Hi!
Is there a way to add a remote host by using a different port than 8443?
I have 1 dedicated server (local server) and 1 public cloud instance that I want to use as a backup, both at OVH.
I opened all ports and tested if available with nmap. Only 8443 is not available.
I know that port 8443 is used by Cisco WaaS Central Manager standard SSL administration port and this is the kind on material OVH is using.
I changed port to 8444 and I get something like that with lxc info ->
core.https_address: ‘[::]:8444’
environment:
addresses:
54.xx.yy.zz:8444
‘[2607:5300:203:2f4b::]:8444’
10.xx.yy.1:8444
driver: lxc
driver_version: 3.0.1
kernel: Linux
kernel_architecture: x86_64
kernel_version: 4.15.0-29-generic
server: lxd
server_pid: 3135
server_version: 3.0.1
storage: btrfs
storage_version: 4.15.1
server_clustered: false
server_name: host.xyz.net
So I tried to add a remote host and I get this error message:
Generating a client certificate. This may take a minute…
Error: Get https://54.xx.yy.zz:8443: Unable to connect to: 54.xx.yy.zz.207:8443
I’ve rebuilt both servers from scratch and init lxd with zfs on loop so I can add a working remote on port 8443. If I try to reverse the process between servers I have the same problem.
I’ll troubleshoot this tomorrow following the link you shared and see what is going on with this public cloud instance.
I reinstalled Ubuntu 18.04 (basic install) on both the dedicated and the cloud instance TWICE trying to see why I can’t get remote installation working from the decicated (first try) while I can do it from the cloud instance (second try).
So too much loss of time on that. I’ll use it like that.
Thanks!
