That’s indeed pretty odd. I just looked at the de.po file that makes the German translation and it’s correct. STATE isn’t translated so should cause a fallback to STATE whereas your system seems to fallback to the fr.po value.
I don’t see anything on our side which would cause this on our end so it’s most likely some issue with libc (which provides the gettext functions) or with the way the Gentoo package ships the .mo for LXD.
You may want to poke at the .mo on your system and grep for the french strings in the German file, just to make sure they didn’t get merged in there at package build time or something.
$ strings /usr/share/locale/de/LC_MESSAGES/lxd.mo
%s (%d more)
%s is not a directory
%v (interrupt two more times to force)
(none)
ALIAS
ALIASES
ARCHITECTURE
Accept certificate
Action (defaults to GET)
Add new remote servers
Alias name missing
Auto update: %s
Bytes received
Bytes sent
CREATED AT
Columns
Copy aliases from source
Could not create server cert dir
Created: %s
Creating %s
DESCRIPTION
EXPIRY DATE
FINGERPRINT
Invalid source %s
Invalid target %s
Make image public
More than one file to download, but target is not a directory
Remote admin password
Server certificate NACKed by user
Set the file's gid on push
Set the file's perms on push
Set the file's uid on push
Project-Id-Version: LXD
Report-Msgid-Bugs-To: lxc-devel@lists.linuxcontainers.org
PO-Revision-Date: 2019-12-12 14:53+0000
Last-Translator: St
phane Graber <stgraber@stgraber.org>
Language-Team: German <https://hosted.weblate.org/projects/linux-containers/lxd/de/>
Language: de
MIME-Version: 1.0
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: 8bit
Plural-Forms: nplurals=2; plural=n != 1;
X-Generator: Weblate 3.10-dev
%s (%d mehr)
%s ist kein Verzeichnis
%v (zwei weitere Male unterbrechen, um zu erzwingen)
(kein Wert)
ALIAS
ALIASES
ARCHITEKTUR
Akzeptiere Zertifikat
Aktion (Standard: GET)
Neue entfernte Server hinzuf
Aliasname fehlt
automatisches Update: %s
Bytes empfangen
Bytes gesendet
ERSTELLT AM
Spalten
Kopiere Aliasse von der Quelle
Kann Verzeichnis f
r Zertifikate auf dem Server nicht erstellen
Erstellt: %s
Erstelle %s
BESCHREIBUNG
ABLAUFDATUM
FINGERABDRUCK
ltige Quelle %s
ltiges Ziel %s
ffentliche Abbild
Mehr als eine Datei herunterzuladen, aber das Ziel ist kein Verzeichnis
Entferntes Administrator Passwort
Server Zertifikat vom Benutzer nicht akzeptiert
Setzt die gid der Datei beim
bertragen
Setzt die Dateiberechtigungen beim
bertragen
Setzt die uid der Datei beim
bertragen
I should mention that I do build the system with French support. But the locale settings are correct, so this still shouldn’t be happening.
It probably has something to do with glibc. This isn’t the only issue I’ve had with the new one.
Might be interesting to run an affected command under strace -f to see what translation files it’s opening and in what order.
Normally with LANG set to de_DE, it should really only open that one but I don’t know if the C library is looking for other configs or something. Looking at everything that’s open through strace may help track that too.
