I’m trying deploy k8s cluster inside LXD. I’am following THIS guide. Everything works fine without apparmor. Unfortunenly apparmor block deploy with conjure-up. Here is my kernel logs:
Dec 18 17:52:56 kubernetes kernel: [416846.378583] audit: type=1400 audit(1608313976.703:5615): apparmor=“DENIED” operation=“bind” profile=“snap.kube-apiserver.kube-apiserver” pid=753885 comm=“kube-apiserver” family=“unix” sock_type=“dgram” protocol=0 requested_mask=“bind” denied_mask=“bind” addr=none
Dec 18 17:52:56 kubernetes kernel: [416846.521961] audit: type=1400 audit(1608313976.847:5616): apparmor=“DENIED” operation=“bind” profile=“snap.kube-apiserver.kube-apiserver” pid=753917 comm=“kube-apiserver” family=“unix” sock_type=“dgram” protocol=0 requested_mask=“bind” denied_mask=“bind” addr=none
Dec 18 17:52:57 kubernetes kernel: [416846.711501] audit: type=1400 audit(1608313977.039:5617): apparmor=“DENIED” operation=“bind” profile=“snap.kube-apiserver.kube-apiserver” pid=753958 comm=“kube-apiserver” family=“unix” sock_type=“dgram” protocol=0 requested_mask=“bind” denied_mask=“bind” addr=none
Here is my lxd container config:
image.architecture: amd64
image.description: ubuntu 18.04 LTS amd64 (release) (20201211.1)
image.label: release
image.os: ubuntu
image.release: bionic
image.serial: "20201211.1"
image.type: squashfs
image.version: "18.04"
linux.kernel_modules: ip_vs,ip_vs_rr,ip_vs_wrr,ip_vs_sh,ip_tables,ip6_tables,netlink_diag,nf_nat,overlay,br_netfilter
raw.lxc: |
lxc.apparmor.profile=unconfined
lxc.mount.auto=proc:rw sys:rw cgroup:rw
lxc.cgroup.devices.allow=a
lxc.cap.drop=
security.nesting: "true"
security.privileged: "true"
volatile.base_image: 95c0e536d361eb5ac953ad343e0342c2f615e4aea714ca8a64126a228b809cae
volatile.eth0.host_name: vethde486604
volatile.eth0.hwaddr: 00:16:3e:fb:f9:0c
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
volatile.uuid: 17a2cfef-d443-4626-a38a-68dd68de9bb0
mem:
path: /dev/mem
type: unix-char
The entry lxc.apparmor.profile=unconfined does not seem to work. The workaround is to completely disable the apparmor, but it’s not a good solution for me because I have other containers running on this host. How can I disable apparmor for single container?
(Ps. sorry for my english
