yes I am using ubuntu 21.04 and version of lxd is 4.15 also I am not much expert in using these containers. Earlier I installed it on kali linux everything worked well but in this system I am getting too many errors .Tried many solutions nothing worked and even I think I have messed up more.
sudo lxd --version
4.15
sudo journalctl -b | grep lxdbr0
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9115] manager: (lxdbr0): new Bridge device (/org/freedesktop/NetworkManager/Devices/6)
Jun 21 09:44:40 amaan avahi-daemon[1371]: Joining mDNS multicast group on interface lxdbr0.IPv4 with address 10.166.212.1.
Jun 21 09:44:40 amaan avahi-daemon[1371]: New relevant interface lxdbr0.IPv4 for mDNS.
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9641] device (lxdbr0): state change: unmanaged → unavailable (reason ‘connection-assumed’, sys-iface-state: ‘external’)
Jun 21 09:44:40 amaan avahi-daemon[1371]: Registering new address record for 10.166.212.1 on lxdbr0.IPv4.
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9668] device (lxdbr0): state change: unavailable → disconnected (reason ‘connection-assumed’, sys-iface-state: ‘external’)
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9674] device (lxdbr0): Activation: starting connection ‘lxdbr0’ (2a40c791-aacc-4b1e-a370-ea7d35c66ebf)
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9675] device (lxdbr0): state change: disconnected → prepare (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9679] device (lxdbr0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9681] device (lxdbr0): state change: config → ip-config (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9684] device (lxdbr0): state change: ip-config → ip-check (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 09:44:40 amaan avahi-daemon[1371]: Joining mDNS multicast group on interface lxdbr0.IPv6 with address fd42:ad51:a11e:2dca::1.
Jun 21 09:44:40 amaan avahi-daemon[1371]: New relevant interface lxdbr0.IPv6 for mDNS.
Jun 21 09:44:40 amaan avahi-daemon[1371]: Registering new address record for fd42:ad51:a11e:2dca::1 on lxdbr0..
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9759] device (lxdbr0): state change: ip-check → secondaries (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9768] device (lxdbr0): state change: secondaries → activated (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 09:44:40 amaan NetworkManager[1380]: [1624248880.9779] device (lxdbr0): Activation: successful, device activated.
Jun 21 09:44:41 amaan audit[2995]: AVC apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>” pid=2995 comm=“apparmor_parser”
Jun 21 09:44:41 amaan kernel: audit: type=1400 audit(1624248881.029:67): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>” pid=2995 comm=“apparmor_parser”
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: DHCPv6 stateless on lxdbr0
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: DHCPv4-derived IPv6 names on lxdbr0
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: router advertisement on lxdbr0
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: DHCPv6 stateless on fd42:ad51:a11e:2dca::, constructed for lxdbr0
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: DHCPv4-derived IPv6 names on fd42:ad51:a11e:2dca::, constructed for lxdbr0
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: router advertisement on fd42:ad51:a11e:2dca::, constructed for lxdbr0
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: DHCP, sockets bound exclusively to interface lxdbr0
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/test1
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/rv
Jun 21 09:44:41 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/mca
Jun 21 09:44:42 amaan kernel: lxdbr0: port 1(veth5889706a) entered blocking state
Jun 21 09:44:42 amaan kernel: lxdbr0: port 1(veth5889706a) entered disabled state
Jun 21 09:44:42 amaan netscript[3376]: {eth0|eno1|wlp4s0|lxcbr0|lxdbr0|veth5889706a|all}
Jun 21 09:44:42 amaan kernel: lxdbr0: port 1(veth5889706a) entered forwarding state
Jun 21 09:44:42 amaan kernel: IPv6: ADDRCONF(NETDEV_CHANGE): lxdbr0: link becomes ready
Jun 21 09:44:42 amaan NetworkManager[1380]: [1624248882.3374] device (lxdbr0): carrier: link connected
Jun 21 09:47:45 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/mca1
Jun 21 09:47:45 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/test1
Jun 21 09:47:45 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/rv
Jun 21 09:47:50 amaan kernel: lxdbr0: port 2(veth7dd70227) entered blocking state
Jun 21 09:47:50 amaan kernel: lxdbr0: port 2(veth7dd70227) entered disabled state
Jun 21 09:47:50 amaan avahi-daemon[1371]: Interface lxdbr0.IPv6 no longer relevant for mDNS.
Jun 21 09:47:50 amaan avahi-daemon[1371]: Leaving mDNS multicast group on interface lxdbr0.IPv6 with address fd42:ad51:a11e:2dca::1.
Jun 21 09:47:50 amaan avahi-daemon[1371]: Interface lxdbr0.IPv4 no longer relevant for mDNS.
Jun 21 09:47:50 amaan avahi-daemon[1371]: Leaving mDNS multicast group on interface lxdbr0.IPv4 with address 10.166.212.1.
