
Opnsense seems to have virtio support since v19.7.
Do you think I need to install FreeBSD like vm and after that install opnsense?
I prefer to install directly opnsense, but if I can’t, after all.
Someone try opnsense?
Thanks!
