OVN Load Balancer on Incus Cluster - ARP Requests and Intermittent Connectivity Issue
I’m running an Incus cluster with an OVN network setup using a bridge named incus-bridge as uplink. The load balancer IP 10.12.10.170/32 forwards to an nginx container at 10.6.31.5. Initially, I can curl the load balancer IP, but after some time it stops responding.
Using tcpdump on incus-bridge, I see continuous ARP requests for 10.12.10.170 with no replies. Restarting ovn-controller temporarily fixes connectivity. The IP 10.12.10.170 is not assigned to any host interface; I expect OVN to manage it via the physical interface ens160.
nginx container detail:
nginx-test | RUNNING | 10.6.31.5 (eth0) | CONTAINER (APP) | cluster-node-03
incus-bridge config manifest:
ipv4.address: 10.6.30.1/16
ipv4.dhcp: "true"
ipv4.dhcp.ranges: 10.6.30.1-10.6.30.254
ipv4.nat: "true"
ipv4.ovn.ranges: 10.6.31.1-10.6.31.254
ipv4.routes: 10.12.10.170/32, 10.12.10.171/32, 10.12.10.172/32
cluster-default-network config manifest:
bridge.mtu: "1442"
ipv4.address: 10.6.31.1/24
ipv4.nat: "true"
network: incus-bridge
volatile.network.ipv4.address: 10.6.31.1
Load balancer config for 10.12.10.170:
backends:
- name: nginx
  target_port: "80"
  target_address: 10.6.31.5
ports:
- protocol: tcp
  listen_port: "80"
 target_backend:
 - nginx
listen_address: 10.12.10.170
Tcpdump outputs:
08:16:44.833221 ARP, Request who-has 10.12.10.170 tell ubuntu2204, length 28
08:16:45.857252 ARP, Request who-has 10.12.10.170 tell ubuntu2204, length 28
How should OVN handle this floating IP to answer ARP requests reliably and avoid intermittent failures? Is there a recommended way to bind or assign the IP on the physical interface or host side?
Thanks!
What version of OVN are you running?
latest version in official Ubuntu 24.04.3 LTS repository:
$ ovn-controller --version
ovn-controller 24.03.6
Open vSwitch Library 3.3.4
OpenFlow versions 0x6:0x6
SB DB Schema 20.33.0
I can reach the OVN load balancer from outside of cluster network by adding the address to any interface then delete it after few seconds and restart ovn-controller (it work for few minutes too and I think it work because of DHCP lease)
ip a add 10.12.10.170/24 dev ens160
ip a del 10.12.10.170/24 dev ens160
systemctl restart ovn-controller.service
but still facing same issue, no replies to ARP requests after some time
Hmm, I tried to solve the issue for few days without luck,
Is OVN on Bridge interface don’t support load balance?
also should I can access the VM/Container OVN from host without load balancer (because I cannot)?