Jun 21 09:47:50 amaan avahi-daemon[1371]: Withdrawing address record for fd42:ad51:a11e:2dca::1 on lxdbr0.
Jun 21 09:47:50 amaan avahi-daemon[1371]: Withdrawing address record for 10.166.212.1 on lxdbr0.
Jun 21 09:47:50 amaan kernel: lxdbr0: port 1(veth5889706a) entered disabled state
Jun 21 09:47:50 amaan dnsmasq-dhcp[3013]: router advertisement on fd42:ad51:a11e:2dca::, old prefix for lxdbr0
Jun 21 09:47:50 amaan NetworkManager[1380]: [1624249070.3754] device (lxdbr0): state change: activated → unmanaged (reason ‘unmanaged’, sys-iface-state: ‘removed’)
Jun 21 09:47:50 amaan sh[7541]: bridge lxdbr0 doesn’t exist; can’t delete it
Jun 21 10:00:50 amaan ovs-vsctl[12224]: ovs|00001|vsctl|INFO|Called as ovs-vsctl --if-exists del-port lxdbr0 veth7dd70227
Jun 21 10:00:50 amaan lxd.daemon[2552]: t=2021-06-21T10:00:50+0530 lvl=eror msg=“Failed to stop device” devName=eth0 err=“Failed to detach interface “veth7dd70227” from “lxdbr0”: Failed to run: ovs-vsctl --if-exists del-port lxdbr0 veth7dd70227: ovs-vsctl: unix:/var/run/openvswitch/db.sock: database connection failed (No such file or directory)” instance=mca1 instanceType=container project=default
Jun 21 10:00:51 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/test1
Jun 21 10:00:51 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/rv
Jun 21 10:00:51 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/mca
Jun 21 10:00:58 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/test1
Jun 21 10:00:58 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/rv
Jun 21 10:01:04 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/rv
Jun 21 10:01:18 amaan ovs-vsctl[12951]: ovs|00001|vsctl|INFO|Called as ovs-vsctl --if-exists del-port lxdbr0 veth5889706a
Jun 21 10:01:18 amaan lxd.daemon[2552]: t=2021-06-21T10:01:18+0530 lvl=eror msg=“Failed to stop device” devName=eth0 err=“Failed to detach interface “veth5889706a” from “lxdbr0”: Failed to run: ovs-vsctl --if-exists del-port lxdbr0 veth5889706a: ovs-vsctl: unix:/var/run/openvswitch/db.sock: database connection failed (No such file or directory)” instance=rv instanceType=container project=default
Jun 21 10:01:54 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/abc
Jun 21 10:04:57 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/new1
Jun 21 10:04:57 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/abc
Jun 21 10:06:46 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/new2
Jun 21 10:06:46 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/new1
Jun 21 10:06:46 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/abc
Jun 21 10:14:29 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/new1
Jun 21 10:14:29 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/abc
Jun 21 10:14:31 amaan dnsmasq-dhcp[3013]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/abc
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3181] manager: (lxdbr0): new Bridge device (/org/freedesktop/NetworkManager/Devices/14)
Jun 21 10:26:34 amaan avahi-daemon[1371]: Joining mDNS multicast group on interface lxdbr0.IPv4 with address 10.124.224.1.
Jun 21 10:26:34 amaan avahi-daemon[1371]: New relevant interface lxdbr0.IPv4 for mDNS.
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3644] device (lxdbr0): state change: unmanaged → unavailable (reason ‘connection-assumed’, sys-iface-state: ‘external’)
Jun 21 10:26:34 amaan avahi-daemon[1371]: Registering new address record for 10.124.224.1 on lxdbr0.IPv4.
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3676] device (lxdbr0): state change: unavailable → disconnected (reason ‘connection-assumed’, sys-iface-state: ‘external’)
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3689] device (lxdbr0): Activation: starting connection ‘lxdbr0’ (705c8ec2-4e7a-4700-b460-346b096723d4)
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3704] device (lxdbr0): state change: disconnected → prepare (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3709] device (lxdbr0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3713] device (lxdbr0): state change: config → ip-config (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3715] device (lxdbr0): state change: ip-config → ip-check (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 10:26:34 amaan avahi-daemon[1371]: Joining mDNS multicast group on interface lxdbr0.IPv6 with address fd42:431:1889:1f8d::1.
Jun 21 10:26:34 amaan avahi-daemon[1371]: New relevant interface lxdbr0.IPv6 for mDNS.
Jun 21 10:26:34 amaan avahi-daemon[1371]: Registering new address record for fd42:431:1889:1f8d::1 on lxdbr0..
