Hi All!
I’m attempting to get OVN working again, but this time on an ubuntu 20:04 cloud host in hetzner (last time I failed as I was using proxmox/debian buster).
However, still having a few issues, but I’m not sure if its down to the lack of resources of the server, it only has 2GB of RAM not sure if that makes a difference.
So far I’ve tried the following:
sudo apt install ovn-host ovn-central
ovs-vsctl set open_vswitch . external_ids:ovn-remote=unix:/var/run/ovn/ovnsb_db.sock external_ids:ovn-encap-type=geneve external_ids:ovn-encap-ip=10.55.0.42
lxc network set lxdbr0 ipv4.dhcp.ranges=10.0.0.10-10.0.0.200 ipv4.ovn.ranges=10.42.10.5-10.42.10.200
lxc network create ovn0 --type=ovn network=lxdbr0
lxc launch ubuntu:20.04 mattersmost -s zfs1 -n ovn0
it seems to suceed, no errors, but then the container won’t start because it looks as though the ovn0 bridge has not been created?
I see the following:
root@p42:~# ip -br a
lo UNKNOWN 127.0.0.1/8 ::1/128
eth0 UP 159.69.42.91/32 2a01:4f8:c2c:7bbc::1/64 fe80::9400:ff:fe75:d6a9/64
ovs-system DOWN
lxdovn1 DOWN
br-int DOWN
ztks5yas3r UNKNOWN 10.55.0.42/24 fd17:d709:436c:8908:1d99:9359:fe6b:8460/88 fe80::1c51:77ff:fe07:c769/64
docker0 DOWN 172.17.0.1/16
br-30b0e255e043 UP 172.19.0.1/16 fe80::42:bfff:fea6:b3c8/64
docker_gwbridge DOWN 172.18.0.1/16
vethd54da4a@if10 UP fe80::449e:a8ff:feb4:5226/64
lxdbr0 UP 10.42.10.1/24 fd42:5bf8:7fd5:119a::1/64 fe80::216:3eff:fe86:d191/64
lxdovn1b@lxdovn1a UP
lxdovn1a@lxdovn1b UP
lxdbr1 UP 10.42.11.1/24 fd42:23a3:d094:170d::1/64 fe80::216:3eff:fe6e:43af/64
lxdovn3b@lxdovn3a UP
lxdovn3a@lxdovn3b UP
lxdovn3 DOWN
root@p42:~# lxc network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY |
| br-30b0e255e043 | bridge | NO | | | | 0 |
| br-int | bridge | NO | | | | 0 |
| docker0 | bridge | NO | | | | 0 |
| docker_gwbridge | bridge | NO | | | | 0 |
| eth0 | physical | NO | | | | 0 |
| lxdbr0 | bridge | YES | 10.42.10.1/24 | fd42:5bf8:7fd5:119a::1/64 | | 1 |
| lxdbr1 | bridge | YES | 10.42.11.1/24 | fd42:23a3:d094:170d::1/64 | | 1 |
| lxdovn1 | bridge | NO | | | | 0 |
| lxdovn3 | bridge | NO | | | | 0 |
| ovn0 | ovn | YES | 10.113.240.1/24 | fd42:24d6:6ce6:b0f2::1/64 | | 1 |
| ovn1 | ovn | YES | 10.50.215.1/24 | fd42:617a:48ee:2454::1/64 | | 1 |
root@p42:~# ovs-vsctl show
eb0d809a-cdf8-440a-8200-929412dee20a
Bridge lxdovn1
Port lxdovn1
Interface lxdovn1
type: internal
Port lxdovn1b
Interface lxdovn1b
Port patch-lxd-net2-ls-ext-lsp-provider-to-br-int
Interface patch-lxd-net2-ls-ext-lsp-provider-to-br-int
type: patch
options: {peer=patch-br-int-to-lxd-net2-ls-ext-lsp-provider}
Bridge br-int
fail_mode: secure
Port patch-br-int-to-lxd-net2-ls-ext-lsp-provider
