Hello guys,
I have a serious problem, I’ve installed ceph a 3 nodes ceph, and I install lxd with snap (lxd 3.16) on all 3 nodes. But when I make “lxd init” command it comes directly on the storage backend question not on first question about clustering ? could you help please ?
Hi!
Your host may probably have already LXD installed, and specifically the LXD deb package.
Run apt policy lxd
as below. If in Installed: it does not say (none), then you have to uninstall first the deb package of LXD.
$ apt policy lxd
lxd:
Installed: (none)
Candidate: 3.0.3-0ubuntu1~16.04.5
To uninstall the DEB package of LXD,
sudo apt remove lxd
sudo apt autoremove
Yes it was deb package installation and I made lxd.migrate then the deb package has been uninstalled.
Thanks for your answer.
