I’ve forked the LXD plugin and spent a couple of hours fixing it up.
There is no published, signed release yet, but if you build from source and copy packer-plugin-incus into the directory where you invoke packer, you can start fooling around.
The LXD plugin shelled out to lxc, and a find/replace in the codebase was enough to get simple re-packaging of an ubuntu container image working. However, I think long-term it’s better to use the Go SDK directly.
Packer + LXD historically has yielded fairly large images, and I’m interested in ways to mitigate that, at least a little, with post-processing, or clever build techniques. There is also the notion of supporting multiple build techniques (“builder types”), which is something the Azure packer plugin does. See the docs here: Azure | Integrations | Packer | HashiCorp Developer
The Azure plugin has a standard launch->run scripts->snapshot whole disk builder, but it also supports a rather interesting “chroot” builder, which relies on a pre-existing VM in your infrastructure, mounts a new disk on it, and provisions a rootfs in a chroot. The chroot builder can be radically faster, since there is no boot stage.
So perhaps there is an approach that we could explore for Incus builder types that are a middle ground between the current snapshot approach and distrobuilder. And if it could share code with distrobuilder, that would be even more awesome.
Brian, maybe add topic tags to the GitHub repo? I feel like literally searching “incus packer” should return your repo. Repository search results · GitHub
It didn’t for me yesterday.
In the meantime, I’ll rename this to packer-plugin-incuschroot or something, and if I get a builder with an alternative strategy working, I’ll submit it to your repo as a feature.
This is useful for me because the user that runs packer may have called incus switch to use a different default project and the temporary container created by packer cannot be run in that project.
thanks a lot for that work. I am afraid I don’t have right now a test system where I can test this, and I don’t won’t to disrupt the production one. I cannot promise, but maybe by the end of this week I can give it a try, otherwise it would need to happen next year.
Dear @bgaillard : I finally had the time to test this and I can happily report that it is working as expected. Just in case it is useful, I am not using the packer HCL2 configuration language but rather the legacy JSON. Still the “project” attribute was properly detected.
