Possible vulnerabilities
Some GitHub security advisories have appeared today for LXD:
  1. GHSA-ppq7-4492-5552 Backup snapshot import bypasses project restrictions · Advisory · canonical/lxd
  2. GHSA-j93m-3j9p-m5m8 CreateCustomVolumeFromBackup nil-pointer dereference on volumes[0].snapshots[\*].expires\_at · Advisory · canonical/lxd
  3. GHSA-pjff-c2wc-f6jm Arbitrary file write on client due to trusted image hash · Advisory · canonical/lxd
  4. GHSA-fmc8-p6q7-75cc Argument injection in backup compression algorithm leading to AFW and ACE · Advisory · canonical/lxd
  5. GHSA-vghh-5rfx-xhq8 Arbitrary file read+write on host via rootfs/ symlink in malicious image · Advisory · canonical/lxd
  6. GHSA-jpf8-86f3-wp38 Arbitrary file read+write on host via templates/ symlink in malicious image · Advisory · canonical/lxd
  7. GHSA-9j25-mm2h-2f76 Arbitrary file write on host via \exec-output\\ symlink in crafted image · Advisory · canonical/lxd
  8. GHSA-47w9-6r3f-938g Restricted project bypass leading to arbitrary command execution · Advisory · canonical/lxd
  9. GHSA-hhf9-qw4v-72xp Cross-guest volume hijack via DevLXD device patch · Advisory · canonical/lxd
  10. GHSA-7mr3-28h5-m5vx Project restriction bypass for custom volume copy across projects · Advisory · canonical/lxd
  11. GHSA-qx75-2p3r-pwm5 Project restriction bypass in instance copy across projects · Advisory · canonical/lxd
Golang is not my area of expertise, but using GitHub Copilot on #7 (GHSA-9j25-mm2h-2f76) as a sample, the bot seems to think this one could be applicable to Incus: https://gist.github.com/evanjrowley/9abbb81ed89ae2af1f895a3f45d2e4b7
Most of those GHSAs originated from Incus and are properly credited/linked on the very first line. :slightly_smiling_face:
Yeah. We share information about security issues between the LXD and Incus projects.
Incus is the primary source of those advisories as we’ve had several security researchers and firms spend time going through Incus over the past few months, LXD then publish their own version of those.
We usually time the release of the advisories on our end to line up with Incus releases, so 8 of those became public yesterday when Incus 7.2 got tagged.
