Problem to boot on ISO Incus
Hello there,
I had and have still a problem to boot on ISO, for example now i’m trying to install a windows vm and i did theses commands :
incus init windows-client --empty --vm -c limits.cpu=2 -c limits.memory=4GiB -d root,size=50GiB
incus storage volume import soc-storage Iso/windows_client/Win10_22H2_French_x64v1.iso win10-iso --type=iso
incus config device add windows-client win10-iso disk pool=soc-storage source=win10-iso boot.priority=10
incus start windows-client --console
but from here impossible to boot
If you have any solution i would love it
Have you tried to repack windows iso with distrobuilder first?
i have the exact same problem. I created the iso with
distrobuilder repack-windows --windows-arch amd64 --windows-version w11 windows11-en.iso windows11-en.incus.iso
I just realized that this command uses, by accident, the original ISO instead of the repacked Windows ISO.
@ogaida, welcome! Can you show the full commands that you are using?
@simos the problem only occurs in the webui. i have installed the virt-viewer on my mac, switched with incus remote switch ... to incus server and could start viewer with incus console w11 --type=vga successfully. From now on it is also possible to use the graphical console in the webui.
for the installation of virt-viewer on my mac m1 i used:
brew tap krishjainx/homebrew-virt-manager
brew install virt-manager
