I’m trying to use LXC on a GlusterFS volume so the containers are synced between two nodes. The host machine is Ubuntu 18.04 LTS with the latest GlusterFS and LXC 3.0.
# mount -t glusterfs node1:/gv0 /mnt/replicated
# lxc storage create cont-storage dir source=/mnt/replicated
# lxc launch images:ubuntu/xenial cont -s cont-storage
# lxc start cont
The machine starts with success. The issue now is with permissions. This is what I get when I try apt-get update:
# lxc exec cont bash
root@cont:~# apt-get update
Hit:1 http://archive.ubuntu.com/ubuntu xenial InRelease
Get:2 http://archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
Get:3 http://security.ubuntu.com/ubuntu xenial-security InRelease [107 kB]
0% [1 InRelease gpgv 247 kB] [2 InRelease 57.6 kB/109 kB 53%]Splitting up /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_xenial_InRelease into data and signErr:1 http://archive.ubuntu.com/ubuntu xenial InRelease
Clearsigned file isn't valid, got 'NODATA' (does the network require authentication?)
Reading package lists... Done
W: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (1: Operation not permitted)
W: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (1: Operation not permitted)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_xenial_InRelease - PrepareFiles (13: Permission denied)
W: chown to _apt:root of file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_xenial_InRelease failed - Item::QueueURI (1: Operation not permitted)
W: chown to root:root of file /var/lib/apt/lists/partial/security.ubuntu.com_ubuntu_dists_xenial-security_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chmod 0644 of file /var/lib/apt/lists/partial/security.ubuntu.com_ubuntu_dists_xenial-security_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chown to _apt:root of file /var/lib/apt/lists/partial/security.ubuntu.com_ubuntu_dists_xenial-security_InRelease failed - Item::QueueURI (1: Operation not permitted)
W: chmod 0600 of file /var/lib/apt/lists/partial/security.ubuntu.com_ubuntu_dists_xenial-security_InRelease failed - Item::QueueURI (1: Operation not permitted)
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.ubuntu.com/ubuntu xenial InRelease: Clearsigned file isn't valid, got 'NODATA' (does the network require authentication?)
W: chown to root:root of file /var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_xenial-updates_InRelease failed - 201::URIDone (1: Operation not permitted)
W: chmod 0644 of file /var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_xenial-updates_InRelease failed - 201::URIDone (1: Operation not permitted)
W: Problem unlinking the file /var/lib/apt/lists/partial/security.ubuntu.com_ubuntu_dists_xenial-security_InRelease - PrepareFiles (13: Permission denied)
E: can not open /var/lib/apt/lists/partial/security.ubuntu.com_ubuntu_dists_xenial-security_InRelease - fopen (13: Permission denied)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_xenial-updates_InRelease - PrepareFiles (13: Permission denied)
E: can not open /var/lib/apt/lists/partial/archive.ubuntu.com_ubuntu_dists_xenial-updates_InRelease - fopen (13: Permission denied)
How do I fix this?
