OVN network forward ARP issues
I am having trouble with network forwarding in Incus. I set up a bridge network and the corresponding child OVN network, then created a network forward to one of my instances. After a lot of debugging and searching, I found a thread that mentioned ARP requests aren’t being replied to. I can reproduce the issue on a single instance (no cluster). It looks like this might be a regression in OVN that was fixed before but seems to have come back.
This was all tested on a new Ubuntu 24.04 VM using the zabbly/incus and stgraber/ovn-stable PPAs.
username@incus-test:~$ incus --version
6.15
username@incus-test:~$ ovs-vsctl --version
ovs-vsctl (Open vSwitch) 3.4.0
DB Schema 8.7.0
username@incus-test:~$ ovn-nbctl --version
ovn-nbctl 24.03.3
Open vSwitch Library 3.4.0
DB Schema 7.3.0
username@incus-test:~$ ovn-sbctl --version
ovn-sbctl 24.03.3
DB Schema 20.33.0
My network config:
username@incus-test:~$ ip a
    inet6 ::1/128 scope host noprefixroute
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 52:54:00:d5:15:36 brd ff:ff:ff:ff:ff:ff
    inet 192.168.122.125/24 brd 192.168.122.255 scope global dynamic noprefixroute enp1s0
       valid_lft 2645sec preferred_lft 2645sec
    inet6 fe80::5054:ff:fed5:1536/64 scope link
3: ovs-system: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 56:54:21:81:fa:50 brd ff:ff:ff:ff:ff:ff
4: br-int: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 22:ae:8e:46:46:77 brd ff:ff:ff:ff:ff:ff
5: incusbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 10:66:6a:df:13:7d brd ff:ff:ff:ff:ff:ff
    inet 100.64.0.1/11 brd 100.95.255.255 scope global incusbr0
21: incusovn1b@incusovn1a: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master ovs-system state UP group default qlen 1000
    link/ether 3a:d7:cb:37:1f:59 brd ff:ff:ff:ff:ff:ff
22: incusovn1a@incusovn1b: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master incusbr0 state UP group default qlen 1000
    link/ether 4a:9a:34:b6:73:71 brd ff:ff:ff:ff:ff:ff
23: incusovn1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 32:0d:15:26:d0:43 brd ff:ff:ff:ff:ff:ff
27: veth2a75932d@if26: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master ovs-system state UP group default qlen 1000
    link/ether b2:59:e9:d6:df:0b brd ff:ff:ff:ff:ff:ff link-netnsid 0
username@incus-test:~$ ip route
default via 192.168.122.1 dev enp1s0 proto dhcp src 192.168.122.125 metric 100
100.64.0.0/11 dev incusbr0 proto kernel scope link src 100.64.0.1
100.96.0.0/11 dev incusbr0 proto static scope link
192.168.122.0/24 dev enp1s0 proto kernel scope link src 192.168.122.125 metric 100
Incus network config:
username@incus-test:~$ incus network ls
|    NAME    |   TYPE   | MANAGED |     IPV4      | IPV6 | DESCRIPTION | USED BY |  STATE  |
| br-int     | bridge   | NO      |               |      |             | 0       |         |
| enp1s0     | physical | NO      |               |      |             | 0       |         |
| incusbr0   | bridge   | YES     | 100.64.0.1/11 | none |             | 1       | CREATED |
| incusovn1  | bridge   | NO      |               |      |             | 0       |         |
| incusovn1a | unknown  | NO      |               |      |             | 0       |         |
| incusovn1b | unknown  | NO      |               |      |             | 0       |         |
| lo         | loopback | NO      |               |      |             | 0       |         |
| ovs-system | unknown  | NO      |               |      |             | 0       |         |
username@incus-test:~$ incus network ls --project lab-1
| n-4-uplink | ovn  | YES     | 192.168.0.1/24 | none |             | 1       | CREATED |
Incus network details:
username@incus-test:~$ incus network show incusbr0
  bridge.mtu: "1500"
  dns.mode: none
  dns.nameservers: 8.8.8.8,8.8.4.4,1.1.1.1,1.0.0.1
  ipv4.address: 100.64.0.1/11
  ipv4.dhcp.ranges: 100.64.0.2-100.64.0.2
  ipv4.nat: "true"
  ipv4.ovn.ranges: 100.64.0.3-100.95.255.254
  ipv4.routes: 100.96.0.0/11
  ipv4.routing: "true"
  ipv6.address: none
type: bridge
- /1.0/networks/n-4-uplink?project=lab-1
managed: true
status: Created
locations:
- none
project: default
username@incus-test:~$ incus network show n-4-uplink --project lab-1
  bridge.mtu: "1500"
  ipv4.address: 192.168.0.1/24
  ipv4.nat: "true"
  ipv6.address: none
  network: incusbr0
  volatile.network.ipv4.address: 100.64.0.3
type: ovn
- /1.0/instances/i-4-1?project=lab-1
managed: true
status: Created
locations:
- none
project: lab-1
username@incus-test:~$ incus network forward show n-4-uplink 100.96.0.10 --project lab-1
config: {}
ports:
- description: ""
  protocol: tcp
  listen_port: "1024"
  target_port: "80"
  target_address: 192.168.0.2
  snat: false
listen_address: 100.96.0.10
Running curl 100.96.0.10:1024 results in the following trace:
username@incus-test:~$ sudo tcpdump -i incusbr0
