Hi, I have a problem with the LXC REST API. I set the port and password on which the API should listen. And how I use curl on the machine I get the response.
Hi, If you are using self signed certificates, you need to allow it in Postman.
In your Postman screenshot at line with: Self-signed SSL certificates are being blocked: Fix this by turing off ‘SSL certificate verification’ in Settings > General
