Problem getting device list from lxc config device show
lxc command line is having problem showing container information"
Remote: unix://
Created: 2018/12/06 06:50 UTC
Status: Running
Type: persistent
Profiles: default
Pid: 4849
Ips:
  eth0:	inet	172.18.8.197
  eth0:	inet6	fd68:a08:802:8:216:3eff:fef6:dc91
  eth0:	inet6	fe80::216:3eff:fef6:dc91
  lo:	inet	127.0.0.1
  lo:	inet6	::1
Resources:
  Processes: 47
  CPU usage:
    CPU usage (in seconds): 23585
  Memory usage:
    Memory (current): 1.10GB
    Memory (peak): 1.15GB
  Network usage:
      Bytes received: 185.51MB
      Bytes sent: 15.44MB
      Packets received: 409323
      Packets sent: 154270
    lo:
      Bytes received: 307.91kB
      Bytes sent: 307.91kB
      Packets received: 3890
      Packets sent: 3890
    tunl0:
      Bytes received: 0B
      Bytes sent: 0B
      Packets received: 0
      Packets sent: 0
But when I do lxc config device info it shows empty string:
ubuntu@lxd-cluster-main:~$ lxc config device show matrix-server
Not sure whats the problem.
The problem is that you’re inheriting those devices from a profile so they’re not directly part of the container’s configuration. Look at lxc config show --expanded matrix-server which will show you the entire configuration with all the bits inherited from profiles.
