Hello, Is it possible to import/export remotes from/to a running LXD instance? I’ve got a few hosts geographically separated in a mesh setup and currently adding new remotes to each host node manually.
Thanks,
Thanks,
Remotes are defined in the client, not the server. You can find the config in ~/snap/lxd/common/config/ or ~/.config/lxc/.
It’s possible for you to define them globally on the system (or through a configuration management tooling) by putting the config.yml in /var/snap/lxd/common/config/ or /etc/lxc/
Found it thanks!
