Successfully installed IncusOS - CMD “incus remote add IncusOS 192.168.XXX.XXX” asks for a Trust Token - how is this token generated.?? I have tried “incus config trust add IncusOS” but token is refused - Error: No matching certificate add operation found.
Did you provide an initial trusted client certificate when creating the install image? (See Getting an image - IncusOS documentation ) If not, IncusOS has no way to authenticate any API requests.
Thanks Mathius - I did provide the initial cert , maybe the copy/paste was incorrect - a fresh install has fixed the issue. Newbie to this OS.
