guillomep
(Guillaume)
November 25, 2025, 10:51am
1
I have created a VM to create a Fedora desktop using the commands describe here How to create instances - Incus documentation
Then I have install it using the web ui of incus.
Now I want to access my VM using RDP, but when I’m starting krdp server it does an error: « egl failed to create dri2 screen »
I’m probably missing something with virtio or virgl but I don’t know what
catfish
November 26, 2025, 4:35am
2
which desktop environment do you use, x11 or wayland?
I’m running a debian container with headless x11 without trouble. I used to run a alpine container with headless wlroots wayland using WLR_BACKENDS=headless and WLR_LIBINPUT_NO_DEVICES=1.
do you only have one gpu in you pc and passthrough the gpu to the vm without config pci passthrough?
If not, can you try vnc?
or can you create vm using: incus create images:fedora/43 (name) --vm?
guillomep
(Guillaume)
November 26, 2025, 7:45am
3
I’m creating it with an empty VM and attaching an ISO, it is not a container.
I have no GPU passthrough for the VM. Maybe I should use VirGL
guillomep
(Guillaume)
November 26, 2025, 8:28am
4
I have install Incus on Debian Trixie using Zabbly repo and when I tried to add `gl=on` I get this error qemu-system-x86_64: OpenGL support was not enabled in this build of QEMU
catfish
November 26, 2025, 12:18pm
5
Please give me more details. I can’t help you by guessing. You only said you created a fedora VM by using ISO without GPU passthrough. And I guess you use kde.
cat /run/incus/(vm name)/qemu.conf
incus config show (vm name)
And all relate steps in VM.
guillomep
(Guillaume)
November 26, 2025, 1:14pm
6
Yes no problem and you guess right I use KDE
# Machine
[machine]
usb = "off"
type = "q35"
graphics = "off"
accel = "kvm"
[global]
driver = "ICH9-LPC"
property = "disable_s3"
value = "1"
[global]
value = "0"
driver = "ICH9-LPC"
property = "disable_s4"
[boot-opts]
strict = "on"
# Memory
[memory]
slots = "8"
size = "8192M"
maxmem = "62122M"
# CPU
[smp-opts]
maxcpus = "18"
cpus = "1"
[object "mem0"]
qom-type = "memory-backend-memfd"
size = "8192M"
share = "on"
[numa]
type = "node"
nodeid = "0"
memdev = "mem0"
# Firmware (read only)
[drive]
unit = "0"
readonly = "on"
file = "/opt/incus/share/qemu/OVMF_CODE.4MB.fd"
if = "pflash"
format = "raw"
# Firmware settings (writable)
[drive]
file = "/dev/fd/4"
if = "pflash"
format = "raw"
unit = "1"
# Qemu control
[chardev "monitor"]
wait = "off"
path = "/run/incus/desktop/qemu.monitor"
backend = "socket"
server = "on"
[mon]
mode = "control"
chardev = "monitor"
# Console
[chardev "console"]
backend = "ringbuf"
size = "1048576"
# VM core info driver
[device "qemu_vmcoreinfo"]
driver = "vmcoreinfo"
[device "qemu_pcie0"]
driver = "pcie-root-port"
bus = "pcie.0"
addr = "1.0"
chassis = "0"
multifunction = "on"
# Balloon driver
[device "qemu_balloon"]
driver = "virtio-balloon-pci"
bus = "qemu_pcie0"
addr = "00.0"
# Random number generator
[object "qemu_rng"]
qom-type = "rng-random"
filename = "/dev/urandom"
[device "dev-qemu_rng"]
bus = "qemu_pcie0"
addr = "00.1"
rng = "qemu_rng"
driver = "virtio-rng-pci"
# Input
[device "qemu_keyboard"]
driver = "virtio-keyboard-pci"
bus = "qemu_pcie0"
addr = "00.2"
# Input
[device "qemu_tablet"]
driver = "virtio-tablet-pci"
bus = "qemu_pcie0"
addr = "00.3"
# Vsock
[device "qemu_vsock"]
vhostfd = "3"
driver = "vhost-vsock-pci"
bus = "qemu_pcie0"
addr = "00.4"
guest-cid = "3348623858"
# Virtual serial bus
[device "dev-qemu_serial"]
bus = "qemu_pcie0"
addr = "00.5"
driver = "virtio-serial-pci"
# Serial identifier
[chardev "qemu_serial-chardev"]
backend = "ringbuf"
