Restart from scratch lxc (uninstall and reinstall lxc) or can you return to default configuration?
Regards!!!
Regards!!!
You should be able to just undo any change you made to /etc/default/lxc-net and then restart the lxc-bridge service.
Would also help a bit if you could tell us more about what the problem is.
Hello @stgraber thank you very much for your answer
Since I created my first container I have not had access to the internet.
I have used several configurations that I found online but I have not found the right one for my case
That’s why I decided to start from an installation of lxc as recently installed.
I was able to create a bridge to configure the containers but I could not configure it correctly to have connectivity with the internet
It is the first time that I use bridge for a configuration of virtualization in linux and I assume that it is my biggest problem at the moment
I have the doubt that a video that I found https://youtu.be/4TzMl6mkqWU?t=5m47s is shown after installing lxc starts a container, that container at once has no ip but then gives an ip and can be ping
What files should I show the content to see if my settings are correct? both in the lxc Debian 9 server and in the container
Regards!!
The following files would be useful:
/etc/default/lxc
# LXC_AUTO - whether or not to start containers at boot
LXC_AUTO="true"
# BOOTGROUPS - What groups should start on bootup?
# Comma separated list of groups.
# Leading comma, trailing comma or embedded double
# comma indicates when the NULL group should be run.
# Example (default): boot the onboot group first then the NULL group
BOOTGROUPS="onboot,"
# SHUTDOWNDELAY - Wait time for a container to shut down.
# Container shutdown can result in lengthy system
# shutdown times. Even 5 seconds per container can be
# too long.
SHUTDOWNDELAY=5
# OPTIONS can be used for anything else.
# If you want to boot everything then
# options can be "-a" or "-a -A".
OPTIONS=
# STOPOPTS are stop options. The can be used for anything else to stop.
# If you want to kill containers fast, use -k
STOPOPTS="-a -A -s"
USE_LXC_BRIDGE="false" # overridden in lxc-net
[ ! -f /etc/default/lxc-net ] || . /etc/default/lxc-net
USE_LXC_BRIDGE="true"
LXC_BRIDGE="bt0"
LXC_ADDR="192.168.3.10"
LXC_NETMASK="255.255.255.0"
LXC_NETWORK="192.168.3.0/24"
LXC_DHCP_RANGE="192.168.3.2,10.0.3.254"
LXC_DHCP_MAX="253"
LXC_DHCP_CONFILE=""
LXC_DOMAIN=""
/etc/lxc/default.conf
lxc.network.type = empty
/var/lib/lxc/d9lxc/config
# Template used to create this container: /usr/share/lxc/templates/lxc-debian
# Parameters passed to the template: -r stretch
# Template script checksum (SHA-1): 127e2020d76da79709d5e4e0c7e347f40a6a793b
#lxc.include = /usr/share/lxc/config/nesting.conf
lxc.rootfs = /var/lib/lxc/d9lxc/rootfs
lxc.rootfs.backend = dir
# Common configuration
lxc.include = /usr/share/lxc/config/debian.common.conf
lxc.tty = 4
lxc.utsname = d9lxc
lxc.arch = amd64
Ok, so your /etc/lxc/default.conf is the issue, which cause the same problem to be replicated in your container’s config.
I suspect you want both /etc/lxc/default.conf and /var/lib/lxc/d9lxc/config changed, replacing:
with:
lxc.network.type = veth
lxc.network.link = bt0
lxc.network.flags = up
lxc.network.hwaddr = 00:16:3e:xx:xx:xx
Which will have your existing container and any new ones get connected to your bt0 bridge rather than be provisioned with no network interfaces.
I tried to start the container but it shows me the following:
~# lxc-start -n d9lxc
lxc-start: tools/lxc_start.c: main: 366 The container failed to start.
lxc-start: tools/lxc_start.c: main: 368 To get more details, run the container in foreground mode.
lxc-start: tools/lxc_start.c: main: 370 Additional information can be obtained by setting the --logfile and --logpriority options.
~# lxc-start -n d9lxc -F
lxc-start: conf.c: instantiate_veth: 2669 failed to attach 'vethRCGOWL' to the bridge 'bt0': Operation not permitted
lxc-start: conf.c: lxc_create_network: 2962 failed to create netdev
lxc-start: start.c: lxc_spawn: 1088 Failed to create the network. lxc-start: start.c: __lxc_start: 1346 Failed to spawn container "d9lxc". lxc-start: tools/lxc_start.c: main: 366 The container failed to start. lxc-start: tools/lxc_start.c: main: 370 Additional information can be obtained by setting the --logfile and --logpriority options.
these are my network configurations on my lxc Debian 9 server:
/etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo bt0
iface lo inet loopback
# Configurar interfaces manualmente, evitando conflictos con, por ejemplo, el administrador de red
iface bt0 inet manual
# Configuración del puente
iface bt0 inet static
bridge_ports enp3s0
address 192.168.0.200
broadcast 192.168.0.255
netmask 255.255.255.0
gateway 192.168.0.90
dns-nameservers 8.8.8.8 8.8.4.4
~# ip address show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
inet6 ::1/128 scope host
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 74:d4:35:5e:e0:7a brd ff:ff:ff:ff:ff:ff
inet 192.168.0.223/24 brd 192.168.0.255 scope global dynamic enp3s0
valid_lft 5976sec preferred_lft 5976sec
inet6 fe80::b7f7:2aa8:7eeb:1851/64 scope link
3: enp4s6: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 00:00:e8:f9:74:75 brd ff:ff:ff:ff:ff:ff
activating bridge (when activating the bridge I am left without internet connection on my lxc Debian 9 server):
~# ifup bt0
~# ip address show
2: enp3s0: <BROADCAST,MULTICAST> mtu 1500 qdisc pfifo_fast master bt0 state DOWN group default qlen 1000
61: bt0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
inet 192.168.0.200/24 brd 192.168.0.255 scope global bt0
inet6 fe80::76d4:35ff:fe5e:e07a/64 scope link
Turn off my Debian 9 server and the bridge works correctly in my container, also update my old containers in your conf file with the new bridge data (bt0) and correctly assign me ip
If I have any problem related to this topic I will continue posting here
Regards!!
