Panic with lxc alias
I reinstalled lxd 5.0.0 with separate zfs partition. As far as I can see i did exactly the same as always.
Then I want to create an alias.
In the past this was never a problem, but this time it gives me a panic.
root@nc02 ~ lxc alias add delete "delete -i"
To start your first container, try: lxc launch ubuntu:20.04
Or for a virtual machine: lxc launch ubuntu:20.04 --vm
panic: assignment to entry in nil map
goroutine 1 [running]:
main.(*cmdAliasAdd).Run(0xc0001391f0, 0xc0001afc18?, {0xc0001f8d00?, 0x2, 0x0?})
	/build/lxd/parts/lxd/src/lxc/alias.go:84 +0xdd
github.com/spf13/cobra.(*Command).execute(0xc0001d6500, {0xc0001f8ca0, 0x2, 0x2})
	/build/lxd/parts/lxd/src/.go/pkg/mod/github.com/spf13/cobra@v1.4.0/command.go:856 +0x67c
github.com/spf13/cobra.(*Command).ExecuteC(0xc0001d6000)
	/build/lxd/parts/lxd/src/.go/pkg/mod/github.com/spf13/cobra@v1.4.0/command.go:974 +0x3b4
github.com/spf13/cobra.(*Command).Execute(...)
	/build/lxd/parts/lxd/src/.go/pkg/mod/github.com/spf13/cobra@v1.4.0/command.go:902
main.main()
	/build/lxd/parts/lxd/src/lxc/main.go:276 +0x1a33
Any help would be appreciated.
After creation first container the problem is gone.
Before it also worked without first creating a container.
Thanks for confirmation, I am looking into this.
Confirmed issue, opened bug here:
