Do you have /sys/fs/cgroup/pids/ populated in the container?
You’re mentioning Debian so it could also be a simple issue of lack of cgroup2 support in this particular setup. If that’s the case, try booting your host in cgroup1 mode (systemd.unified_cgroup_hierarchy=false).
Thanks Stéphane,
Indeed the host is running on cgroups v1 as issues were encountered if the kernel arg systemd.unified_cgroup_hierarchy=0 is omitted.
I understand Podman needs to use cgroups v2 so will try on a new host (or see if use of cgroups v1 can be enforced over Podman).
To answer your 1st question, the /sys/fs/cgroup/pids directory does not exist on the container.
Ah, if the host is on cgroup1, then /sys/fs/cgroup/pids should exist in the container.
If it doesn’t, it’s most likely because systemd in the container is similarly being forced to cgroup2 by the distro…
Might be worth trying to set raw.lxc to lxc.init.cmd=/sbin/init systemd.unified_cgroup_hierarchy=0 and see if the container then picks up /sys/fs/cgroup/pids.