Jun 21 10:26:34 amaan dnsmasq-dhcp[3013]: router advertisement on fd42:431:1889:1f8d::, old prefix for lxdbr0
Jun 21 10:26:34 amaan dnsmasq-dhcp[3013]: DHCPv6 stateless on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 10:26:34 amaan dnsmasq-dhcp[3013]: DHCPv4-derived IPv6 names on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 10:26:34 amaan dnsmasq-dhcp[3013]: router advertisement on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3992] device (lxdbr0): state change: ip-check → secondaries (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.3995] device (lxdbr0): state change: secondaries → activated (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 10:26:34 amaan NetworkManager[1380]: [1624251394.4009] device (lxdbr0): Activation: successful, device activated.
Jun 21 10:26:34 amaan audit[25581]: AVC apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>” pid=25581 comm=“apparmor_parser”
Jun 21 10:26:34 amaan kernel: audit: type=1400 audit(1624251394.492:229): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>” pid=25581 comm=“apparmor_parser”
Jun 21 10:26:34 amaan dnsmasq-dhcp[25593]: DHCPv6 stateless on lxdbr0
Jun 21 10:26:34 amaan dnsmasq-dhcp[25593]: DHCPv4-derived IPv6 names on lxdbr0
Jun 21 10:26:34 amaan dnsmasq-dhcp[25593]: router advertisement on lxdbr0
Jun 21 10:26:34 amaan dnsmasq-dhcp[25593]: DHCPv6 stateless on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 10:26:34 amaan dnsmasq-dhcp[25593]: DHCPv4-derived IPv6 names on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 10:26:34 amaan dnsmasq-dhcp[25593]: router advertisement on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 10:26:34 amaan dnsmasq-dhcp[25593]: DHCP, sockets bound exclusively to interface lxdbr0
Jun 21 10:28:22 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/ab
Jun 21 10:28:29 amaan kernel: lxdbr0: port 1(veth9220f597) entered blocking state
Jun 21 10:28:29 amaan kernel: lxdbr0: port 1(veth9220f597) entered disabled state
Jun 21 10:28:29 amaan avahi-daemon[1371]: Interface lxdbr0.IPv6 no longer relevant for mDNS.
Jun 21 10:28:29 amaan avahi-daemon[1371]: Leaving mDNS multicast group on interface lxdbr0.IPv6 with address fd42:431:1889:1f8d::1.
Jun 21 10:28:29 amaan avahi-daemon[1371]: Interface lxdbr0.IPv4 no longer relevant for mDNS.
Jun 21 10:28:29 amaan avahi-daemon[1371]: Leaving mDNS multicast group on interface lxdbr0.IPv4 with address 10.124.224.1.
Jun 21 10:28:29 amaan avahi-daemon[1371]: Withdrawing address record for fd42:431:1889:1f8d::1 on lxdbr0.
Jun 21 10:28:29 amaan avahi-daemon[1371]: Withdrawing address record for 10.124.224.1 on lxdbr0.
Jun 21 10:28:29 amaan dnsmasq-dhcp[25593]: router advertisement on fd42:431:1889:1f8d::, old prefix for lxdbr0
Jun 21 10:28:29 amaan dnsmasq-dhcp[3013]: router advertisement on fd42:431:1889:1f8d::, old prefix for lxdbr0
Jun 21 10:28:29 amaan NetworkManager[1380]: [1624251509.3559] device (lxdbr0): state change: activated → unmanaged (reason ‘connection-assumed’, sys-iface-state: ‘external’)
Jun 21 10:28:29 amaan sh[29932]: bridge lxdbr0 doesn’t exist; can’t delete it
Jun 21 10:29:40 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/abc
Jun 21 10:30:19 amaan ovs-vsctl[33630]: ovs|00001|vsctl|INFO|Called as ovs-vsctl --if-exists del-port lxdbr0 veth9220f597
Jun 21 10:30:19 amaan lxd.daemon[25430]: t=2021-06-21T10:30:19+0530 lvl=eror msg=“Failed to stop device” devName=eth0 err=“Failed to detach interface “veth9220f597” from “lxdbr0”: Failed to run: ovs-vsctl --if-exists del-port lxdbr0 veth9220f597: ovs-vsctl: unix:/var/run/openvswitch/db.sock: database connection failed (No such file or directory)” instance=ab instanceType=container project=default
Jun 21 10:35:21 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/first
Jun 21 10:35:21 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/abc
Jun 21 11:37:55 amaan sudo[58733]: amaan : TTY=pts/0 ; PWD=/home/amaan ; USER=root ; COMMAND=/usr/bin/lxd config device add first eth0 nic nictype=bridged parent=lxdbr0 name=eth0
Jun 21 11:38:29 amaan sudo[58789]: amaan : TTY=pts/0 ; PWD=/home/amaan ; USER=root ; COMMAND=/usr/sbin/ip link del lxdbr0
Jun 21 11:40:52 amaan sudo[59166]: amaan : TTY=pts/2 ; PWD=/home/amaan ; USER=root ; COMMAND=/usr/bin/systemctl enable --now lxd-dns-lxdbr0
Jun 21 11:45:05 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/c1
Jun 21 11:45:05 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/first
Jun 21 11:45:05 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/abc
Jun 21 11:46:09 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/c1
Jun 21 11:46:09 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/first
Jun 21 11:46:09 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/abc
Jun 21 11:46:11 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/c1
Jun 21 11:46:11 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/first
Jun 21 11:46:15 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/first
Jun 21 11:46:48 amaan dnsmasq-dhcp[25593]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/first
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.7495] manager: (lxdbr0): new Bridge device (/org/freedesktop/NetworkManager/Devices/43)
Jun 21 14:11:33 amaan avahi-daemon[1371]: Joining mDNS multicast group on interface lxdbr0.IPv4 with address 10.124.224.1.
