I’ve set up an OVN network based on these directions and I also followed the YT video for “OVN and a LXD cluster”.
I’m running this in a cluster (virtualized for testing) of 3 machines. Each host has a br0 bridge interface. The directions are very descriptive and I followed them with seemingly no issues. I created the UPLINK network and all went fine and then created the “my-ovn” network also with no errors.
The only diversion from the directions was the ipv6 settings. Currently ipv6 is disabled on all 3 hosts so I omitted that from the creation of the UPLINK:
I’m not seeing errors in the northbound or southbound ovn logs. When I create an instance with the “my-ovn” network it never gets an IP address. Any ideas what I may be missing?
Thanks!
EDIT: One quick addition - if I tail the ovn-controller.log on the first host I see this when I create a new instance with the my-ovn network:
2024-02-09T18:25:09.168Z|00096|binding|INFO|Claiming lport incus-net8-instance-f0111668-b866-4a6b-b29c-ad158f755f7e-eth0 for this chassis.
2024-02-09T18:25:09.169Z|00097|binding|INFO|incus-net8-instance-f0111668-b866-4a6b-b29c-ad158f755f7e-eth0: Claiming 00:16:3e:20:33:97 dynamic
2024-02-09T18:25:09.171Z|00098|binding|INFO|Setting lport incus-net8-instance-f0111668-b866-4a6b-b29c-ad158f755f7e-eth0 ovn-installed in OVS
2024-02-09T18:25:09.180Z|00099|binding|INFO|Setting lport incus-net8-instance-f0111668-b866-4a6b-b29c-ad158f755f7e-eth0 up in Southbound
Checking the onv-northd.log it even shows this when I create the new instance:
2024-02-09T18:25:09.003Z|00079|northd|INFO|Assigned dynamic IPv4 address '10.127.3.2' to port 'incus-net8-instance-f0111668-b866-4a6b-b29c-ad158f755f7e-eth0'
Right, so it’s showing state=down and remote_state=down which suggests that your hosts are unable to communicate for the Geneve tunnels.
I’d first make sure that you can ping the remote_ip listed in ovs-vsctl, if you can, then please look for firewalls on all affected machines as you may have something in place which prevents the tunnel traffic from going out or coming in.
Yep the hosts can all ping each other. This is in a temp VM environment that I’m testing with where all hosts are running via qemu. They’re running a basic Debian 12 install and afaik that doesn’t ship with a firewall installed.
Could it be that I’m creating the UPLINK incorrectly? Based on the docs:
you must specify either an unmanaged bridge interface or an unused physical interface as the parent for the physical network that is used for OVN uplink. The instructions assume that you are using a manually created unmanaged bridge.
The network on the hosts is using a bridge interface br0 as follows:
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel master br0 state UP group default qlen 1000
link/ether 52:54:00:1f:a4:e1 brd ff:ff:ff:ff:ff:ff
5: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 96:54:c1:c3:91:7b brd ff:ff:ff:ff:ff:ff
inet 192.168.122.101/24 brd 192.168.122.255 scope global br0
Will do. So it sounds like this isn’t an issue with Incus but is something related to OVN not creating the required tunnels to work properly. I’ll investigate it from that direction.
Yeah, exactly, those tunnels should be live regardless of what kind of configuration may have been done in Incus, so the fact that they’re not is quite suspicious and would explain much of the current behavior.