Interface patch-br-int-to-lxd-net2-ls-ext-lsp-provider
type: patch
options: {peer=patch-lxd-net2-ls-ext-lsp-provider-to-br-int}
Port br-int
Interface br-int
type: internal
Port patch-br-int-to-lxd-net4-ls-ext-lsp-provider
Interface patch-br-int-to-lxd-net4-ls-ext-lsp-provider
type: patch
options: {peer=patch-lxd-net4-ls-ext-lsp-provider-to-br-int}
Bridge lxdovn3
Port lxdovn3b
Interface lxdovn3b
Port lxdovn3
Interface lxdovn3
type: internal
Port patch-lxd-net4-ls-ext-lsp-provider-to-br-int
Interface patch-lxd-net4-ls-ext-lsp-provider-to-br-int
type: patch
options: {peer=patch-br-int-to-lxd-net4-ls-ext-lsp-provider}
ovs_version: "2.13.0"
root@p42:~# ovn-nbctl show
switch c8f82ec8-454b-49e3-9197-9b8218e131fe (net0)
port port1
addresses: ["dynamic"]
switch 22676f1d-fe14-4dec-a730-41cd1c9cdeb2 (lxd-net4-ls-ext)
port lxd-net4-ls-ext-lsp-router
type: router
router-port: lxd-net4-lr-lrp-ext
port lxd-net4-ls-ext-lsp-provider
type: localnet
addresses: ["unknown"]
switch d4e4c4a2-139f-4625-b473-2a3e35bed875 (lxd-net2-ls-int)
port lxd-net2-ls-int-lsp-router
type: router
router-port: lxd-net2-lr-lrp-int
switch 43657317-d1aa-4af0-b378-2b8cce8541ae (lxd-net2-ls-ext)
port lxd-net2-ls-ext-lsp-router
type: router
router-port: lxd-net2-lr-lrp-ext
port lxd-net2-ls-ext-lsp-provider
type: localnet
switch 9223579f-fd16-42dc-bfb1-f79caf9bcdfe (lxd-net4-ls-int)
port lxd-net4-ls-int-lsp-router
type: router
router-port: lxd-net4-lr-lrp-int
router 3e096a94-9d8a-4667-8b4c-8775e9c0a1a4 (lxd-net2-lr)
port lxd-net2-lr-lrp-ext
mac: "00:16:3e:0d:ac:29"
networks: ["10.42.10.5/24", "fd42:5bf8:7fd5:119a:216:3eff:fe0d:ac29/64"]
port lxd-net2-lr-lrp-int
networks: ["10.113.240.1/24", "fd42:24d6:6ce6:b0f2::1/64"]
nat 06946f37-b934-47c4-8550-705c39cc2fe6
external ip: "fd42:5bf8:7fd5:119a:216:3eff:fe0d:ac29"
logical ip: "fd42:24d6:6ce6:b0f2::/64"
type: "snat"
nat 8500c690-7239-4896-92d6-e78c41745818
external ip: "10.42.10.5"
logical ip: "10.113.240.0/24"
type: "snat"
router b202cf2f-8c40-4fcb-b5cf-a34008e998f9 (lxd-net4-lr)
port lxd-net4-lr-lrp-ext
mac: "00:16:3e:f4:76:04"
networks: ["10.42.11.201/24", "fd42:23a3:d094:170d:216:3eff:fef4:7604/64"]
port lxd-net4-lr-lrp-int
networks: ["10.50.215.1/24", "fd42:617a:48ee:2454::1/64"]
nat 58fde284-2601-45e5-b6c7-315058ed44b9
external ip: "10.42.11.201"
logical ip: "10.50.215.0/24"
type: "snat"
nat ae739baf-b210-4874-ac55-b99142e5ba07
external ip: "fd42:23a3:d094:170d:216:3eff:fef4:7604"
logical ip: "fd42:617a:48ee:2454::/64"
type: "snat
root@p42:~# ovs-vsctl list open_vswitch
_uuid : eb0d809a-cdf8-440a-8200-929412dee20a
bridges : [4d480b5a-ad40-401b-a13f-e031d1aac443, 6ca35c00-536f-4924-8ef6-98b4893427cc, f0d1f553-634f-4cfb-ad08-95c184b9324c]