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8067] device (lxdbr0): state change: unmanaged → unavailable (reason ‘connection-assumed’, sys-iface-state: ‘external’)
Jun 21 14:11:33 amaan avahi-daemon[1371]: New relevant interface lxdbr0.IPv4 for mDNS.
Jun 21 14:11:33 amaan avahi-daemon[1371]: Registering new address record for 10.124.224.1 on lxdbr0.IPv4.
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8102] device (lxdbr0): state change: unavailable → disconnected (reason ‘connection-assumed’, sys-iface-state: ‘external’)
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8110] device (lxdbr0): Activation: starting connection ‘lxdbr0’ (459f0081-baf0-4709-aab0-9aa25004be3b)
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8126] device (lxdbr0): state change: disconnected → prepare (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8130] device (lxdbr0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8133] device (lxdbr0): state change: config → ip-config (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8136] device (lxdbr0): state change: ip-config → ip-check (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 14:11:33 amaan avahi-daemon[1371]: Joining mDNS multicast group on interface lxdbr0.IPv6 with address fd42:431:1889:1f8d::1.
Jun 21 14:11:33 amaan avahi-daemon[1371]: New relevant interface lxdbr0.IPv6 for mDNS.
Jun 21 14:11:33 amaan avahi-daemon[1371]: Registering new address record for fd42:431:1889:1f8d::1 on lxdbr0.*.
Jun 21 14:11:33 amaan dnsmasq-dhcp[25593]: router advertisement on fd42:431:1889:1f8d::, old prefix for lxdbr0
Jun 21 14:11:33 amaan dnsmasq-dhcp[3013]: router advertisement on fd42:431:1889:1f8d::, old prefix for lxdbr0
Jun 21 14:11:33 amaan dnsmasq-dhcp[25593]: DHCPv6 stateless on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 14:11:33 amaan dnsmasq-dhcp[25593]: DHCPv4-derived IPv6 names on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 14:11:33 amaan dnsmasq-dhcp[3013]: DHCPv6 stateless on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 14:11:33 amaan dnsmasq-dhcp[25593]: router advertisement on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 14:11:33 amaan dnsmasq-dhcp[3013]: DHCPv4-derived IPv6 names on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 14:11:33 amaan dnsmasq-dhcp[3013]: router advertisement on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 14:11:33 amaan audit[87038]: AVC apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>” pid=87038 comm=“apparmor_parser”
Jun 21 14:11:33 amaan kernel: audit: type=1400 audit(1624264893.823:261): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>” pid=87038 comm=“apparmor_parser”
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8428] device (lxdbr0): state change: ip-check → secondaries (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8431] device (lxdbr0): state change: secondaries → activated (reason ‘none’, sys-iface-state: ‘external’)
Jun 21 14:11:33 amaan NetworkManager[1380]: [1624264893.8447] device (lxdbr0): Activation: successful, device activated.
Jun 21 14:11:34 amaan dnsmasq-dhcp[87050]: DHCPv6 stateless on lxdbr0
Jun 21 14:11:34 amaan dnsmasq-dhcp[87050]: DHCPv4-derived IPv6 names on lxdbr0
Jun 21 14:11:34 amaan dnsmasq-dhcp[87050]: router advertisement on lxdbr0
Jun 21 14:11:34 amaan dnsmasq-dhcp[87050]: DHCPv6 stateless on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 14:11:34 amaan dnsmasq-dhcp[87050]: DHCPv4-derived IPv6 names on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 14:11:34 amaan dnsmasq-dhcp[87050]: router advertisement on fd42:431:1889:1f8d::, constructed for lxdbr0
Jun 21 14:11:34 amaan dnsmasq-dhcp[87050]: DHCP, sockets bound exclusively to interface lxdbr0
Jun 21 14:11:34 amaan dnsmasq-dhcp[87050]: read /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts/first
