Hi folks, I a bit new to LXC so apologies in advance for the nature of the question.
I have a small homelab environment, currently running a Caddy web server on an LXC container (ubuntu server 20.04). I have gone through the install process of Remotely on a separate LXC container [10.33.3.34] (ubuntu server 20.04) using the generic installer, but Im having difficulty getting Remotely to connect with my (existing) Caddy server [10.33.3.33]. The generic installer installs its own instance of caddy or nginx. The Caddy server and Remotely server are bridged to the eth0 port on host, which is an 8GB Raspberry Pi.
On further inspection, if I do an
nmap -p- [10.33.3.34](https://10.33.3.34)
from another host, which is the IP address of the Remotely server, I do not see port 5000 available to me, I only get 22 and 80 as open ports.
However if I do a
ss -tulpn
I seel that port 5000 is set as listening from inside the container.
How do I get my Remotely server to accept reverse proxy requests from my existing caddy server on LXC? Thanks for your time.
