-------- Please I need help I can’t access lxd, I have important information and software inside containers virtual machines.
~$ lxd --version
6.1
~$ systemctl list-jobs
JOB UNIT TYPE STATE
14107 snap.lxd.activate.service start running
1 jobs listed.
-------- lxd is working
~$ systemctl status snap.lxd.activate.service
● snap.lxd.activate.service - Service for snap application lxd.activate
Loaded: loaded (/etc/systemd/system/snap.lxd.activate.service; enabled; vendor preset: enabled)
Active: activating (start) since Fri 2024-07-19 19:19:25 WEST; 21min ago
Main PID: 33574 (daemon.activate)
Tasks: 13 (limit: 27989)
Memory: 19.4M
CPU: 229ms
CGroup: /system.slice/snap.lxd.activate.service
├─33574 /bin/sh /snap/lxd/29469/commands/daemon.activate
└─33616 lxd activateifneeded
jul 19 19:19:25 luiz-Vivobook systemd[1]: Starting Service for snap application lxd.activate…
jul 19 19:19:25 luiz-Vivobook lxd.activate[33574]: => Starting LXD activation
jul 19 19:19:25 luiz-Vivobook lxd.activate[33574]: ==> Loading snap configuration
jul 19 19:19:25 luiz-Vivobook lxd.activate[33574]: ==> Checking for socket activation support
jul 19 19:19:25 luiz-Vivobook lxd.activate[33574]: ==> Setting LXD socket ownership
jul 19 19:19:25 luiz-Vivobook lxd.activate[33574]: ==> Setting LXD user socket ownership
jul 19 19:19:25 luiz-Vivobook lxd.activate[33574]: ==> Checking if LXD needs to be activated
-------- the service is working
-------- but I can’t do anything with lxd, when I run the commands “sudo lxd”, “lxc list” or “lxc info” nothing happens and the terminal stops indefinitely
~$ sudo lxd --debug --group lxd
DEBUG [2024-07-19T20:11:45+01:00] Connecting to a local LXD over a Unix socket
DEBUG [2024-07-19T20:11:45+01:00] Sending request to LXD etag= method=GET url=“http://unix.socket/1.0”
-------- the terminal stops indefinitely
