Potential issue when launching containers with custom root mount options
I am using Incus version 6.16 installed from the Zabbly repository. The host OS is Ubuntu 24.04.3. Incus backing storage for containers and images is Ceph RBD.
The goal is to launch a container to run Samba Active Directory Domain Controller, which as far as I understand requires the filesystem to be mounted with options acl and user_xattr.
So I tried:
incus launch images:ubuntu/24.04 addc01 –network incus-ovn –storage incus_rbd –device root,initial.block.filesystem=ext4 –device root,initial.block.mount_options=“rw,relatime,discard,stripe=16,acl,user_xattr”
Options “rw,relatime,discard,stripe=16” were added because they seem to be applied by default when launching other Ubuntu containers.
Verifying:
incus config show addc01
 <INFORMATION_OMITTED_FOR_BREVITY>
    network: incus-ovn
    initial.block.filesystem: ext4
    initial.block.mount_options: rw,relatime,discard,stripe=16,acl,user_xattr
    pool: incus_rbd
However, inside the container:
root@addc01:~# mount
/dev/rbd0 on / type ext4 (rw,relatime,idmapped,discard,stripe=16)
What am I missing? Should I first create the storage volume and then attach it during instance creation?
Thanks.
My guess is that those are default options so they don’t appear in the mount entry as no change happened from the default.
Here is an example outside of Incus:
root@castiana:~# mount /dev/zvol/castiana/test /mnt/ -o rw,relatime,discard,stripe=16,acl,user_xattr
root@castiana:~# cat /proc/mounts | grep /mnt
/dev/zd16 /mnt ext4 rw,relatime,discard,stripe=16 0 0
root@castiana:~#
Oh, I see. As the AD provision kept failing, I assumed this might be the issue. Well, must be something else thern. Thanks.
Is there any restriction in the use of extended attributes in containers? For example (these commands come from the samba wiki, for the purpose of testing xattr support):
root@addc04:~# touch test.txt
root@addc04:~# setfattr -n user.test -v test test.txt
root@addc04:~# setfattr -n security.test -v test2 test.txt
setfattr: test.txt: Operation not permitted
This is an unpriviledged container running ubuntu 24.04
Might be worth trying Instance options - Incus documentation
Thanks. I tried setting security.syscalls.intercept.setxattr to true, but:
root@addc04:/mnt# setfattr -n security.test -v test2 test.txt
Digging deeper in the documentation, I found the following:
setxattr
The setxattr system call is used to set extended attributes on files.
The attributes which are handled by this currently are:
  • trusted.overlay.opaque (overlayfs directory whiteout)
Does this mean that it does not address the scenario of setting random attributes to files?
thanks.
Ah yeah, security.XYZ is a very dangerous part of the xattr space, so not something we’d want to blindly escalate privilege on.
