Hi, I have a slim Golang API that communicates with LXD clusters using the client InstanceServer in github.com/lxd/client.
At some point I call ConnextLXDWithContext, which takes ConnectionArgs
as an argument, which I’m using to pass in a custom http client via ConnectionArgs.HTTPClient
In my custom http client I have an implementation of http RoundTripper, which wraps the original http Transport with some distributed tracing logic.
The problem I’m facing is that my RoundTripper is being overwritten down the line here.
Would it be possible to extend the ConnectionArgsto take an extra field that wraps the TLS transport set by you?
I have a pull request with a suggestion.
Thanks