cur_cfg : 9
datapath_types : [netdev, system]
datapaths : {}
db_version : "8.2.0"
dpdk_initialized : false
dpdk_version : none
external_ids : {hostname=p42, ovn-bridge-mappings="lxdbr0:lxdovn1,lxdbr1:lxdovn3", ovn-encap-ip="10.55.0.42", ovn-encap-type=geneve, ovn-remote="tcp:10.55.0.42:6642", rundir="/var/run/openvswitch", system-id="d3002a31-8cd5-44ee-8e08-271cba3ca0c0"}
iface_types : [erspan, geneve, gre, internal, ip6erspan, ip6gre, lisp, patch, stt, system, tap, vxlan]
manager_options : []
next_cfg : 9
other_config : {}
ovs_version : "2.13.0"
ssl : []
statistics : {}
system_type : ubuntu
system_version : "20.04"
I have also tried the following:
sudo ovs-vsctl set open_vswitch . external_ids:ovn-remote=unix:/var/run/ovn/ovnsb_db.sock external_ids:ovn-encap-type=geneve external_ids:ovn-encap-ip=127.0.0.1
lxc network set lxdbr1 ipv4.dhcp.ranges=10.42.11.5-10.42.11.200 ipv4.ovn.ranges=10.42.11.201-10.42.11.250
and the logs
root@p42:/var/log/openvswitch# ls
ovsdb-server.log ovs-vswitchd.log
root@p42:/var/log/openvswitch# cat ovsdb-server.log
2020-12-21T14:51:45.740Z|00001|vlog|INFO|opened log file /var/log/openvswitch/ovsdb-server.log
2020-12-21T14:51:45.765Z|00002|ovsdb_server|INFO|ovsdb-server (Open vSwitch) 2.13.0
2020-12-21T14:51:55.774Z|00003|memory|INFO|4732 kB peak resident set size after 10.0 seconds
2020-12-21T14:51:55.774Z|00004|memory|INFO|cells:39 monitors:3 sessions:2
2020-12-21T14:58:35.207Z|00005|jsonrpc|WARN|unix#10: receive error: Connection reset by peer
2020-12-21T14:58:35.207Z|00006|reconnect|WARN|unix#10: connection dropped (Connection reset by peer)
2020-12-21T15:05:40.042Z|00007|jsonrpc|WARN|unix#23: send error: Broken pipe
2020-12-21T15:05:40.042Z|00008|reconnect|WARN|unix#23: connection dropped (Broken pipe)
2020-12-21T15:11:37.412Z|00001|vlog|INFO|opened log file /var/log/openvswitch/ovsdb-server.log
2020-12-21T15:11:37.438Z|00002|ovsdb_server|INFO|ovsdb-server (Open vSwitch) 2.13.0
2020-12-21T15:11:47.447Z|00003|memory|INFO|4640 kB peak resident set size after 10.0 seconds
2020-12-21T15:11:47.447Z|00004|memory|INFO|cells:382 monitors:3 sessions:2
2020-12-21T15:19:09.761Z|00005|jsonrpc|WARN|unix#21: send error: Broken pipe
2020-12-21T15:19:09.761Z|00006|reconnect|WARN|unix#21: connection dropped (Broken pipe)
root@p42:/var/log/openvswitch# cat ovs-vswitchd.log
2020-12-21T14:51:45.944Z|00002|vlog|INFO|opened log file /var/log/openvswitch/ovs-vswitchd.log
2020-12-21T14:51:45.955Z|00003|ovs_numa|INFO|Discovered 2 CPU cores on NUMA node 0
2020-12-21T14:51:45.955Z|00004|ovs_numa|INFO|Discovered 1 NUMA nodes and 2 CPU cores
2020-12-21T14:51:45.955Z|00005|reconnect|INFO|unix:/var/run/openvswitch/db.sock: connecting...
