There seems to be “random errors” when trying to extract docker images that gets pulled inside my LXC container.
I get error like these when trying to pull docker images:
Creating docker-compose.yml
Pulling docker images.
Pulling fluentd ... extracting (100.0%)
Pulling siridb ... extracting (100.0%)
Pulling redis ... done
Pulling postgres ... done
Pulling rabbitmq ... done
Pulling nginx ... download complete
Pulling ucrm ... download complete
Pulling unms ... download complete
Pulling netflow ... extracting (100.0%)
ERROR: for fluentd failed to register layer: Error processing tar file(exit status 1): replaceDirWithOverlayOpaque("/etc/ca-certificates") failed: createDirWithOverlayOpaque("/etc/rdwoo542523568") failed: failed to mkdir /etc/rdwoo542523568/m/d: mkdir /etc/rdwoo542523568/m/d: input/output error
ERROR: for nginx failed to register layer: Error processing tar file(exit status 1): replaceDirWithOverlayOpaque("/etc/nginx") failed: createDirWithOverlayOpaque("/etc/rdwoo087941222") failed: failed to mkdir /etc/rdwoo087941222/m/d: mkdir /etc/rdwoo087941222/m/d: input/output error
ERROR: for netflow failed to register layer: Error processing tar file(exit status 1): replaceDirWithOverlayOpaque("/home/app") failed: createDirWithOverlayOpaque("/home/rdwoo396199294") failed: failed to mkdir /home/rdwoo396199294/m/d: mkdir /home/rdwoo396199294/m/d: input/output error
ERROR: for ucrm failed to register layer: Error processing tar file(exit status 1): replaceDirWithOverlayOpaque("/usr/src/ucrm") failed: createDirWithOverlayOpaque("/usr/src/rdwoo985977234") failed: failed to mkdir /usr/src/rdwoo985977234/m/d: mkdir /usr/src/rdwoo985977234/m/d: input/output error
ERROR: for unms failed to register layer: Error processing tar file(exit status 1): replaceDirWithOverlayOpaque("/home/app") failed: createDirWithOverlayOpaque("/home/rdwoo590378847") failed: failed to mkdir /home/rdwoo590378847/m/d: mkdir /home/rdwoo590378847/m/d: input/output error
ERROR: for siridb failed to register layer: Error processing tar file(exit status 1): replaceDirWithOverlayOpaque("/etc/ca-certificates") failed: createDirWithOverlayOpaque("/etc/rdwoo210311524") failed: failed to mkdir /etc/rdwoo210311524/m/d: mkdir /etc/rdwoo210311524/m/d: input/output error
ERROR: failed to register layer: Error processing tar file(exit status 1): replaceDirWithOverlayOpaque("/etc/ca-certificates") failed: createDirWithOverlayOpaque("/etc/rdwoo210311524") failed: failed to mkdir /etc/rdwoo210311524/m/d: mkdir /etc/rdwoo210311524/m/d: input/output error
ERROR: Failed to pull docker images
On my host machine I get these errors in dmesg
Mar 01 20:23:55 lambda kernel: overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
Mar 01 20:23:50 lambda kernel: overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
Mar 01 20:23:46 lambda kernel: overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
Mar 01 20:23:43 lambda kernel: overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
Mar 01 20:23:37 lambda kernel: overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
Mar 01 20:23:36 lambda kernel: overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
Why is this?
