today I was recovering my cluster node after partial data loss and forgot to restore one storage volume, but afterwards I got phantom db entries and can not continue.
So, it started like this
[root@lxd11 ~]# lxd recover
This LXD server currently has the following storage pools:
- ee (backend="zfs", source="")
The recovery process will be scanning the following storage pools:
- EXISTING: "ee" (backend="zfs", source="")
Would you like to continue with scanning for lost volumes? (yes/no) [default=yes]: yes
Scanning for unknown volumes...
The following unknown volumes have been found:
- Container "vaulttest" on pool "ee" in project "default" (includes 7 snapshots)
- Container "vaulttest1" on pool "ee" in project "default" (includes 7 snapshots)
- Container "vaulttest2" on pool "ee" in project "default" (includes 7 snapshots)
- Container "vaulttest3" on pool "ee" in project "default" (includes 7 snapshots)
- Container "vaulttest4" on pool "ee" in project "default" (includes 7 snapshots)
- Container "vaulttest5" on pool "ee" in project "default" (includes 7 snapshots)
Would you like those to be recovered? (yes/no) [default=no]: yes
Starting recovery...
Error: Failed import request: Failed creating instance "vaulttest" record in project "default": Failed creating instance record: Failed initialising instance: Failed add validation for device "testvol":
Failed loading custom volume: Storage volume not found
oh well, ok, my bad, let’s restore the storage volume and retry
Error: Failed validation request: Failed checking volumes on pool "ee": Instance "vaulttest3" in project "default" already has storage DB record
Ups, so it didn’t completely fail, but left ghost db entries. When I moved vaulttest3 away, it repeated with vaulttest4 and 5. At last is it succeeeded for vaulttest, vaulttest1 and 2, but now for vaulttest3,4 and 5 I have phantom entries that won’t go away, e.g.
[root@lxd11 ~]# lxc launch c8 vaulttest5 --target lxd11
Creating vaulttest5
Error: Failed creating instance from image: Error inserting volume "vaulttest5" for project "default" in pool "ee" of type "containers" into database "UNIQUE constraint failed: index 'storage_volumes_unique_storage_pool_id_node_id_project_id_name_type'"
[root@lxd11 ~]# lxc rm -f vaulttest5
Error: Failed checking instance exists "local:vaulttest5": Instance not found
how do I get rid of this? I see I have the following in my global db, is it enough if i just delete those or will I make it worse?
[root@lxd11 ~]# lxd sql global .dump | fgrep vaulttest5
INSERT INTO storage_volumes VALUES(911409,'vaulttest5',1,10,0,'',1,0,'2023-01-02 14:23:39.047069147+00:00');
[root@lxd11 ~]# lxd sql global .dump | fgrep 911409
INSERT INTO storage_volumes_snapshots VALUES(911410,911409,'auto-20230430-230157','','0001-01-01 00:00:00+00:00','2023-04-30 23:01:57.938295922+00:00');
INSERT INTO storage_volumes_snapshots VALUES(911411,911409,'auto-20230519-230234','','0001-01-01 00:00:00+00:00','2023-05-19 23:02:35.425842938+00:00');
INSERT INTO storage_volumes_snapshots VALUES(911412,911409,'auto-20230520-230548','','0001-01-01 00:00:00+00:00','2023-05-20 23:05:48.687867843+00:00');
INSERT INTO storage_volumes_snapshots VALUES(911413,911409,'auto-20230522-110210','','0001-01-01 00:00:00+00:00','2023-05-22 11:02:10.849646612+00:00');
INSERT INTO storage_volumes_snapshots VALUES(911414,911409,'auto-20230522-120223','','0001-01-01 00:00:00+00:00','2023-05-22 12:02:24.120855158+00:00');
INSERT INTO storage_volumes_snapshots VALUES(911415,911409,'auto-20230522-130223','','0001-01-01 00:00:00+00:00','2023-05-22 13:02:24.259932839+00:00');
INSERT INTO storage_volumes_snapshots VALUES(911416,911409,'auto-20230522-140242','','0001-01-01 00:00:00+00:00','2023-05-22 14:02:43.226609057+00:00');
INSERT INTO storage_volumes_config VALUES(1862,911409,'zfs.use_refquota','true');