2020-12-21T14:51:45.955Z|00006|reconnect|INFO|unix:/var/run/openvswitch/db.sock: connected
2020-12-21T14:51:45.966Z|00007|bridge|INFO|ovs-vswitchd (Open vSwitch) 2.13.0
2020-12-21T14:54:50.338Z|00008|memory|INFO|13144 kB peak resident set size after 184.4 seconds
2020-12-21T14:54:50.344Z|00009|ofproto_dpif|INFO|system@ovs-system: Datapath supports recirculation
2020-12-21T14:54:50.344Z|00010|ofproto_dpif|INFO|system@ovs-system: VLAN header stack length probed as 2
2020-12-21T14:54:50.344Z|00011|ofproto_dpif|INFO|system@ovs-system: MPLS label stack length probed as 1
2020-12-21T14:54:50.344Z|00012|ofproto_dpif|INFO|system@ovs-system: Datapath supports truncate action
2020-12-21T14:54:50.344Z|00013|ofproto_dpif|INFO|system@ovs-system: Datapath supports unique flow ids
2020-12-21T14:54:50.344Z|00014|ofproto_dpif|INFO|system@ovs-system: Datapath supports clone action
2020-12-21T14:54:50.345Z|00015|ofproto_dpif|INFO|system@ovs-system: Max sample nesting level probed as 10
2020-12-21T14:54:50.345Z|00016|ofproto_dpif|INFO|system@ovs-system: Datapath supports eventmask in conntrack action
2020-12-21T14:54:50.345Z|00017|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_clear action
2020-12-21T14:54:50.345Z|00018|ofproto_dpif|INFO|system@ovs-system: Max dp_hash algorithm probed to be 0
2020-12-21T14:54:50.345Z|00019|ofproto_dpif|INFO|system@ovs-system: Datapath supports check_pkt_len action
2020-12-21T14:54:50.345Z|00020|ofproto_dpif|INFO|system@ovs-system: Datapath supports timeout policy in conntrack action
2020-12-21T14:54:50.345Z|00021|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_state
2020-12-21T14:54:50.345Z|00022|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_zone
2020-12-21T14:54:50.345Z|00023|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_mark
2020-12-21T14:54:50.345Z|00024|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_label
2020-12-21T14:54:50.345Z|00025|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_state_nat
2020-12-21T14:54:50.345Z|00026|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_orig_tuple
2020-12-21T14:54:50.345Z|00027|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_orig_tuple6
2020-12-21T14:54:50.345Z|00028|ofproto_dpif|INFO|system@ovs-system: Datapath does not support IPv6 ND Extensions
2020-12-21T14:54:50.394Z|00029|bridge|INFO|bridge br-int: added interface br-int on port 65534
2020-12-21T14:54:50.395Z|00030|bridge|INFO|bridge br-int: using datapath ID 0000025ca36c2449
2020-12-21T14:54:50.395Z|00031|connmgr|INFO|br-int: added service controller "punix:/var/run/openvswitch/br-int.mgmt"
2020-12-21T14:55:00.339Z|00032|memory|INFO|peak resident set size grew 189% in last 10.0 seconds, from 13144 kB to 37956 kB
2020-12-21T14:55:00.339Z|00033|memory|INFO|handlers:1 ofconns:2 ports:1 revalidators:1 rules:9
2020-12-21T14:55:01.346Z|00034|connmgr|INFO|br-int<->unix#0: 6 flow_mods 10 s ago (5 adds, 1 deletes)
2020-12-21T14:58:35.858Z|00035|bridge|INFO|bridge lxdovn1: added interface lxdovn1 on port 65534
2020-12-21T14:58:35.858Z|00036|bridge|INFO|bridge lxdovn1: using datapath ID 00005a0b484d1b40
2020-12-21T14:58:35.858Z|00037|connmgr|INFO|lxdovn1: added service controller "punix:/var/run/openvswitch/lxdovn1.mgmt"
2020-12-21T14:58:35.881Z|00038|bridge|INFO|bridge lxdovn1: added interface lxdovn1b on port 1
2020-12-21T14:58:35.920Z|00039|bridge|INFO|bridge lxdovn1: added interface patch-lxd-net2-ls-ext-lsp-provider-to-br-int on port 2
2020-12-21T14:58:35.921Z|00040|bridge|INFO|bridge br-int: added interface patch-br-int-to-lxd-net2-ls-ext-lsp-provider on port 1
2020-12-21T14:58:45.407Z|00041|connmgr|INFO|br-int<->unix#0: 627 flow_mods in the 1 s starting 10 s ago (625 adds, 2 modifications)
2020-12-21T15:11:28.431Z|00042|bridge|INFO|bridge lxdovn1: deleted interface lxdovn1 on port 65534
2020-12-21T15:11:28.431Z|00043|bridge|INFO|bridge lxdovn1: deleted interface lxdovn1b on port 1
2020-12-21T15:11:28.431Z|00044|bridge|INFO|bridge lxdovn1: deleted interface patch-lxd-net2-ls-ext-lsp-provider-to-br-int on port 2
2020-12-21T15:11:28.432Z|00045|bridge|INFO|bridge br-int: deleted interface br-int on port 65534
2020-12-21T15:11:28.432Z|00046|bridge|INFO|bridge br-int: deleted interface patch-br-int-to-lxd-net2-ls-ext-lsp-provider on port 1
2020-12-21T15:11:37.618Z|00002|vlog|INFO|opened log file /var/log/openvswitch/ovs-vswitchd.log
2020-12-21T15:11:37.637Z|00003|ovs_numa|INFO|Discovered 2 CPU cores on NUMA node 0
2020-12-21T15:11:37.637Z|00004|ovs_numa|INFO|Discovered 1 NUMA nodes and 2 CPU cores
2020-12-21T15:11:37.638Z|00005|reconnect|INFO|unix:/var/run/openvswitch/db.sock: connecting...