size = "16B"
[device "qemu_serial"]
driver = "virtserialport"
name = "org.linuxcontainers.incus"
bus = "dev-qemu_serial.0"
chardev = "qemu_serial-chardev"
[device "qemu_serial_legacy"]
name = "org.linuxcontainers.lxd"
# Spice agent
[chardev "qemu_spice-chardev"]
backend = "spicevmc"
name = "vdagent"
[device "qemu_spice"]
name = "com.redhat.spice.0"
chardev = "qemu_spice-chardev"
# Spice folder
[chardev "qemu_spicedir-chardev"]
backend = "spiceport"
name = "org.spice-space.webdav.0"
[device "qemu_spicedir"]
chardev = "qemu_spicedir-chardev"
# USB controller
[device "qemu_usb"]
driver = "qemu-xhci"
bus = "qemu_pcie0"
addr = "00.6"
p2 = "8"
p3 = "8"
[chardev "qemu_spice-usb-chardev1"]
name = "usbredir"
[device "qemu_spice-usb1"]
driver = "usb-redir"
chardev = "qemu_spice-usb-chardev1"
[chardev "qemu_spice-usb-chardev2"]
name = "usbredir"
[device "qemu_spice-usb2"]
chardev = "qemu_spice-usb-chardev2"
[chardev "qemu_spice-usb-chardev3"]
name = "usbredir"
[device "qemu_spice-usb3"]
chardev = "qemu_spice-usb-chardev3"
# Sound device
[audiodev "qemu_spice-audiodev"]
driver = "spice"
[device "qemu_spice-audio"]
driver = "virtio-sound-pci"
bus = "qemu_pcie0"
addr = "00.7"
audiodev = "qemu_spice-audiodev"
[device "qemu_pcie1"]
chassis = "1"
bus = "pcie.0"
addr = "1.1"
# SCSI controller
[device "qemu_scsi"]
driver = "virtio-scsi-pci"
bus = "qemu_pcie1"
addr = "00.0"
[device "qemu_pcie2"]
bus = "pcie.0"
addr = "1.2"
chassis = "2"
# Shared config drive (9p)
[fsdev "qemu_config"]
path = "/var/lib/incus/devices/desktop/config.mount"
fsdriver = "local"
security_model = "none"
readonly = "on"
[device "dev-qemu_config-drive-9p"]
mount_tag = "config"
fsdev = "qemu_config"
driver = "virtio-9p-pci"
bus = "qemu_pcie2"
addr = "00.0"
# Shared agent drive (9p)
[fsdev "qemu_agent"]
readonly = "on"
path = "/opt/incus/agent/"
fsdriver = "local"
[device "dev-qemu_agent-drive-9p"]
fsdev = "qemu_agent"
bus = "qemu_pcie2"
addr = "00.1"
mount_tag = "agent"
[device "qemu_pcie3"]
bus = "pcie.0"
addr = "1.3"
chassis = "3"
# GPU
[device "qemu_gpu"]
driver = "virtio-vga"
bus = "qemu_pcie3"
addr = "00.0"
[device "qemu_pcie4"]
bus = "pcie.0"
addr = "1.4"
chassis = "4"
# VM Generation ID
[device "vmgenid0"]
driver = "vmgenid"
guid = "a3f6430b-21db-44ed-8a20-26080b629f78"
[device "qemu_pcie5"]
bus = "pcie.0"
addr = "1.5"
chassis = "5"
[device "qemu_pcie6"]
bus = "pcie.0"
addr = "1.6"
chassis = "6"
[device "qemu_pcie7"]
bus = "pcie.0"
addr = "1.7"
chassis = "7"
[device "qemu_pcie8"]
bus = "pcie.0"
addr = "2.0"
chassis = "8"
[device "qemu_pcie9"]
addr = "2.1"
chassis = "9"
bus = "pcie.0"
[device "qemu_pcie10"]
chassis = "10"
bus = "pcie.0"
addr = "2.2"
[device "qemu_pcie11"]
bus = "pcie.0"
addr = "2.3"
chassis = "11"
[device "qemu_pcie12"]
chassis = "12"
bus = "pcie.0"
addr = "2.4"
And
boot.autorestart: "true"
boot.autostart: "true"
limits.cpu: "4"
limits.memory: 8GiB
volatile.cloud-init.instance-id: 8ae05749-945c-4493-9d8d-48fe0f3e1f91
volatile.eth0.host_name: tap4d5dcdbf
volatile.eth0.hwaddr: 10:66:6a:5a:de:2a
volatile.eth0.last_state.ip_addresses: 10.100.1.13,fd12:3456:7890:1:1266:6aff:fe5a:de2a
volatile.uuid: a3f6430b-21db-44ed-8a20-26080b629f78
volatile.uuid.generation: a3f6430b-21db-44ed-8a20-26080b629f78
volatile.vm.definition: pc-q35-10.1
volatile.vm.rtc_adjustment: "-1"
volatile.vm.rtc_offset: "1"
volatile.vsock_id: "3348623858"
data:
pool: data
source: data
iso-volume:
boot.priority: "10"
pool: data
source: fedora-kinoite-43
description: Desktop PC
(iso is detached once installed)
After Fedora is up and running, I go in the settings of KDE, section “Remote Desktop” to enable the RDP server.
