Good day,
Im running Ubuntu 22.04 LTS incus 6.3.
After setting a static IP on a container, I’m getting a high CPU warning and Duplicate IP set warning in the logs. If I remove the container with the static, the warnings will disappear.
==> /var/log/ovn/ovn-northd.log <==
2024-07-31T09:16:17.595Z|02131|poll_loop|INFO|Dropped 5542 log messages in last 6 seconds (most recently, 0 seconds ago) due to excessive rate
2024-07-31T09:16:17.595Z|02132|poll_loop|INFO|wakeup due to [POLLIN] on fd 17 (192.168.10.50:35554<->192.168.10.50:6641) at lib/stream-fd.c:157 (71% CPU usage)
2024-07-31T09:16:23.594Z|02133|poll_loop|INFO|Dropped 5486 log messages in last 6 seconds (most recently, 0 seconds ago) due to excessive rate
2024-07-31T09:16:23.594Z|02134|poll_loop|INFO|wakeup due to [POLLIN] on fd 17 (192.168.10.50:35554<->192.168.10.50:6641) at lib/stream-fd.c:157 (72% CPU usage)
2024-07-31T09:16:29.595Z|02135|poll_loop|INFO|Dropped 5897 log messages in last 6 seconds (most recently, 0 seconds ago) due to excessive rate
2024-07-31T09:16:29.595Z|02136|poll_loop|INFO|wakeup due to [POLLIN] on fd 17 (192.168.10.50:35554<->192.168.10.50:6641) at lib/stream-fd.c:157 (74% CPU usage)
2024-07-31T09:16:31.093Z|02137|ipam|WARN|Dropped 58590 log messages in last 60 seconds (most recently, 0 seconds ago) due to excessive rate
2024-07-31T09:16:31.093Z|02138|ipam|WARN|6bad30e2-d319-4373-ad6f-eb35c476713d: Duplicate IP set: 10.12.220.250
I tried to launch the instance with a static IP.
inc launch images:alpine/edge/cloud --network ovn5 dnss01 --device eth0,ipv4.address=10.12.220.250
I also set the IP after the container was created.
inc launch images:alpine/edge/cloud --network ovn5 dnss01 --config ipv4.address=eth0,10.12.220.250
the OVN nbctl command shows no duplicates.
sudo ovn-nbctl --columns=name,dynamic_addresses,addresses list logical_switch_port
dynamic_addresses : "00:16:3e:2f:39:5f 10.12.220.2"
addresses : ["00:16:3e:2f:39:5f dynamic"]
dynamic_addresses : []
addresses : [router]
addresses : ["00:16:3e:85:07:c5 10.12.220.250"]
addresses : [unknown]