2020-12-21T15:11:37.638Z|00006|reconnect|INFO|unix:/var/run/openvswitch/db.sock: connected
2020-12-21T15:11:37.650Z|00007|ofproto_dpif|INFO|system@ovs-system: Datapath supports recirculation
2020-12-21T15:11:37.650Z|00008|ofproto_dpif|INFO|system@ovs-system: VLAN header stack length probed as 2
2020-12-21T15:11:37.650Z|00009|ofproto_dpif|INFO|system@ovs-system: MPLS label stack length probed as 1
2020-12-21T15:11:37.650Z|00010|ofproto_dpif|INFO|system@ovs-system: Datapath supports truncate action
2020-12-21T15:11:37.650Z|00011|ofproto_dpif|INFO|system@ovs-system: Datapath supports unique flow ids
2020-12-21T15:11:37.650Z|00012|ofproto_dpif|INFO|system@ovs-system: Datapath supports clone action
2020-12-21T15:11:37.650Z|00013|ofproto_dpif|INFO|system@ovs-system: Max sample nesting level probed as 10
2020-12-21T15:11:37.650Z|00014|ofproto_dpif|INFO|system@ovs-system: Datapath supports eventmask in conntrack action
2020-12-21T15:11:37.650Z|00015|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_clear action
2020-12-21T15:11:37.650Z|00016|ofproto_dpif|INFO|system@ovs-system: Max dp_hash algorithm probed to be 0
2020-12-21T15:11:37.650Z|00017|ofproto_dpif|INFO|system@ovs-system: Datapath supports check_pkt_len action
2020-12-21T15:11:37.650Z|00018|ofproto_dpif|INFO|system@ovs-system: Datapath supports timeout policy in conntrack action
2020-12-21T15:11:37.650Z|00019|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_state
2020-12-21T15:11:37.650Z|00020|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_zone
2020-12-21T15:11:37.650Z|00021|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_mark
2020-12-21T15:11:37.650Z|00022|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_label
2020-12-21T15:11:37.650Z|00023|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_state_nat
2020-12-21T15:11:37.650Z|00024|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_orig_tuple
2020-12-21T15:11:37.650Z|00025|ofproto_dpif|INFO|system@ovs-system: Datapath supports ct_orig_tuple6
2020-12-21T15:11:37.650Z|00026|ofproto_dpif|INFO|system@ovs-system: Datapath does not support IPv6 ND Extensions
2020-12-21T15:11:37.711Z|00027|dpif|WARN|system@ovs-system: failed to query port patch-lxd-net2-ls-ext-lsp-provider-to-br-int: Invalid argument
2020-12-21T15:11:37.712Z|00028|dpif|WARN|system@ovs-system: failed to query port patch-br-int-to-lxd-net2-ls-ext-lsp-provider: Invalid argument
2020-12-21T15:11:37.715Z|00029|bridge|INFO|bridge lxdovn1: added interface lxdovn1 on port 65534
2020-12-21T15:11:37.722Z|00030|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:37.722Z|00031|bridge|INFO|bridge lxdovn1: added interface patch-lxd-net2-ls-ext-lsp-provider-to-br-int on port 2
2020-12-21T15:11:37.726Z|00032|bridge|INFO|bridge br-int: added interface br-int on port 65534
2020-12-21T15:11:37.726Z|00033|bridge|INFO|bridge br-int: added interface patch-br-int-to-lxd-net2-ls-ext-lsp-provider on port 1
2020-12-21T15:11:37.726Z|00034|bridge|INFO|bridge lxdovn1: using datapath ID 00005a0b484d1b40
2020-12-21T15:11:37.726Z|00035|connmgr|INFO|lxdovn1: added service controller "punix:/var/run/openvswitch/lxdovn1.mgmt"
2020-12-21T15:11:37.728Z|00036|bridge|INFO|bridge br-int: using datapath ID 0000025ca36c2449
2020-12-21T15:11:37.728Z|00037|connmgr|INFO|br-int: added service controller "punix:/var/run/openvswitch/br-int.mgmt"
2020-12-21T15:11:37.746Z|00038|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:37.748Z|00039|bridge|INFO|ovs-vswitchd (Open vSwitch) 2.13.0
