I’m facing an issue where incus copy node1:origin-container new-container fails when copying a container to multiple nodes simultaneously. The second copy fails with:
Error: Failed migration on source: A matching non-reusable operation has now succeeded
I’m trying to run the command on node2 & node3. origin-container on node1 is stopped.
Setup
- Nodes aren’t in cluster mode
- PKI trust between them
- ZFS backend
- Incus
6.12 - Ubuntu noble, latest
24.04 - Zabbly kernel
6.10.14-zabbly+ - Zabbly zfs
2.2.5-amd64-202408071636-ubuntu24.04
What I Tried
- Manually ran
zfs send | zfs receiveon the same dataset to multiple nodes - works. - Checked Incus code - it seems to block parallel copies.
Questions
- Is this a bug in Incus, or an intentional design (e.g., to avoid race conditions)?
- Is this a ZFS limitation (e.g., lock during
zfs send), or Incus-specific? - Can this be bypassed?
The current behavior causes slower replica(clone/copy) creation (have to wait for the first to end). Any insight would help!
