I’m attempting to get USB Redirection of a PGP smart card working. Currently tit works on the host and I’m passing it through to the container with the following profile config -
nitrokey:
productid: "4109"
type: unix-hotplug
vendorid: 20a0
I do see the device in the container -
root@packer-test:~# lsusb -s 003:029
Bus 003 Device 029: ID 20a0:4109 Clay Logic Nitrokey Storage
root@packer-test:~# usb-devices
T: Bus=03 Lev=03 Prnt=10 Port=03 Cnt=01 Dev#= 29 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=20a0 ProdID=4109 Rev=01.01
S: Manufacturer=Nitrokey
S: Product=Nitrokey Storage
S: SerialNumber=0000000000000
C: #Ifs= 3 Cfg#= 1 Atr=80 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I: If#= 1 Alt= 0 #EPs= 3 Cls=0b(scard) Sub=00 Prot=00 Driver=usbfs
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 16 Ivl=4096ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I: If#= 2 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=86(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
I have the same packages in the container as on the host for managing the smart card but I cannot seem to get it working. pcscd
is on the system and has a LIBUSB_ERROR_BUSY showing up both in debian/12 and ubuntu/22.04 containers -
root@packer-test:~# systemctl status pcscd
○ pcscd.service - PC/SC Smart Card Daemon
Loaded: loaded (/lib/systemd/system/pcscd.service; indirect; preset: enabled)
Drop-In: /run/systemd/system/service.d
└─zzz-lxc-service.conf
Active: inactive (dead) since Sun 2024-04-14 17:17:39 UTC; 20min ago
Duration: 1min 1.070s
TriggeredBy: ● pcscd.socket
Docs: man:pcscd(8)
Process: 174 ExecStart=/usr/sbin/pcscd --foreground --auto-exit $PCSCD_ARGS (code=exited, status=0/SUCCESS)
Main PID: 174 (code=exited, status=0/SUCCESS)
CPU: 69ms
Apr 14 17:16:38 packer-test systemd[1]: Started pcscd.service - PC/SC Smart Card Daemon.
Apr 14 17:16:38 packer-test pcscd[174]: 00000000 ccid_usb.c:683:OpenUSBByName() Can't claim interface 3/29: LIBUSB_ERROR_BUSY
Apr 14 17:16:38 packer-test pcscd[174]: 00000221 ifdhandler.c:161:CreateChannelByNameOrChannel() failed
Apr 14 17:16:38 packer-test pcscd[174]: 00000002 readerfactory.c:1134:RFInitializeReader() Open Port 0x200000 Failed (usb:20a0/4109:libudev:1:/dev/bus/usb/003/029)
Apr 14 17:16:38 packer-test pcscd[174]: 00000002 readerfactory.c:378:RFAddReader() Nitrokey Nitrokey Storage (0000000000000) init failed.
Apr 14 17:16:38 packer-test pcscd[174]: 00000046 hotplug_libudev.c:518:HPAddDevice() Failed adding USB device: Nitrokey Nitrokey Storage
Is there something I’m doing wrong? I’ve attempted privileged and unprivileged containers with the same result.
Kenton