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on incusbr0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
21:42:50.526354 ARP, Request who-has 100.96.0.10 tell incus-test, length 28
21:42:51.542105 ARP, Request who-has 100.96.0.10 tell incus-test, length 28
21:42:52.566009 ARP, Request who-has 100.96.0.10 tell incus-test, length 28
^C <killed after several minutes>
3 packets captured
3 packets received by filter
0 packets dropped by kernel
Using the default firewall rules:
table inet filter {
	chain input {
		type filter hook input priority filter; policy accept;
	chain forward {
		type filter hook forward priority filter; policy accept;
	chain output {
		type filter hook output priority filter; policy accept;
table inet incus {
	chain pstrt.incusbr0 {
		type nat hook postrouting priority srcnat; policy accept;
		ip saddr 100.64.0.0/11 ip daddr != 100.64.0.0/11 masquerade
	chain fwd.incusbr0 {
		ip version 4 oifname "incusbr0" accept
		ip version 4 iifname "incusbr0" accept
	chain in.incusbr0 {
		iifname "incusbr0" tcp dport 53 accept
		iifname "incusbr0" udp dport 53 accept
		iifname "incusbr0" icmp type { destination-unreachable, time-exceeded, parameter-problem } accept
		iifname "incusbr0" udp dport 67 accept
		iifname "incusbr0" ip protocol udp udp checksum set 0
	chain out.incusbr0 {
		oifname "incusbr0" tcp sport 53 accept
		oifname "incusbr0" udp sport 53 accept
		oifname "incusbr0" icmp type { destination-unreachable, time-exceeded, parameter-problem } accept
		oifname "incusbr0" udp sport 67 accept
		oifname "incusbr0" ip protocol udp udp checksum set 0
ovs/ovn network details:
username@incus-test:~$ sudo ovs-vsctl show
4e60ff7f-7a18-4e54-82d1-b248490a6032
    Bridge br-int
        fail_mode: secure
        datapath_type: system
        Port br-int
            Interface br-int
                type: internal
        Port veth2a75932d
            Interface veth2a75932d
        Port patch-br-int-to-incus-net5-ls-ext-lsp-provider
            Interface patch-br-int-to-incus-net5-ls-ext-lsp-provider
                type: patch
                options: {peer=patch-incus-net5-ls-ext-lsp-provider-to-br-int}
    Bridge incusovn1
        Port incusovn1
            Interface incusovn1
        Port incusovn1b
            Interface incusovn1b
        Port patch-incus-net5-ls-ext-lsp-provider-to-br-int
            Interface patch-incus-net5-ls-ext-lsp-provider-to-br-int
                type: patch
                options: {peer=patch-br-int-to-incus-net5-ls-ext-lsp-provider}
    ovs_version: "3.4.0"
username@incus-test:~$ sudo ovn-nbctl show
switch 61d9133c-d8d0-4662-854f-92dcb20c692c (incus-net5-ls-int)
    port incus-net5-instance-639da7f5-e0a2-47e1-8e43-b016d8450378-eth0
        addresses: ["10:66:6a:25:fa:fc 192.168.0.2"]
    port incus-net5-ls-int-lsp-router
        type: router
        router-port: incus-net5-lr-lrp-int
switch a80e0df8-16ca-466b-a34a-4d8df476b217 (incus-net5-ls-ext)
    port incus-net5-ls-ext-lsp-router
        type: router
        router-port: incus-net5-lr-lrp-ext
    port incus-net5-ls-ext-lsp-provider
        type: localnet
        addresses: ["unknown"]
router 5e072d2d-cac4-48eb-b1f8-bcf704b839a3 (incus-net5-lr)
    port incus-net5-lr-lrp-int
        mac: "10:66:6a:c7:e8:95"
        networks: ["192.168.0.1/24"]
    port incus-net5-lr-lrp-ext
        networks: ["100.64.0.3/11"]
    nat 30b0cae2-565f-4145-a23b-27400d0c64d2
        external ip: "100.64.0.3"
        logical ip: "192.168.0.0/24"
        type: "snat"
username@incus-test:~$ sudo ovn-sbctl show
Chassis "30316039-f75a-4171-bbcd-2c9bd7b315c5"
    hostname: incus-test
    Encap geneve
        ip: "127.0.0.1"
        options: {csum="true"}
    Port_Binding cr-incus-net5-lr-lrp-ext
    Port_Binding incus-net5-instance-639da7f5-e0a2-47e1-8e43-b016d8450378-eth0
username@incus-test:~$ sudo ovn-nbctl list load_balancer
_uuid               : 6dc2d54c-86a3-4b32-8cac-ec5c69b16f40
external_ids        : {}
health_check        : []
ip_port_mappings    : {}
options             : {}
protocol            : tcp
selection_fields    : []
vips                : {"100.96.0.10:1024"="192.168.0.2:80"}
The ARP reply bit is missing here (As described here)
username@incus-test:~$ sudo ovn-sbctl list logical_flow  | grep 100.96.0.10
match               : "ct.new && ip4.dst == 100.96.0.10 && tcp.dst == 1024"
actions             : "reg1 = 100.96.0.10; reg2[0..15] = 1024; ct_lb_mark;"
match               : "reg0[2] == 1 && ip4.dst == 100.96.0.10 && tcp.dst == 1024"
match               : "ip && ip4.dst == 100.96.0.10"
match               : "reg7 == 0 && ip4.dst == 100.96.0.10/32"
match               : "ct.new && !ct.rel && ip4 && ip4.dst == 100.96.0.10 && tcp && tcp.dst == 1024 && is_chassis_resident(\"cr-incus-net5-lr-lrp-ext\")"
Can you help me figure out if it’s my setup or if it’s really an OVN regression? Thanks!
Hello @julio641742, did you manage to resolve it?