Then look to journalctl -f /usr/bin/krdpserver and see the message.
Also if I run eglinfo -B I get the same message.
catfish
November 26, 2025, 3:46pm
7
After 2 hours trying, I gave up. I tried to install kde in a fedora vm, but can’t start kde. Then I installed kde in a debian vm, but can’t start krdp. I know why you install fedora from ISO now. Due to I can’t reproduce your environment, I can only give you some points to try. I feel sorry about not being able to help you anymore.
First, gl=on is impossible:
Right, the reason why we don’t build or try to enable VirGL is that from my understanding it only really works with SPICE when run on the same system that runs the VM. There’s never any such guarantee with LXD as everything, even local requests always go over our REST API.
Another issue with VirGL is the need for a full stack of DRI/DRM drivers be present and loadable by qemu. Not only does this potentially expand the attack surface of qemu quite significantly (because we’d need to allow for a …
Second, you can try this drivers for test:
For example:
description: qemu driver
devices: {}
raw.qemu.conf: |-
[device "qemu_gpu"]
driver = "qxl-vga"
Third, you can try vnc.
Fourth, use another desktop environment.
Fifth, use container. It’s very easy to use gpu. Just change gid to container’s video gid and change gpu’s pci address.
description: hardware acceleration
mygpu:
gid: '44'
gputype: physical
pci: '0000:00:02.0'
type: gpu
guillomep
(Guillaume)
November 26, 2025, 4:03pm
8
Thank you for your reply
Is it possible to install a full DE in a non privileged LXC ?
I already use the gpu for some LXC but no passthrough
Maybe I will look to SR-IOV to split my GPU and do passthrough
catfish
November 26, 2025, 4:14pm
9
Yes, I’m running mate desktop in a unprivileged LXC.
When we say gpu passthrough to linux container means add the hwac profile to the lxc, doesn’t means real gpu passthrough, because we haven’t make a term for it. Same gpu can be shared by multiple containers.
guillomep
(Guillaume)
November 26, 2025, 4:27pm
10
Do you have a config to share for your mate desktop please
catfish
November 26, 2025, 5:01pm
11
Nothing fancy. I create a container with hwac profile. And I just install mate-desktop-environment and tigervnc-standalone-server.
And auto start vnc use systemd.
[Unit]
Description=Start TigerVNC server at startup
After=syslog.target network.target
[Service]
Type=simple
User=(username)
Group=(username)
WorkingDirectory=/home/(username)
PIDFile=/home/(username)/.vnc/%H:590%i.pid
ExecStartPre=-/bin/sh -c "/usr/bin/vncserver -kill :%i > /dev/null 2>&1"
ExecStart=/usr/bin/vncserver -fg -depth 24 -geometry 1920x1080 -localhost no :%i
ExecStop=/usr/bin/vncserver -kill :%i
[Install]
WantedBy=multi-user.target
catfish
November 26, 2025, 5:10pm
12
Oh,I forgot tigervnc config.
~/.vnc/xstartup
#!/bin/sh
unset SESSION_MANAGER
unset DBUS_SESSION_BUS_ADDRESS
mate-session
