I have installed incus on my fedora 42 machine. I ran incus admin init
and kept everything at the default option except ipv6 which I disabled.
I launched a container with incus launch images:debian/12/default debian-test
and then went into it with incus shell debian-test
. Inside the container I tried to run apt update
but it seems like the networking doesn’t work. ping 1.1.1.1
seems to just get stuck too with no error.
This is the output of ip a
inside the container:
root@debian-test3:~# ip a
inet6 ::1/128 scope host
20: eth0@if21: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 10:66:6a:44:54:0e brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.153.209.132/24 metric 1024 brd 10.153.209.255 scope global dynamic eth0
valid_lft 3136sec preferred_lft 3136sec
inet6 fe80::1266:6aff:fe44:540e/64 scope link
This is the config of incusbr0
ipv4.address: 10.153.209.1/24
ipv6.address: none
ipv6.dhcp: "false"
ipv6.nat: "false"
ipv6.routing: "false"
type: bridge
- /1.0/instances/debian-test
- /1.0/instances/debian-test2
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
project: default
I have tried to disable IPv6 since my LAN doesn’t support it. I also don’t have a public IPv6 address but I don’t think that matters.
When looking for a solution I found that you first need to configure the fedora firewall to allow incus so I ran:
sudo firewall-cmd --zone=trusted --change-interface=incusbr0 --permanent
sudo firewall-cmd --reload
from this forum post.
Docker isn’t installed on the host any more, it was installed previously but the DOCKER-USER
chain doesn’t seem to exist any more.
This is the output of ip a show incusbr0
on the host:
4: incusbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 10:66:6a:40:a5:ae brd ff:ff:ff:ff:ff:ff
inet 10.153.209.1/24 scope global incusbr0
Thanks!
