trystan
(Trystan)
December 31, 2020, 10:58pm
1
There may be nothing the LXD folks or the team that creates the images for Oracle/Centos 8 can do about it, but I am unable to get a stock Centos8/Oracle8 (cloud or vanilla) image booting to usable network with or without cloud-init.
Seems I’m hitting this bug:
https://bugzilla.redhat.com/show_bug.cgi?id=1832603
lxd version 4.9
profile for container:
boot.autostart: "true"
snapshots.expiry: 2d
snapshots.schedule: 0 */6 * * *
nictype: macvlan
parent: enp4s0f0
pool: lpool
[root@oracle ~]# nmcli
lo: unmanaged
"lo"
loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
eth0: unmanaged
"eth0"
macvlan, 00:16:3E:8E:7E:B9, sw, mtu 1500
lxc exec oracle bash and using the following commands:
nmcli dev set eth0 managed yes
nmcli con up 'System eth0'
results in:
Error: Connection activation failed: No suitable device found for this connection (device lo not available because device is strictly unmanaged).
tomp
(Thomas Parrott)
January 1, 2021, 8:15am
2
Yes there was a fix for veth devices added to our images recently see CentOS 8 Stream container not assigned IPv4/IPv6 addresses
However there is some ongoing discussion in that thread about getting it to work on a Ubuntu bionic host.
Also I note you are actually using macvlan and not veth and for this case there is an issue open to address this (hopefully it will be similar to the fix for veth).
See
opened 01:08PM - 23 Dec 20 UTC
closed 02:33AM - 16 Jun 21 UTC
On the [lxd tryit](https://linuxcontainers.org/lxd/try-it) server I ran the foll… owing:
root@tryit-precise:~# lxc launch images:centos/8-Stream centos8stream
Creating centos8stream
Starting centos8stream
root@tryit-precise:~# lxc list centos8stream
| centos8stream | RUNNING | | | CONTAINER | 0 |
root@tryit-precise:~# lxc image ls
| ALIAS | FINGERPRINT | PUBLIC | DESCRIPTION | ARCHITECTURE | TYPE | SIZE | UPLOAD DATE |
| | 6940ae22b743 | no | Centos 8-Stream amd64 (20201222_07:08) | x86_64 | CONTAINER | 126.81MB | Dec 23, 2020 at 2:41am (UTC) |
root@tryit-precise:~# lxc exec centos8stream bash
[root@centos8stream ~]# cat /etc/udev/rules.d/86-nm-unmanaged.rules
ENV{ID_NET_DRIVER}=="veth", ENV{NM_UNMANAGED}="0"
Seems the fix https://github.com/lxc/lxc-ci/pull/216 was not effective.
Discussed [here](https://discuss.linuxcontainers.org/t/1-6-lxd-containers-not-assigned-ipv4-ipv6-addresses), @tomponline suggests it's due to the tryit service using `macvlan` nictype.