2020-12-21T15:11:40.987Z|00040|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:41.001Z|00041|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:41.012Z|00042|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:41.145Z|00043|bridge|INFO|bridge lxdovn1: deleted interface patch-lxd-net2-ls-ext-lsp-provider-to-br-int on port 2
2020-12-21T15:11:41.145Z|00044|bridge|INFO|bridge br-int: deleted interface patch-br-int-to-lxd-net2-ls-ext-lsp-provider on port 1
2020-12-21T15:11:41.167Z|00045|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:41.167Z|00046|dpif|WARN|Dropped 2 log messages in last 3 seconds (most recently, 3 seconds ago) due to excessive rate
2020-12-21T15:11:41.167Z|00047|dpif|WARN|system@ovs-system: failed to query port patch-lxd-net2-ls-ext-lsp-provider-to-br-int: Invalid argument
2020-12-21T15:11:41.167Z|00048|dpif|WARN|system@ovs-system: failed to query port patch-br-int-to-lxd-net2-ls-ext-lsp-provider: Invalid argument
2020-12-21T15:11:42.123Z|00049|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:42.123Z|00050|bridge|INFO|bridge lxdovn1: added interface patch-lxd-net2-ls-ext-lsp-provider-to-br-int on port 1
2020-12-21T15:11:42.123Z|00051|bridge|INFO|bridge br-int: added interface patch-br-int-to-lxd-net2-ls-ext-lsp-provider on port 2
2020-12-21T15:11:42.261Z|00052|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:42.337Z|00053|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:42.352Z|00054|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:42.411Z|00055|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:42.421Z|00056|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:42.477Z|00057|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:42.613Z|00058|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:43.271Z|00059|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:43.501Z|00060|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:43.527Z|00061|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:11:47.749Z|00062|memory|INFO|38480 kB peak resident set size after 10.1 seconds
2020-12-21T15:11:47.749Z|00063|memory|INFO|handlers:1 ofconns:2 ports:4 revalidators:1 rules:332
2020-12-21T15:11:51.142Z|00064|connmgr|INFO|br-int<->unix#0: 636 flow_mods in the 1 s starting 10 s ago (633 adds, 1 deletes, 2 modifications)
2020-12-21T15:11:58.683Z|00065|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:12:36.920Z|00066|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:12:36.936Z|00067|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:12:36.942Z|00068|bridge|WARN|could not open network device lxdovn1b (No such device)
2020-12-21T15:12:37.673Z|00069|bridge|INFO|bridge lxdovn1: added interface lxdovn1b on port 3
2020-12-21T15:12:50.391Z|00070|connmgr|INFO|br-int<->unix#0: 6 flow_mods 12 s ago (6 adds)
2020-12-21T15:19:09.839Z|00071|bridge|INFO|bridge lxdovn3: added interface lxdovn3 on port 65534
2020-12-21T15:19:09.839Z|00072|bridge|INFO|bridge lxdovn3: using datapath ID 000052f5d1f0fb4c
2020-12-21T15:19:09.840Z|00073|connmgr|INFO|lxdovn3: added service controller "punix:/var/run/openvswitch/lxdovn3.mgmt"
2020-12-21T15:19:09.903Z|00074|bridge|INFO|bridge lxdovn3: added interface lxdovn3b on port 1
2020-12-21T15:19:09.952Z|00075|bridge|INFO|bridge lxdovn3: added interface patch-lxd-net4-ls-ext-lsp-provider-to-br-int on port 2
2020-12-21T15:19:09.952Z|00076|bridge|INFO|bridge br-int: added interface patch-br-int-to-lxd-net4-ls-ext-lsp-provider on port 3
2020-12-21T15:19:19.822Z|00077|connmgr|INFO|br-int<->unix#0: 622 flow_mods in the 1 s starting 10 s ago (620 adds, 2 modifications)
