[AMD Official Use Only]
I see this.
https://discuss.linuxcontainers.org/t/lxd-daemon-startup-problem/3302
truncate -s 1G /var/lib/lxd/disks/
I see this.
If you don’t mind losing your instances and images I would suggest starting afresh with:
sudo lxd init - run through configuring LXD which will create a storage pool for use with all of your instances (not just one of them).[AMD Official Use Only]
This is a terrible solution to dump containers.
Ok, so I did your list below. I reinstalled lxd. I have a release server regenerated from a backup I had done just a few days ago. But.. the network connection is not working.
#this is the command issued
lxc config device add ubuntu-vm-REL myport80 proxy listen=tcp:0.0.0.0:8002 connect=tcp:127.0.0.1:80002
Device myport80 added to ubuntu-vm-REL
Then I go into the container and I have python 3.
Python -m http.server 8002
This site can’t be reached.
asl@ASL-PC:~$ lxc config device add ubuntu-vm-REL myport8002 proxy listen=tcp:0.0.0.0:8002 connect=tcp:127.0.0.1:8002
Device myport8002 added to ubuntu-vm-REL
asl@ASL-PC:~$ lxc config device show ubuntu-vm-REL
myport8002:
connect: tcp:127.0.0.1:8002
listen: tcp:0.0.0.0:8002
type: proxy
asl@ASL-PC:~$
This worked in the past. Not sure why it’s not now. I don’t have any conflicting ports or containers setup at this point. This has worked in the past I thought.
lisa
Ok, got network working. 2 servers restored. One to go. I had a backup from lxc export
Now on backups…working off of instructions here.
https://www.cyberciti.biz/faq/how-to-backup-and-restore-lxd-containers/
See this error
asl@ASL-PC:~/backups/ubuntu-vm $ lxc import
Error: unknown command “import” for “lxc”
Run ‘lxc --help’ for usage.
There is no lxc import???
Thanks,
lisa
That suggests you’re on LXD 3.0.x or something. What does lxc version show you?
